Electric Hammer Drill: How to Activate Impact Mode (Button Location & Usage)
Hipodrom 28500 11
Where is the switch to turn impact mode on and off on my hammer drill?
Impact mode is controlled by the orange slider on top of the drill near the head; move that switch perpendicular to the drill axis to choose between hammer and drill [#10237818] [#10237983] [#10238083] The right-left lever underneath is for rotation direction, not impact mode [#10237895] The wheel by the trigger is for speed limiting/max RPM, not the hammer function [#10238110] [#10238114]
  • #1 10237801
    Hipodrom
    I have a hopelessly simple question... I have a hammer drill like this:
    where is there a button to turn it on and off? :cry:
  • #3 10237895
    magneto0909
    Rate: 76
    Hello.right-left is marked hammer, drill.
  • #4 10237937
    Hipodrom
    I don't understand... the orange one or triggers? I can only press it and turn the wheel + - (I do not know what it is for ... I thought it was for rotation but it does not change anything)
    under the "belly" has such a lever and I can give it right-left, but it seems to me that this is the direction of rotation ...
    I don't see a hammer anywhere
    I'm just going to use it for the first time and it's for glass so I want to make sure that the impact is not turned on
    popielarski.555
    It's about this 'switch' on top of the drill not far from the head. And that's how a colleague would feel if the stroke is on when drilling in something hard.
    Atreyu Makiavel
    Help: 112
    Rate: 318
    Atreyu Makiavel wrote:
    from the top
    If I meant trigger, wouldn't I have written "trigger"? There is a slider from the top, it works perpendicular to the axis of the drill, orange. AND IT IS FROM ABOVE.
  • #7 10238090
    Hipodrom
    right ;) thanks a lot
    Can anyone tell me what the trigger wheel is for? it's not the speed of rotation :( I can spin + and - up to a certain point
  • #9 10238114
    Dziarski Hank
    Help: 246
    Rate: 934
    Maximum RPM limitation. By turning it, you decrease the stroke of the "trigger".
  • #10 10238191
    Hipodrom
    I have one more question, because I just drilled a "trial" piece of glass and unfortunately it shattered at the time of puncture. All drilling was fine... what am I doing wrong?
    I have a drill with the hammer off
    drill bit "for tiles or glass"
    I was drilling freely.
    I don't really know what else I can do...
    is it better to throw faster revolutions or better slow and push harder with a drill on the glass?
  • #11 10238219
    merolPL
    Help: 68
    Rate: 45
    If you want the hammer to engage, the drill must have the right speed and pressure on the drill.
  • #12 10238233
The discussion revolves around activating the impact mode on an electric hammer drill. Users clarify that the button to engage the hammer function is an orange slider located on top of the drill, near the head. The original poster expresses confusion about the controls, particularly the trigger wheel, which adjusts the rotation speed. Additional inquiries focus on drilling techniques for glass, with advice emphasizing the importance of using the correct drill bit, maintaining appropriate speed and pressure, and employing proper technique to avoid damaging the material. The conversation highlights the challenges of drilling glass and suggests that professional assistance may be necessary for optimal results.
