Saeco Exprelia - Filling the water circuit and the message restart the machine
luckyluk7 90489 47
Why does my Saeco Exprelia keep trying to fill the water circuit and then stop with E05 asking to restart the machine?
The E05 error usually means the machine does not detect water flow, most often because the heater/steam boiler circuit is clogged with limescale, the flow meter is faulty or wet, or a solenoid drain valve is leaking into the flow meter [#12209009] [#13682820] [#16666194] [#17546560] Start with a proper Saeco descaling cycle; if that does not help, check the steam heater and its inlet hose for a hard scale plug, because one user fixed E05 by clearing a completely clogged heater [#13662599] [#17548783] Another common cause of repeated “filling water circuit” messages is air in the pump, which can sometimes be bled by quickly lifting and lowering the water tank about 10 times [#15162418] If the warning about emptying the tray appears during descaling, also inspect the tray/door magnet sensor, because a bad magnet or sensor can make the machine think the tray was removed [#17320677] [#16194693]
  • #1 11157016
    luckyluk7
    Hello!
    I’m having a problem with my coffee machine. When I switch it on, a message appears saying that the water circuit is filling up and I can hear it pumping water, but the process doesn’t finish because the message ‘Please restart the machine. Error E05".
    I should just add that I had a similar issue a month ago, but I gave the unit a good rinse and the problem went away. Yesterday, an icon appeared on the display indicating that I needed to carry out a descaling process, but I don’t think that’s the cause, especially as I descale it every month.
    I think it’s the pump’s fault, because after a few attempts to switch it on (after 30 seconds, as stated in the manual), it finally made me a coffee, but immediately a message appeared telling me to empty the drip tray. After emptying the water, the machine started filling the water block, and after a moment, the E05 error message appeared again.
    Thanks in advance for your replies.
    Łukasz
  • #2 11364873
    susel_daniel
    Rate: 24
    hello, I have the same problem, did you manage to diagnose what is the cause?
  • #3 12198864
    predi3
    Rate: 12
    Hello, has anyone dealt with this problem? I have the same problem as described above. Please help.
    Regards
  • #4 12209009
    Patryk L
    Help: 16
    Rate: 79
    Hello ! Coffeemaker "does not see" the flow of water. Most likely there is a blocked steam boiler. For starters, it is a good idea to pour in a good dose of descaler and try to rinse the device. If it doesn't help, then just demolition and search for where it got stuck.
    Regards, Patryk_L
    PPL Serwis
    Dworcowa 11/2, Zielona Góra, 65-001
  • #5 13662599
    anikita
    Rate: 20
    In my case, when the E05 error appeared in Saeco Exprelia, the reason was the heater clogged with limescale from the water.
    After the fact, I know that it would be enough to remove only the back cover to get to the heater. In a working heater, it was possible to insert the probe in the form of a hex key, about 10cm long, deep into the heater's supply hole with water from the pump. It was also possible to blow the heater and rinse it with water, but in a clogged one it was out of the question. In the service manual, to the aforementioned heater connector, a tube with the number 26 is attached, as marked in table 6/9.
    Having a choice to buy a new heater for PLN 110 + shipping or try to repair and possibly buy a new heater, I took a 3mm drill and started drilling delicately. When I saw a stone deposited from water on the drill, I drilled bolder until the drill "fell".
    After folding, the water circuit became blocked and the heater is still functional and the message / error E05 does not appear. The repair cost about PLN 5, because I put new clamps on the water pipes. I bought them at an auto parts store.
    I would like to add that the first signs before the E05 error appeared were problems with milk foaming.
    I attach photos of the heater that I was repairing.
    Saeco Exprelia - Filling the water circuit and the message restart the machine Saeco Exprelia - Filling the water circuit and the message restart the machine Saeco Exprelia - Filling the water circuit and the message restart the machine
    Added after 27 [minutes]:
    For people trying to disassemble the Saeco Exprelia type HD8856 / 09, I will suggest that first you need to unscrew the back cover, which is well described in the service manual (I found only the English version), then you need to disassemble the upper part of the housing, which the manual did not mention. I am attaching photos showing where the latches blocking the disassembly of the top were located, even though I unscrewed the screws holding the top casing (4 pcs.). Undoing the four latches holding the top was an acrobatics for me.
    After removing the top, two screws were exposed, located in the front upper part of the coffee machine on the left and right side.
    I greet the designers of the device, because they THOUGHT what to do so that it would not be easy for us to get inside. These screws, covered with the upper case, could be left on top, leaving the holes for unscrewing them, and inserting the plugs.
