[Solved] How to hide the motion sensor in aluminium outdoor lights?
Jobi000 1776 7
  • #1 18084538
    Jobi000
    Rate: 12
    Welcome,
    I have aluminium and Glass tube luminaires outside. Such typical tubes.
    I don't want to install a standard motion sensor, but to hide "something" in the fixtures.
    And here's the problem. A PIR motion sensor bulb would not work.
    I read about microwaves, but once they write that they pdze through something, other times that they don't. One electrician recommended a microwave sensor for aluminium, but it's mostly written on the internet that it won't work....
    Do you have any experience? Help please, as I am completely unfamiliar with it....
    Thank you in advance 😀
    jdubowski
    Tube devices specialist
    Help: 2511
    Rate: 2804
    Jobi000 wrote:
    I have aluminium and Glass lamp fittings outside. Such typical tubes.
    Photo?
    Jobi000 wrote:
    And here's the problem. The PIR motion sensor bulb did not work.
    And which PIR sensor did you use?
    For detecting aluminium yes, but concealed in an aluminium housing it will not work.
    Jobi000 wrote:
    Do you have any experience? Help please, as I am completely unfamiliar with this....
    Nothing will work through the metal part of the fixture, microwaves will work through the glass part, infrared not so much anymore.
  • #3 18084677
    wacek.wacek
    Help: 98
    Rate: 284
    Microwaves pass through the aluminium screen? On drywall you can throw it, but in sheet metal I somehow doubt it. A miniature PIR sensor and a hole to shoot through. Let's see what these lamps look like.
  • #4 18085956
    Jobi000
    Rate: 12
    the lamp looks like this:
    How to hide the motion sensor in aluminium outdoor lights? .
    However, the bulb and sensor are:
    RICU LED and motion sensor lamp, 120°, OR-SW-7001LR3 Orno
    I would prefer not to drill if the microwave sensor would pass through this glass.
    Added after 1 [minute]:
    jdubowski wrote:
    Photo?
    Light with LEDs and RICU LED motion sensor, 120°, OR-SW-7001LR3 Orno:
    Nothing will work through the metal part of the fitting, through the glass part microwaves will work, infrared not so much.
    Added after 59 [seconds]:
    wacek.wacek wrote:
    Microwaves pass through aluminium screen? On drywall you can throw but in sheet metal I somehow doubt it. A miniature PIR sensor and a hole to shoot through. Show how these lamps look.
    How to hide the motion sensor in aluminium outdoor lights? How to hide the motion sensor in aluminium outdoor lights? .
    Added after 4 [hours] 35 [minutes]: .
    How about putting this microwave inside the lamp , such as this one:
    would its detection range only change to the "pole" of the glass radius at the bottom, or would the microwaves somehow propagate sideways "under the glass"?
    I know this is an amateurish question, but I'm completely unfamiliar with it.... :)
  • #5 18088718
    wexors
    Level 19  
    Help: 22
    Rate: 40
    According to physics, a microwave wave should diffract and spread a little to the side, but to be honest I don't know :D
    xury
    Automation specialist
    Help: 878
    Rate: 1498
    In my opinion there will be no problems with propagation. I have (or rather had, because I converted) an led plafond with a microwave sensor. Unfortunately it was detecting movement through two walls of 24 centimetre supraconcrete. I tried covering the sensor with sheet metal and it didn't do anything. I ended up converting to continuous power.
  • #7 18097102
    Jobi000
    Rate: 12
    wexors wrote:
    according to what physics says the microwave wave should diffract and spread a little to the side but honestly I don't know in physics I was weak :D
    Well me too... now I see that unfortunately...
  • #8 19428650
    Jobi000
    Rate: 12
    I found micro sensor bulbs
The discussion revolves around the challenge of concealing a motion sensor within aluminium outdoor lights. The user seeks alternatives to standard PIR sensors, which are ineffective when hidden in metal fixtures. Responses indicate that while microwave sensors can potentially work through glass, their effectiveness through aluminium is debated. Some participants suggest that microwaves can diffract and spread, allowing for detection even when placed inside the lamp. However, practical experiences shared indicate that microwaves can penetrate various materials, including concrete, but may not perform reliably in all scenarios. The user expresses a preference for solutions that do not involve drilling into the fixtures.
