Removing Stuck Foil from Fellowes Saturn A4 Laminator Drum: User Inquiry
tomek89.8989 42000 2
  • #1 13424254
    tomek89.8989
    I have a big problem during lamination, I got the foil and it turned all over on this drum I have no idea how to get out now, I don't know how to unscrew it because there are only 3 screws by the handle and nothing else I tried to open it somehow but it doesn't work .
    Please help, unfortunately this is not my laminator :(
  • #2 13437606
    siwusek
    Help: 6
    Rate: 203
    Unscrew the casing and get to the drum, cut the foil on the drum along the length and tear it off. Fold the laminator and fasten the white sheet several times to remove the glue residue.
    If you can't, give it to the service at least you won't have to buy a laminator.
  • #3 17479226
    grzegor4
    Rate: 28
    I did the same thing too. It turned out that there are 4 screws hidden under the rubber feet. Just pull them out, we have access to the screws.