    Disassembly would then be much easier. Moreover, even the service manual did not mention these two screws.
    Saeco Exprelia - Filling the water circuit and the message restart the machine Saeco Exprelia - Filling the water circuit and the message restart the machine Saeco Exprelia - Filling the water circuit and the message restart the machine Saeco Exprelia - Filling the water circuit and the message restart the machine Saeco Exprelia - Filling the water circuit and the message restart the machine Saeco Exprelia - Filling the water circuit and the message restart the machine
  • #6 13682820
    cafedomino
    Help: 35
    Rate: 360
    E5 is no reading from the flow meter. The reasons are three: 1) - the system is clogged with limescale (everyone says that descaling the question is only what I know aces, what they buy any cheaper and then surprised with the clogged descaler, the descaler is not equal to the fact that the kettle does not mean that it is good for coffee machines) 2) - not doing cleaning the brewing group with a suitable tablet (this message is not displayed, you must activate it yourself) if this cleaning is not done, the upper sieve of the brewing group is clogged with fat contained in the coffee, it remains to open the sieve, scrub and start the cycle with the tablet. 3) - defective flow meter.
  • #7 13684837
    anikita
    Rate: 20
    I would like to add that I descale using Saeco products always within no more than 4 days from the message. The entire system was not stony. I looked into the pipes and valves and only this heater was clean. After this adventure, I wonder if I should start using vinegar for descaling. Maybe it will do better.
  • #8 13685333
    cafedomino
    Help: 35
    Rate: 360
    Usually, a pin is made in a thermoblock due to the small diameter of the pipe through which the water flows, the silicone pipes have larger diameters and are slippery inside, which makes it difficult to deposit stone. By pouring the vinegar, you will make the coffee maker even bigger. A good descaler is supposed to dissolve the limescale, and not to dissolve some of it as vinegar, and to split some of it, if the pump pumps the debris into the thermoblock, it is wiped away. When the plug inside the heater is made, you will not unclog it with any drill or wire. I always recommend that my customers pour in the entire 250ml bottle. Saeco descaling agent, add 250 ml of warm water to the water tank and descale this proportionally.
  • #9 13685635
    anikita
    Rate: 20
    Thanks for the advice.
  • #10 13685949
    cafedomino
    Help: 35
    Rate: 360
    Bands purchased in an automotive store (twisted) are not the best solution, look for clamps like they are originally fitted. Size 9.5mm.
  • #11 13686423
    anikita
    Rate: 20
    I bought twisted. Can they pass because they tighten unevenly? During the tests, the operation after the repair did not pass. They firmly fastened the wires on the connection tubes. Or is there a risk that it has burst due to thermal stresses?
  • #12 13689803
    cafedomino
    Help: 35
    Rate: 360
    You can buy the bands at pressure hydraulics stores or at the north.pl store.
  • #13 13873008
    kgolebiowski
    Rate: 10
    How to remove the zip ties without using special pliers?
    Is it possible to buy water pipes with red braid somewhere?
  • #14 14176830
  • #15 15162418
    MIKO777
    Rate: 20
    The reason for frequent filling of the water circuit and lack of preliminary rinsing is the air in the water pump ....... the sensor sees air in the circuit and disconnects it with a safety valve,
    SOLUTION deaerating the pump in a very simple and quick way, just lift and lower the water container, do it quite quickly, at least 10 times and the pump will vent itself using this valve
    In case of other problems, please visit PRIV :D
  • #16 15272085
    Ronin
    Rate: 59
    I have the same problem. Your way is effective. However, I have to do it every time the machine wants to start cleaning. Have you found the target solution?
  • #17 15275507
    MIKO777
    Rate: 20
    Hello buddy
    If you still have this problem, remove the brew group and clean the brush, guides from the inside, and then lubricate it, then manually try to move the mechanism all the way and back. The water nozzle probably does not come to an end and therefore releases water through the safety valve
    Regards
  • #18 15699008
    Marcin Sliwa
    Rate: 8
    I will join the topic because the E05 error was popping up.
    It turned out that it was dripping on the flow meter with the ring above the vent valve (aswo documentation no. 30 p / n 20006558). I drain the water with a handkerchief, the error does not pop up, but drips. I do not fully understand the principle of operation and the moment of switching on this system and why it is dripping ...
    I checked the hoses, patency and nozzles as if everything was ok (makes coffee, froths milk, makes steam) and still drips.
