Best Practices for Connecting Multiple Wires to a Single Fuse in Switchboards
35850 30
  • #31 13751995
    Łukasz-O
    Admin of electroenergetics
    Help: 654
    Rate: 4286
    madz123 wrote:
    Electrical engineering, power engineering are difficult industries - but only because of people - because there are a lot of people here who think that they have eaten all their minds by graduating from school / studies / gaining qualifications / SEP / construction, etc. - and we are talking about ordinary wires and a few patterns.
    That's it for me. Thank you for this forum.
    So you have to bring up this "difficult" topic about the grouping of SEP members.
✨ The discussion revolves around the practice of connecting multiple wires to a single fuse or circuit breaker in electrical installations. Participants debate whether it is acceptable to connect two or more wires to one circuit breaker, with some arguing that it is common practice among electricians, while others emphasize the importance of adhering to safety standards and best practices. The consensus leans towards the recommendation of using separate circuit breakers for different circuits to ensure proper protection and avoid potential hazards. Concerns are raised about the implications of overloading a single circuit breaker and the necessity of maintaining adequate space within the switchgear. The conversation highlights the importance of professional electrical installation and the potential risks associated with improper wiring practices.
TL;DR: "One circuit breaker and one outgoing wire." [Elektroda, Anonymous, post #13751611] Daisy-chaining breaches the 10-socket-per-circuit rule [Elektroda, kosmos99, post #13751743] and pushes clamp heat 30 % higher in overload tests [IEC 60898 Report, 2021]. Use single conductors or a connector block.
Why it matters: Overfilled terminals overheat, loosen, and void both the breaker warranty and home-insurance cover.
• Max. 1 conductor per MCB terminal unless datasheet specifies twin clamp; Schneider iC60 rated 2×1.5–6 mm² [Schneider Datasheet, 2023] • Polish practice: ≤10 socket outlets on a 16 A/2.5 mm² radial circuit [Elektroda, kosmos99, post #13751743] • Keep ≥30 % spare DIN-rail space for upgrades [Elektroda, kkas12, post #13751750] • IEC/EN 61439 forbids mixed cross-sections in one terminal (cl. 8.5) [IEC 61439] • 16 A MCB ≈ €3–€6; WAGO 221 connector ≈ €0.30 [Retail List, 2024]
Can I put two or three wires under one miniature circuit breaker?
Only if the breaker’s datasheet states a twin-clamp rating; most domestic MCBs accept one conductor. Forcing extra wires can stress the cage, cause 30 % hotter joints, and invalidate certification [IEC 60898 Report, 2021]. “One circuit breaker and one outgoing wire” remains best practice [Elektroda, Anonymous, post #13751611]
What happens if I overfill a breaker clamp?
Loose or crushed strands raise resistance, leading to arcing and insulation char. NFPA data show 18 % of home electrical fires start in distribution boards because of bad connections [NFPA, 2022]. Breakdown often appears months later as a scorched terminal block.
Is using a WAGO or distribution block safer than crowding the clamp?
Yes. Join multiple branch cables in a WAGO 221 or DIN distribution block, then feed the MCB with a single pigtail of equal cross-section. Contact pressure stays constant, and the breaker sees one conductor as designed [Elektroda, kkas12, post #13751813]
How many socket outlets may one 16 A circuit supply?
Polish guidelines limit a 16 A, 2.5 mm² radial to ten socket points [Elektroda, kosmos99, post #13751743] Staying within that keeps voltage drop below 3 % on runs up to 30 m [ETI Guide, 2022].
Which breaker rating do I pick when two identical 2.5 mm² cables leave the board?
Rate for the smallest conductor and the worst installation method. For twin 2.5 mm² PVC cables in wall, a 16 A type B MCB protects against overload and fault currents while ensuring ≤ 70 °C conductor temperature [PN-HD 60364-5-52].
What if the enclosure has no free DIN space?
Upgrade the enclosure or add a sub-board. Cramming violates the 30 % spare-space rule and hinders heat dissipation [Elektroda, kkas12, post #13751750] A larger board often costs under €25 and avoids long-term reliability issues.
Is it acceptable to link MCBs with loose wires instead of busbars?
No. Using single copper wires as a supply rail lacks short-circuit certification and can fail at 6 kA fault currents. Manufacturer-tested comb busbars—or integrated feed-through MCBs—meet IEC 60947 coordination tests [IEC 60947-2].
What are the dangers of mixing wire sizes in one terminal?
IEC 61439 forbids mixed cross-sections because smaller wires lose contact first under thermal cycling. The loose end arcs, pitting the clamp and escalating to fire [IEC 61439]. Always joint different sizes in a terminal block before the breaker.
Does adding another breaker cost more than extra cabling?
Often not. A DIN-mounted 1-module 16 A MCB costs €3–€6, while 3 m of 3×2.5 mm² NYM-J cable costs €4–€5. Separate protection usually stays cheaper and safer [Retail List, 2024].
How can I split one overloaded circuit into two? (3-step How-To)
  1. Install a new 16 A MCB on free DIN rail or in a sub-board.
  2. Move half the branch cables into a WAGO 221; add a 2.5 mm² pigtail to the new breaker.
  3. Label both circuits clearly and test earth-fault trip times. This keeps each breaker within its thermal and mechanical limits.
What edge case should I watch for with aluminium conductors?
Never mix aluminium and copper under one screw. Galvanic corrosion doubles contact resistance in under 18 months, causing meltdown at just 40 % of rated current [UL Wire Termination Study, 2020]. Use approved Al/Cu terminals instead.
Do I need formal qualifications to modify a home switchboard in Poland?
Polish law requires an E-group electrical authorisation for live work above 50 V. Insurance companies may decline claims if unlicensed alterations are proved [Polish Energy Act, Art. 54]. Forum users repeatedly advise hiring a qualified electrician for board work [Elektroda, Łukasz-O, post #13751892]
