A warm hello to everyone on the forum.
My Philips Saeco HD8856/09 coffee machine is displaying error code E05. What is causing this? Where can I find the error code table?
Thank you in advance for your reply.
I forgot to mention that on the Philips website I found the following: “Check that the latch securing the brewing unit is in the correct position, as shown in the diagram. If not, push it upwards until you hear a soft click. @113183@ E05 (flow meter/boiler/pump): Make sure the water tank is correctly installed. "
The brewing unit is fitted correctly – as for the rest, how can I check?