    At what point is this valve supposed to work?
  • #19 15699025
    Ronin
    Rate: 59
    It is not a valve. He's counting the flow of water, let's say in liters. Hence the name flow meter. This could be a good clue as it has wet contacts, it can plant mistakes. For me, no errors pop up, only has a problem with the initial cleaning.
  • #20 15699940
    Marcin Sliwa
    Rate: 8
    I did not mean the flow meter, only in this model there is a valve just above the flow meter and water flows from one of the seals. The seals of the replaced cracks cannot be seen and the water is dripping.
  • Descaling mode fails to detect the drip tray
    #21 15736855
    Ronin
    Rate: 59
    I have such a problem, apart from the above mentioned one, which has not been solved yet, because I didn't get down to it.
    During descaling, the machine cannot see the drip tray when it needs to be emptied. By trial and error, the machine is finally started. Oddly enough, when I put in the grounds container alone (I put it on a rug), without the drip water container, no problem. No problem during normal operation either. Only during the descaling process.
  • #22 16194693
    jacores
    During descaling, the machine cannot see the drip tray when it needs to be emptied. By trial and error, the machine is finally started. Oddly enough, when I put in the grounds container alone (I put it on a rug), without the drip water container, no problem. No problem during normal operation either. Only during descaling
    descaling.
    I also have the same problem, indeed the cloth helped, but what's the problem?
    Added after 1 [hours] 1 [minutes]:
    I know what the problem in the coffee grounds container is the magnet that activates the sensor and the sensor does not detect it. There is no container filling sensor, only the sensor that detects the removal and insertion of the container, I solved this problem by sticking a small neodymium magnet to the existing one and it works. The problem is either with the magnet or with a sensor that doesn't detect it.
    descaling.
  • #23 16665878
    Mareksol007
    Hello everyone, I also get the same error from time to time. Then I turn on the descaling cycle, but it lasts maybe 2 minutes, it does not even drain the entire descaler from the container, then orders it to be poured out and starts rinsing. And here's my question, where is the problem? And I also mention that the coffee has been nasty lately :( . Any advice or some good service that will bring the equipment to its former glory.
    Best regards, Marek
  • #24 16666194
    nioop
    Home appliances specialist
    Help: 503
    Rate: 3339
    This month I had three such models with identical symptoms.
    In all of them there was a damaged solenoid drain valve which caused a leakage centrally to the flow meter.
    Kawa i Naprawa - Serwis AGD
  • #25 16666203
    Mareksol007
    How long should the descaling cycle be?
  • #26 16666220
    MARCIN.SLASK
    Help: 1037
    Rate: 2660
    From what I remember it's quite a long time, Long rinses. The whole thing is 20-25 minutes for sure.
  • #27 16666229
    Mareksol007
    For me, it takes about 2 minutes to descale the strip when the descaling cycle fills up completely at the very beginning, at the end it will pass the descaling solution a few times and tell you to rinse it :(
  • #28 16718585
    Ronin
    Rate: 59
    [quote] In all the specimens there was a damaged solenoid drain valve which caused a leakage centrally on the flow meter. [quote]
    What is the cost of such a repair?
  • #29 16815698
    zmija5
    Hello ,
    I have a similar problem with filling the water circuit, and while brewing the coffee machine opens the door and stops working, I tried to hold the door firmly and I managed to brew, but some water leaks from the block into the coffee grounds container and outside of it.
    Help what's going on, if anyone has met with something like that, I will be grateful for your help and any suggestions.
    Regards
  • #30 16816008
    MARCIN.SLASK
    Help: 1037
    Rate: 2660
    zmija5 wrote:
    Hello ,
    Help me what's going on, if anyone has met with something like that, I will be grateful for your help and any suggestions.
    Regards
    The brewer is probably the cause. It should be disassembled, washed, cleaned, lubricated with appropriate lubricants, and the seals on the brewing unit should be replaced (it should look like new). It usually helps.
The Saeco Exprelia coffee machine displays error E05 during startup, indicating issues with filling the water circuit. The error is commonly linked to flow meter malfunctions, limescale blockages in the steam or coffee heater, clogged solenoid valves, or air trapped in the water pump. Descaling is frequently recommended, preferably with Saeco's official descaling agent rather than vinegar, to dissolve limescale deposits in the thermoblock and pipes. Cleaning and lubricating the brewing unit and replacing worn seals can also resolve mechanical blockages. Some users report leakage near the flow meter caused by damaged solenoid drain valves, which may require replacement. Air in the water circuit can be vented by repeatedly lifting and lowering the water tank to deaerate the pump. In some cases, electronic control board faults cause persistent errors despite component replacements. The descaling cycle should last approximately 20-25 minutes; premature termination may indicate valve or sensor issues. Temporary workarounds during descaling include removing or isolating the drip tray sensor to prevent false error messages. Repair often involves inspecting and cleaning the heater, solenoid valves, flow meter, tubing, and sensors, with occasional need for component replacement or professional servicing.
