LIDL Solar Mole Repellent: Weakening Sound Waves Due to Low Temperature - Comparisons & Reasons
erazm 23 13122 9
Why does a solar mole repeller’s buzzer become much weaker after a few minutes in cold ground or in a cold room?
The most likely cause is poor-quality construction or a defective unit, because a device meant for outdoor winter use should not lose so much output at low temperature [#13486266] One reply notes that if the buzzer were a small motor with an eccentric weight, thickened grease in the cold could slow it down, but another identifies the unit as an electronic generator with a piezo transducer, which makes a mechanical-grease explanation less likely [#13480496][#13480610] A weak or low-quality battery was also suggested as a possible cause, though the discussion leaned away from the batteries being the main problem because they are warmed at the surface in the solar sphere [#13480496][#13480526] In short, the thread’s best answer is that the repeller itself is probably badly made or faulty rather than properly winter-rated [#13486266]
  • Cold temperature causes buzzer output to weaken 40–50%
    #1 13480399
    erazm 23
    On March 27, in the LIDL shop, I bought a solar scarecrow.
    After switching on the repeller, the buzzer in the device started to emit sound waves (batteries charged). After depositing it in the ground (temperature in the 5 ° - 7 ° hole) after 2 - 3 minutes, the sound of the signal drops by 40 - 50% and is almost inaudible. After removing the repellent from the ground and waiting for a few minutes the device emits the proper sound waves again (when the temperature in the buzzer will increase). The instructions show that the device can also be used in the winter, that is at low temperatures of the earth (they state "the solar collector was not soiled and covered in winter with snow or ice"). When the repeller is standing in a cold room (gazebo) overnight it is the same.
    The reduction of the emitted signal due to the low temperature in the hole does not occur in other solar mole repellent products that I have (other companies).
    Please explain the reasons for the weakening of the signal.
    It's his picture
  • #2 13480496
    Futrzaczek
    Help: 538
    Rate: 522
    Poor quality battery, just what if it is placed in the handle.
    Or, if the buzzer has the form of a motor with a weight on the shaft, the grease thickens in it enough that it can not spin.
    F-TECH Michał Kurzela
    Zacisze 20B, Serock, 05-140 | Company Website: https://elektronika.top/
  • #3 13480526
    erazm 23
    Rather, it's not the fault of 2 batteries because they are on the surface - in this round sphere, which as the sun shines is warm. How does the buzzer work - the sound wave signaling device I do not know.
  • #4 13480610
    jacekko63
    Help: 140
    Rate: 320
    Electronic generator plus piezo transducer.
  • #5 13482002
    erazm 23
    Ok. And what is the reason that at low temperature emitted sound waves are weakening. I would like to know if this is a defect of this device. Tomorrow, I made an appointment to return him to the store.
  • #6 13483925
    erazm 23
    Is it a repeller's fault that the sound signal emitted becomes weak due to low temperature ??
  • #7 13486266
    Futrzaczek
    Help: 538
    Rate: 522
    Rather yes - it is a device designed to work in weather conditions, where such temperatures are not uncommon. If it starts to work worse, it means that there is either a copy or the entire project.
  • #8 13486698
    kybernetes
    Help: 426
    Rate: 1489
    Or maybe he was designed to work on the fields near Canton and a dishonest or incompetent importer chose such because they were the cheapest?
  • #9 13492386
    erazm 23
    I returned this "scrap" to the store. Or maybe someone will provide information on the solar mole repellent in which you can replace the batteries, has a sound signal switch and in addition to the sound waves emitted there are also vibrations of the arrowhead.
  • Firecrackers and smoke proved effective in mole tunnels
    #10 14015470
    pawol
    Help: 18
    Rate: 130
    I have found that buzzers in the deterrents have a technology sticker on themselves with the word "take off after washing" in English. This shows only the low level of companies assembling it to the pile. It barely moaned.
    But to the point ... I fought with the mole for a month:
    1. tube sockets fi 50 and fi 75 - without effect
    2. burying the contents of the cat litter box - to no avail
    3. Chatting with a shovel - no effect
    It helped wunder waffe in the form of firecrackers popularly called "achtungi"
    I have cleared the holes of the mounds. Achtung inside and covered with a lid from the barrel to increase the sound pressure in the tunnels :) As it slipped smoke in the hole for 15 minutes was like in a boiler room. I repeated the maneuver in three holes.
    Crete is gone. It must have stunned him completely until he fell.
    And I warn you that fighting a mole in a fenced area is legal.
    It is a waste of time for patentsors from the net
The discussion revolves around a solar mole repellent purchased from LIDL, which exhibits a significant reduction in sound wave emission when placed in cold ground (5 °C - 7 °C). Users speculate that the issue may stem from poor battery quality or the design of the buzzer mechanism, which may not function effectively at low temperatures. Some participants suggest that the device is not suitable for colder climates, indicating a potential defect or design flaw. Alternatives to the LIDL product are sought, including models that allow for battery replacement and feature additional vibration mechanisms. One user shares their unsuccessful attempts to deter moles using various methods, ultimately resorting to firecrackers as a more effective solution.
