Review & Feedback: Home Switchgear Design, 32A Fuse, TN-C System, Electrical Switchboard Diagram
piotrekk8403 123810 12
Can you review my home switchboard diagram for a TN-C supply with a 32A fuse and meter protection?
The diagram cannot be approved as it stands; the project was judged invalid, and a proper assessment of the whole installation is needed before any correction can be made [#13653963] Bathroom lighting should be protected by an RCD according to the regulations [#13653699] The proposed 4-pole surge arrester also needs justification, because the PEN section sits next to N and PE and the manufacturer’s recommendation should be checked instead of assuming that arrangement is correct [#13653817][#13653707] The appearance of the drawing alone does not prove that the shown strip is really a PE strip [#13653707]
  • #1 13653622
    piotrekk8403
    Rate: 17
    Hello everyone, I am preparing a diagram of an electrical switchboard in my home. I would ask you to check and understand because I am not a specialist in the subject of home installation.
    ZE wrote to me in conditions; counter protection, fuse type 32A,
    The low voltage network operates in the TN-C system
  • #2 13653634
    elpapiotr
    Electrician specialist
    Help: 1015
    Rate: 3530
    What, what is this contraption for?
    And what is this mysterious PE-N ?
  • #3 13653686
    Darom
    Help: 231
    Rate: 588
    What about bathroom lighting - which circuit is it?
    Why a 4-way surge arrester?
    kisses
    - GIFT-
  • #4 13653699
    Adam_Bandit
    Help: 24
    Rate: 59
    It looks like a PE strip.
    Friend Gifts rightly drew attention to the bathroom lighting circuit, according to the regulations, it should be protected with an RCD.
  • #5 13653707
    elpapiotr
    Help: 1015
    Rate: 3530
    The appearance does not prove anything, despite the fact that we have a 4-wire power supply.
  • #6 13653714
    Adam_Bandit
    Help: 24
    Rate: 59
    I would also make these sockets from the garage and the boiler room on a separate RCD, because something "crashes" is half of the sockets in the house without power supply.
  • #7 13653725
    jann111
    Help: 180
    Rate: 507
    At the PEN chapter, the old "good" school of Boczkowski. :D
    Errors similar as in most of the topics from the series "My first switchboard". It is a pity that the next such topic does not start with a review "similar topics" .
  • #8 13653746
    piotrekk8403
    Rate: 17
    this "contraption" I forgot to remove when I was doing the amendment
    he plans to use 12v lighting in the bathroom, it will probably be a transformer, and if not, another differential and b10
    according to the recommendations of the manufacturer of the limiter, I should use 4, unless you recommend another solution, including I note that I do not have a lightning protection system and the house connection is a cable in the ground, therefore type c
  • #9 13653817
    elpapiotr
    Help: 1015
    Rate: 3530
    The manufacturer recommends a 4-pole surge arrester in this proximity to N and PE? You have a PEN section right next to them, so ... why?
    Maybe we will look at these recommendations?
  • #10 13653826
    piotrekk8403
    Rate: 17
    jann111 I read a few topics from the series "My first switchboard" and there are very few specific answers, most of them are of the type "you don't know what to do, don't do it".
    in my opinion, this forum is there to help yourself. that's why I am asking for help.
    regarding the additional RCD, I have already drawn it right suggestion
  • #11 13653840
    elpapiotr
    Help: 1015
    Rate: 3530
    Exactly. You don't know what to do then don't :D
  • #12 13653842
    piotrekk8403
    Rate: 17
    elpapiotr I'm sorry, you are right, that is, use 3 halves
  • #13 13653963
    Akrzy74
    Rest in Peace
    Help: 363
    Rate: 1504
    piotrekk8403 wrote:
    I would like to have a check and understanding because I am not a specialist in the subject of home installation.
    "Project" checked - invalid.
    The forum is to help each other, preferably in such a way as to accurately answer the author's question, taking into account his knowledge in a given topic and the safety of himself and his environment. I remind you that a friend wrote:
    - checking does not consist in correcting errors, but in assessing - which in this case is negative.
    It is not only about the switchgear diagram, but also the entire installation, and a rational decision can only be made when you have a sufficient amount of information.
    I close.
The discussion revolves around the design of a home electrical switchboard, specifically focusing on a 32A fuse and the TN-C system. The original poster seeks feedback on their diagram, which includes a PE-N configuration. Respondents raise concerns about the bathroom lighting circuit, suggesting it should be protected by an RCD due to safety regulations. There are discussions about the necessity of a 4-pole surge arrester and the implications of having a PEN section nearby. Recommendations include using separate RCDs for specific circuits to prevent widespread power loss. The overall consensus emphasizes the importance of safety and proper installation practices in home electrical systems.
