Identifying Your Engine Type: Comprehensive Guide to Distinguish Between 2t and 4t Engines
catryk 46869 13
How can I tell whether my engine is a 2-stroke or a 4-stroke?
You can identify it by the cylinder head: a 4-stroke has valves, while a 2-stroke does not [#13246418] Another quick check is lubrication: a 2-stroke usually uses oil mixed with fuel, while a 4-stroke has engine oil filled into the crankcase, not into the fuel tank [#13246443][#13251569] If you remove the exhaust pipe, a 2-stroke piston will show ports/windows, while in a 4-stroke you won’t see the piston that way because it sits behind the exhaust valve [#13248362] You can also test compression by turning the engine with the spark plug out and a finger over the hole: compression every revolution points to 2-stroke, and compression every two revolutions points to 4-stroke [#13249942] Smoke when cold is not a reliable identifier by itself [#13246563][#13246692]
  • #1 13246395
    catryk
    Rate: 11
    Hello, I know that such a post has surely been somewhere, but I can't find it, and it is a much-needed information for me on how to check what engine we have. If someone could explain to me how to check it I would be very grateful.
  • #2 13246418
    Blicek
    Help: 82
    Rate: 217
    Is this some kind of joke?
    Head with valves 4T
    Head without valves 2T
    You do not need to be a specialist to distinguish by the gang of the engine work....
  • #3 13246431
    catryk
    Rate: 11
    Of course ze need not, but I did not see so I decided to go to the forum and ask, because I think that's what this forum was created for. Thanks a lot for your help.
  • #4 13246443
    Rowik
    Rate: 20
    in 2t engines you pour oil into the fuel, in 4t-oil directly into the engine ( I don't mean the cylinder ;) ) in a different way also looks ,,top,,it's probably the easiest to recognize ( leaving aside the work, sound and visual construction )
  • #5 13246563
  • #6 13246625
    catryk
    Rate: 11
    then since I have an oil fill hole in the engine, and if I pour pure 98 gasoline at the station it means it's a 4 stroke? And as for the smoke that flies when the engine is cold, I also have it, but isn't it some kind of defect?
  • #7 13246692
    budiet
    Help: 25
    Rate: 92
    Every engine smokes, especially when it's cold
    Maybe you have a lower-valve engine like in older mowers;)
  • #8 13246782
  • #9 13248362
  • #10 13249304
    Inkwizycja
    Level 30  
    Help: 165
    Rate: 416
    Rowik in new scooters with 2T engines separately pour and fuel and oil (dispenser) so this is not an indicator of engine type.
  • #11 13249942
    budiet
    Help: 25
    Rate: 92
    The best way to do this is to unscrew the plug, plug the hole with your finger and rotate the engine shaft.
    If compression occurs every other stroke (that is, every one revolution of the shaft) then you have 2 strokes.
    If compression is every 4 strokes (that is, every 2 revolutions of the shaft) then you have 4 strokes.
  • Identifying 2T and 4T engines by oiling systems
    #12 13251569
    Rowik
    Rate: 20
    I know that in new scooters you pour separately, but you do not pour this oil directly into the engine to lubricate the crankshaft and everything else, but into another separate reservoir, from which, with the help of an oil pump, the engine dispenses fuel-oil ratio by itself....
    If you pour normal oil into the engine - such as motul 10w40, and at the station you pour pure gasoline, then you have a 4 stroke.
    If you pour oil such as motul 2t into a tank somewhere next to the fuel tank (if it is, for example, a scooter, or other wonder), then you have 2T.... there is no need to pursue this topic further :) .
  • #13 13252083
    kwok
    Level 40  
    Help: 496
    Rate: 1342
    I was repairing a petrol cutter (replacing the crankcase) and what was my surprise that the 4-stroke was running on mixture. I think it was a Husqwarna.
  • #14 13252315
    kryststgpom
    Help: 78
    Rate: 381
    kwok wrote:
    I was repairing a petrol scythe (replacing the crankcase) and what was my surprise that the 4-stroke runs on a mixture. I think it was a Husqwarna.
    Stihl has a 4-mix that also runs on a mixture.
    Link .
The discussion focuses on identifying the type of engine—two-stroke (2T) or four-stroke (4T). Key distinguishing features include the presence of valves (4T has valves, while 2T does not), the method of oil application (2T requires oil mixed with fuel, while 4T has oil added directly to the engine), and the engine's smoking behavior when cold. Users suggest practical methods for identification, such as checking for compression during engine rotation and examining the piston design. Some users mention specific brands and models that may operate differently, such as Husqvarna and Stihl, which have unique fuel and oil requirements.
