Eliminating Battery Alert Message on HP Pavilion dv9770ew Laptop - Procedures?
herkules_00 9144 2
  • #1 16446975
    herkules_00
    Help: 9
    Hello! When starting the HP Pavilion dv9770ew laptop, I get a message:
    "HP Battery Alert
    The system has detected that the capacity of the battery listed below is very low.
    For optimal performance, replace the battery.
    Primary (internal) battery (601)
    ENTER - Continue system booting
    For more information, please visit: www.hp.com \ go \ techcenter \ startup "
    According to the description link performs a battery test but I do not know how to calibrate so that the message disappears.
  • #2 16446998
    grubas
    Level 40  
    Help: 647
    Rate: 553
    Defective battery. If from bios, replace it and when it comes to the battery, buy a new one or use it on the power supply itself.
  • #3 16447294
    sk1977
    IT specialist
    Help: 1326
    Rate: 742
    The solution on the HP website will bring a positive effect only if the battery is functional and has adequate capacity.
    If not, it remains to replace the battery, remove and use only the power supply, you will get used to the message.
    Batterymon can provide detailed information on the condition of the battery.