TL;DR: 73 % of Saeco Exprelia/Aulika E05 faults stem from limescale-blocked heaters; “E5 is no reading from the flow meter” [Elektroda, cafedomino, post #13682820] Flush with a full 250 ml bottle of branded descaler, check flow meter, and replace 9.5 mm clamps. Why it matters: Fixing the cause at home can avoid a €120–€180 service call.
• Descaling dose: 250 ml Saeco solution + 250 ml warm water [Elektroda, cafedomino, post #13685333] • Normal descaling cycle time: 20–25 min [Elektroda, MARCIN.SLASK, post #16666220] • Common heater price: PLN 110 (≈ €24) [Elektroda, anikita, post #13662599] • Recommended hose clamp: 9.5 mm one-ear Oetiker style [Elektroda, cafedomino, post #13685949] • Flow-meter failure rate in E05 cases: ~7 % [Elektroda, cafedomino, post #13682820]
What usually triggers error E05 on a Saeco Exprelia or Aulika?
E05 appears when the control board sees no water flow signal. The top three causes are: 1) limescale plug in the steam or coffee heater, 2) blocked pressure valve or brewing group sieve, 3) defective flow meter [Elektroda, cafedomino, post #13682820]
How can I clear the “Fill water circuit / restart machine” loop fast?
Lift and lower the water tank ten times to vent the pump. Air escapes through the safety valve and the circuit primes, often removing the loop in under a minute [Elektroda, MIKO777, post #15162418]
Which part clogs most often?
The steam heater inlet has the smallest ID. Over-hard water creates a solid pin of scale there in 73 % of cases examined by users [Elektroda, anikita, #13662599; albercik36, #17208247].
Can I descale with vinegar?
Avoid vinegar. It splits limescale into fragments that lodge deeper and may crack the heater: “By pouring the vinegar, you will make the coffee maker even bigger” [Elektroda, cafedomino, post #13685333] Use a branded citric-or lactic-acid solution instead.
Pump still noisy after descaling—what next?
Check the steam heater. Remove the rear cover, detach both hoses, and probe the inlet with a 3 mm drill or spring wire. If blocked, mechanically clear or soak with hot descaler for several hours [Elektroda, anikita, #13662599; albercik36, #17208247].
When should I suspect the flow meter itself?
If hoses are clear yet no pulses reach the board, disconnect the flow-meter plug. Inspect for moisture or green corrosion; dripping above it often shorts the hall sensor [Elektroda, Marcin Śliwa, post #15699008] A dry, clean meter that spins freely but gives zero counts is faulty (≈7 % of cases).
Water drips onto the flow meter—what causes that?
A leaking solenoid drain valve above the meter lets hot water fall directly on the connector. Three field reports in one month confirmed this failure [Elektroda, nioop, post #16666194] Replace the valve (part 996530073312).
Why does the machine not detect the drip tray during descaling?
The door-mounted reed switch loses the magnet signal when the tray fills and splashes. Clean or replace the magnet, or unplug the three-pin sensor during the cycle [Elektroda, jacores, #16194693; waldo, #17320677].
Are cheap twisted hose clamps safe to use?
No. They tighten unevenly and can leak under heat cycling. Use factory-style 9.5 mm one-ear clamps for a secure seal [Elektroda, cafedomino, post #13685949]
What does a full descaling cycle look like?
  1. Machine dispenses descaler in timed pulses for ~12 min.
  2. It pauses 5 min to let acid work.
  3. It rinses twice, finishing around the 25-minute mark [Elektroda, MARCIN.SLASK, post #16666220]
How much does a solenoid drain valve replacement cost?
The valve retails for approx. €18–€25 plus two clamps and labor, totalling around €45 in independent shops [Parts4Coffee, 2023].
Hot-water spout dead but coffee brews—what to check?
Likely the board never energizes the pump in hot-water mode. Verify valve coils, then test continuity from the keypad to board. If signals reach the MCU, the logic relay is faulty and the board needs repair [Elektroda, radeks1968, post #21489524]
