How to Revive a Frozen Laptop: Alternative Methods to Removing Batteries (90 characters)
donka 102834 6
  • #1 1361365
    donka
    Well, today I had such a problem as with the topic, the suspended laptop did not react to anything, I temporarily took out the batteries to revive it. Is there any other way to do this?
  • #2 1361587
    shinay
    Rate: 9
    yyy it probably depends on the laptop model itself.
    but try to hold it pressed or moved (it depends on how you have the laptop)
    switch for about 4 seconds (as in ATX)
  • #3 1370814
    bocian11
    Hello, if this is an older type of HP, there is a small hole on the back where you can press, for example, a pen - there is a restart button in this hole.
    Greetings! ;)
  • #4 1373947
    haker85
    Help: 7
    Rate: 9
    Either you cut the power switch for 4 seconds, or in most laptops the reset button is at the bottom (underneath the laptop)
  • #5 1374443
    henryk_o
    Help: 9
    Rate: 15
    That's right, most loptop machines have a "hole" underneath. You take a pen, needle, skirmish or whatever and reset it.
  • #6 1471062
    mipix
    Help: 495
    Rate: 1487
    oh, how long have I not seen a frozen laptop ;) . The method of holding the power button for a few seconds usually works.
  • #7 1471073
    gabik001
    Level 37  
    Help: 305
    Rate: 418
    And in the case of Q armada, both power buttons at the same time ...
To revive a frozen laptop, users can try several methods beyond removing the battery. Common techniques include holding the power button for several seconds to force a shutdown, using a reset button located at the bottom or back of the laptop (often accessible with a pen or needle), or cutting the power switch for a few seconds. Specific advice for older HP models includes locating a small reset hole on the back of the device. These methods may vary depending on the laptop model.
