HP HSTNN-LB40 5225mAh Laptop Battery Regeneration: Unlocking Electronics & Revival Tips
dawid1346 12744 3
  • #1 17277983
    dawid1346
    Rate: 24
    I have a completely dead battery from HP.
    I opened it and it turned out that the links are ok. I still charged them with the IMAX B6 charger.
    After connecting the battery to the laptop, it does not load and shows that it is discharged and the HP Battery Check software to change the battery.
    Probably blocked electronics.
    Is it possible to unlock somehow? It is worth having fun?
    Battery HP HSTNN-LB40 5225mAh
  • #2 17278009
    kiss39
    Help: 397
    Rate: 636
    ATTENTION! - the wrong link can explode.
    Eliminate the damaged link or the one dropped below the critical one (the battery was left unused for a long time and unused), now each cell should be checked and recharged.
    Do you have to reach all the links? As it is, you need to solder each cell and see if it can be recharged. Used for landing cells with security modules, eg. Battery charger Li-ion 1A TP4056 USB micro
  • #3 17278011
    dawid1346
    Rate: 24
    I have access and I have loaded it with 2 connected in parallel.
    The voltage at the output of all cells (3 cells after 2 cells) gives a voltage of 11.9v
    HP HSTNN-LB40 5225mAh Laptop Battery Regeneration: Unlocking Electronics & Revival TipsIMG_201806...615[1].jpg (2.79 MB)You must be logged in to download this attachment.
  • #4 17279923
    automobilklub
    Help: 21
    Rate: 176
    Kiss39, the author wrote that the links are working? You do not have to disconnect and check. Probably the battery has reached the limit of the number of charges and orders it to be replaced. You can read the batch and save it back after modification. There was a large subject somewhere on the electrode, including batches and a simple diagram for reading the memory through the battery connectors.
