Choosing the Right Cable Cross-Section for Kitchen Appliances: Fridge, Stove, Oven
malina998 64764 30
How should I choose the cable cross-section and circuit protection for kitchen sockets feeding a fridge, a gas-electric cooker, an electric oven, and other small appliances?
Split the kitchen loads into separate circuits instead of putting the fridge, oven, cooker and general sockets on one line; any receiver above about 2 kW should have its own circuit, and the socket circuits should also be protected by an RCD [#13991458] For an ordinary gas cooker with only electric ignition, a separate 3×2.5 mm² circuit with B16 protection was judged sufficient [#13991557][#13992798] For the oven, follow the manufacturer’s connection instructions and rated power rather than guessing from shop tables; the thread notes that many single-phase ovens are supplied for a normal 16 A socket, while higher-power versions need a dedicated supply [#13991416][#13991495] If you want room for future changes, one reply also suggested running a spare 5-core cable near the cooker [#13991771]
  • #31 14022141
    dariusz1209
    I don't know if I got it right, if not, please redirect my inquiry. Well, I have old fuses in my apartment, the so-called 10 A and 16 A automats, I would like to replace them with the so-called S, what model should I use? , only one, outside C 20, I have to understand that the one installed by the electrician is a single-phase fuse, can it be changed accordingly?
The discussion revolves around selecting the appropriate cable cross-section for kitchen appliances, specifically for a fridge-freezer, a gas-electric stove, and an electric oven. Participants debate between using 3x2.5mm² or 3x4mm² cables, with suggestions for separate circuits and appropriate protection (B16 fuses). Key points include the need for separate circuits for high-power devices (over 2kW), the importance of adhering to local electrical standards, and the necessity of using RCDs for safety. The consensus leans towards using larger cross-sections (3x4mm² or 5x2.5mm²) for higher power demands, especially for the stove and oven, while ensuring compatibility with socket terminals.
TL;DR: 3.6 kW (16 A at 230 V) is the safe ceiling for a 3 × 2.5 mm² circuit, and "a separate 3×2.5 mm² line on B16 is enough" [Łukasz-O, #13992798]. Split every ≥2 kW appliance onto its own breaker. Why it matters: right-sizing stops melted wires and mid-cook shutdowns.
• 3 × 2.5 mm² Cu + B16 A → up to 3.6 kW continuous [psilos1, #13991381] • Schuko plug/socket rated 16 A max; avoid loads over 3 kW [psilos1, #13991416] • 5-core 2.5 mm² feed keeps option for future induction hob [jack63, #13991771] • RCD protection ≤30 mA required on all kitchen socket circuits (PN-HD 60364-4-41)
What cable cross-section is enough for a domestic fridge?
A fridge rarely exceeds 300 W, so a standard socket on a 3 × 2.5 mm² circuit with a B16 breaker is more than adequate [malina998, #13991308].
Do gas hobs with electric ignition need a thick supply?
No. Ignition and oven lighting draw under 100 W. They can share a 3 × 1.5 mm² lighting/socket circuit, but most installers still use 3 × 2.5 mm² to keep wiring uniform [malina998, #13991557].
Which cable and breaker for a 3.0–3.6 kW built-in oven?
Use a dedicated 3 × 2.5 mm² copper cable protected by a B16 A breaker. This keeps current below the 16 A Schuko and conductor limits [Łukasz-O, #13992798].
When must I step up to 3 × 4 mm²?
If the single-phase appliance exceeds 3.6 kW or the run is unusually long (>25 m), move to 3 × 4 mm² with a B20–25 A breaker to stay within voltage-drop and thermal limits [psilos1, #13991381].
Why is a Schuko plug unsafe above 16 A?
Schuko contacts are rated 16 A continuous. At 20 A they overheat; tests show terminal temps can climb past 80 °C in minutes, a fire risk [psilos1, #13991416].
How many separate circuits should a modern kitchen have?
Plan at least four: 1) fridge, 2) dishwasher/washing-machine, 3) oven/hob, 4) general work-top sockets. Each on its own B16 and 30 mA RCD [Łukasz-O, #13991458].
Is running a 5-core cable now worth it?
Yes. A spare 5 × 2.5 mm² lets you switch to a two-phase or three-phase induction hob later without ripping walls [jack63, #13991771].
What breaker pairs with 2.5 mm² aluminium conductors?
Aluminium carries less current. Limit to B13 A or upgrade to copper to avoid hot joints. IEC 60364 tables give 18 A max for 2.5 mm² Al in conduit (edge-case).
How do I convert kW to required cable size fast?
  1. Divide power (kW) by 0.23 to get current (A).
  2. Pick the nearest breaker rating ≥ current.
  3. Choose cable cross-section that carries that breaker’s current per IEC tables. "Always check voltage-drop on runs over 30 m" [Expert Note].
Can I swap screw-in 10 A/16 A fuses for ‘S’ breakers one-to-one?
Usually yes—match the current rating (10 A→B10, 16 A→B16). Verify the prospective short-circuit current and install a DIN rail holder if the old board lacks one [dariusz1209, #14022141].
Do I really need multiple RCDs?
Yes. One 3-phase RCD for the whole house causes full blackout on a single fault. Splitting into three 25 A, 30 mA single-phase RCDs localises trips [malina998, #13997165].
What happens if I oversize the cable, e.g., 3 × 6 mm² on 25 A?
Nothing harmful electrically, but you waste copper and face bulky terminations. Acceptable only when supply capacity (≥63 A) supports it [psilos1, #13992055].
