Beginner's Electrical Switchgear Diagram for Single-Family House: YKY5x16, TN-S System, RCDs
viruz997 12489 19
How should I correct the switchboard diagram for a single-family house with a TN-S supply, and do I need separate RCDs for laundry, kitchen, and bathroom circuits?
The diagram is not correct as shown: the neutral conductors from different RCDs must not be joined on one N bus, and each RCD must have its own separate neutral circuit; otherwise it will not work [#16449733] Lighting and socket circuits should not be mixed on one RCD, and the overall circuit layout needs to be split up more properly, including separate circuits for higher-power loads above 2 kW [#16457041][#16456840] Separate RCDs for all laundry/kitchen/bathroom circuits are not presented as mandatory here; one reply suggests RCDs are needed only for some lighting circuits, such as bathroom, facade/garden, and laundry lighting, together with breakers [#16456686][#16456713] The thread also warns that your fault-finding method is unreliable, because switching breakers on and off after an RCD trip may just cause the RCD to trip again, so it will not clearly identify the faulty receiver [#16450361] On the TN-S point, one reply notes that a 5×16 feeder with PEN separation at the measuring connector does not automatically make the house supply TN-S [#16449944]
  • Reviewing TN-S switchboard design and separate RCD requirements
    #1 16449409
    viruz997
    Rate: 28
    As a beginner, I'd like to make sure I have drawn the electrical switchgear diagram correctly. The switchgear is intended for a single-family house. There is 35mb from the measuring connector to the switchboard - YKY5x16 - TN-S network system.
    Is the switchboard well designed, what should be changed?
    Is the use of additional-separate residual current devices for laundry / kitchen / bathroom circuits necessary? In the event that the switch trips, I am able to diagnose overcurrent switches where the leakage current is.
    • Miłowonki 2 - Instalacje Model (1).pdf (47.33 KB) You must be logged in to download this attachment.
  • #2 16449450
    zbich70
    Help: 1171
    Rate: 6668
    viruz997 wrote:
    electrical switchgear scheme. Switchgear designed for
    Is it a switchgear or a switchgear after all?
    viruz997 wrote:
    did I draw the diagram of the electrical switchboard correctly?
    Colleague "designer" heard about single-line diagrams?
    Please enter how you will diagnose it.
  • RCD fault isolation by sequentially restoring circuit breakers
    #3 16449521
    viruz997
    Rate: 28
    Editing posts in this specific forum requires the approval of a moderator so by then your colleague will have to look at these two names, later I will change to a switchboard.
    Please indicate the place where I wrote that I am a designer? The word designed does not mean that you are a designer!
    Yes, I have heard about single-line, but the posted multi-line diagram (which is perhaps less readable) shows exactly the same so I do not understand where the problem is.
    As for residual current devices in one case, the situation may be as follows:
    The earth leakage circuit breaker has tripped - I turn off all off overcurrent - I turn on the RCD - turn on the circuit breakers responsible for individual circuits in turn - then find the faulty device.
  • #4 16449559
    zbich70
    Help: 1171
    Rate: 6668
    viruz997 wrote:
    As for residual current devices, in one case the situation may be as follows
    It's good that a colleague wrote in one case .
    And what about the others?
    Example. Doziaia N. What are you doing? Do you still have eski?
  • #6 16449691
    opornik7
    Electrician specialist
    Help: 316
    Rate: 1569
    Installation 100% so made will not be technically efficient and will not work. Too many cardinal errors.
  • #7 16449733
  • #8 16449859
    mawerix123
    Help: 482
    Rate: 951
    viruz997 wrote:
    TN-S network layout
    For sure :?: Not TN-C with a chapter on TN-CS :?:
  • #9 16449917
    opornik7
    Help: 316
    Rate: 1569
    viruz997 wrote:
    From the measuring connector to the switchboard at home there is 35mb - YKY5x16 - TN-S network system.
  • Questioning the claimed TN-S system and PEN separation
    #10 16449944
    mawerix123
    Help: 482
    Rate: 951
    opornik7 wrote:
    There may be 5x16 from the connector and there is probably a classically incorrect PEN separation in it, but this does not create a power supply for the house in the TN-S network .... And as for the connector comes 5x cable to the recipients .... about TN-S :?:
  • #11 16450125
    kortyleski
    Help: 957
    Rate: 3860
    Diagram as much as possible could be read wrong. With RCD you will be able to bet which and when will disconnect.
