Renault Laguna 1 '95 2.0 16V: SERV Light & Emergency Mode in Intelligent Automatic Gearbox
bastura123 51966 7
  • Intermittent SERV fault triggers automatic gearbox limp mode
    #1 13558547
    bastura123
    Help: 7
    Rate: 34
    Hello, I have a little problem with my Lagoon I, because sometimes the SERV light comes on, it does not cause much of a problem for me because there are no lights other than it, but my Renault is equipped with "intelligent automatic gearbox" and after turning on this indicators, the car goes into emergency mode and does not change gears as it should, it works in low gears, which requires higher engine revolutions while driving. This morning, after starting the car, the light came on, after taking about 25 km, I returned home, opened the hood and "fumbled" in the box marked (attachment), because this light came on while driving, but it went out after restarting the engine, but SERV was on fire still. After my treatments, after returning SERV, it went out, but these lights do not always flash together, what could be the reason?
  • #2 13558642
    domex32
    Help: 585
    Rate: 2451
    What errors are reported by the engine controller?
  • #3 13558670
    bastura123
    Help: 7
    Rate: 34
    after starting the engine, my dashboard looks as follows, as you can see, the SERV went out, but sometimes it appears at the least expected moment.
  • #4 13559190
    domex32
    Help: 585
    Rate: 2451
    I meant computer diagnostics.
  • #5 13559344
    bastura123
    Help: 7
    Rate: 34
    I cannot find the plug for connecting the diagnostic device, I know that theoretically it should be under the steering column, but I cannot locate it.
  • #7 13559385
    bastura123
    Help: 7
    Rate: 34
    Przemo9826 wrote:
    Google does not hurt ...
    all in all yes, excuse me, I forgot to ask "uncle" about all this.
    Only now I have to find someone with a computer, the only problem is that the light comes on once in a while and when I go to the mechanic and the light goes out, the computer may not show me anything ...
  • #8 13559634
    domex32
    Help: 585
    Rate: 2451
    He will remember the error. Do not disconnect the battery.
The discussion revolves around a Renault Laguna 1 (1995) experiencing intermittent activation of the SERV light, which triggers the vehicle's intelligent automatic gearbox to enter emergency mode, limiting gear changes and resulting in higher engine RPMs. The user notes that the SERV light sometimes turns off after restarting the engine, but it can reappear unexpectedly. Participants suggest checking for error codes via computer diagnostics, although the user struggles to locate the diagnostic plug, believed to be under the steering column. There is a recommendation to avoid disconnecting the battery to retain error memory for diagnostics.