  • #12 16450312
    kozi966
    Help: 599
    Rate: 1288
    First of all, none of them will want to join.
  • Sequentially isolating circuits to locate RCD faults
    #13 16450361
    retrofood
    Help: 1140
    Rate: 4798
    I guarantee you that switching on any redundant protection will cause an RCD reaction. I wonder how you will then determine the faulty receiver and its location.
  • #14 16456520
    viruz997
    Rate: 28
    The diagram sent was not legible and it was mainly about the arrangement of the apparatus and then the selection of the size of the switchgear.
    Four leads are connected to the measuring connector and the PEN is separated there. As I mentioned, a 5x16 cable goes to the switchgear in the house. The idea for the drawing of the diagram was born at the time of the proposal of 2 electrical companies invited (read 1 max 3 3f residual current switches, then two overcurrent switches for lighting ground floor / first floor, and several for 230V sockets, 1 overcurrent switch 3f, switch aggregate network - that's all Of course without no documentation after the implementation. I am not saying that it was badly planned by them, but once in school I remember it a little differently everything was presented and watching the newly made installations a little different from the proposals of the above mentioned professionals. Using the links given above as far as my reasoning has improved my diagram I am asking for further tips .... I am adamant in pursuing my goal :)
    • Schemat Rozdzielnicy Model (2).pdf (151.63 KB) You must be logged in to download this attachment.
  • #15 16456566
    elpapiotr
    Help: 1015
    Rate: 3532
    Your inflexibility is admirable, but when RCD number 1 works, I can see the darkness in the whole house. Probably because the rest of the diagram was not shown.
    PS. Why a 2.5 mm? wire for the lighting circuit?
  • #16 16456625
    viruz997
    Rate: 28
    So you will be so kind and tell us where the problem lies in the diagram and show its solution? Because I have already lost ideas (rcd connection - Phase and N from the main bus, second pair of terminals - N from the circuits, phase through the overcurrent?) Or maybe it is about socket and lighting circuits on one rcd switch? Or maybe wrong symbols at lighting circuits. The lighting cable is 1.5 - a printing error.
  • #17 16456686
    elpapiotr
    Help: 1015
    Rate: 3532
    I kindly suggest and advise that only some lighting circuits require the use of RCDs, together with circuit breakers.
  • #18 16456713
    viruz997
    Rate: 28
    If you reason well you are talking about lighting circuits for the bathroom, lighting on the facade / garden, laundry. And the other lighting circuits only with overcurrent switches ..
  • #19 16456840
    Łukasz-O
    Admin of electroenergetics
    Help: 654
    Rate: 4292
    Apart from other issues, completely incorrect circuit layout.
    That much is written on the forum about separate circuits for devices above 2kW, and here on the diagram one big mix.
  • #20 16457041
    opornik7
    Help: 316
    Rate: 1569
    Lighting and sockets on one RCD - error. Darkness will come after it has acted. Paweł wrote about it in post # 15.
    What fungus protects the stops?
    Why T2 Enough? How is the building powered?
    Nonsense that professionals fight. As you can see without success.
    You don't write anything at all about protection from paralysis. What about GSU? What about expansion joints? What about earth electrode?
    We write, we write and home contractors do not know what we are writing about :D
    Buddy viruz997, read with understanding what we wrote. Compare this with the norms and other legal acts and return with ....... the correct installation scheme.
The discussion revolves around the design and correctness of an electrical switchgear diagram for a single-family house, specifically using a YKY5x16 cable in a TN-S system. Participants critique the diagram's clarity and technical accuracy, highlighting issues such as incorrect circuit layouts, the necessity of separate residual current devices (RCDs) for specific circuits (like laundry, kitchen, and bathroom), and the importance of proper PEN separation. Concerns are raised about the potential for tripping RCDs affecting multiple circuits and the need for distinct circuits for high-power devices. The conversation emphasizes the importance of adhering to electrical standards and best practices in residential installations.
