Kia Ceed 1.6 Petrol - Timing Chain Setting, Distance Between Links & Marks on Gear Shaft
ben_eb 71535 12
How do I correctly set the timing on a Kia Ceed 1.6 petrol engine using the chain links and the camshaft and crankshaft gear marks?
Set the Kia Ceed 1.6 timing by aligning the chain’s colored links with the timing marks on the camshaft and crankshaft gears; the thread does not provide a verified link-to-link distance or a complete mark diagram. If the chain has jumped, replace the complete timing set—chain, guides/slides, and tensioner—rather than simply repositioning it, because the worn chain may jump again [#18372525] Inspect the timing gears as well, since excessive clearance at the sprockets can cause ignition-timing errors [#16691273] For the camshaft wheel, the stated tightening torque is 63.7–73.5 Nm [#20272006]
  • #1 16661007
    ben_eb
    Rate: 9
    Good day. Hello everyone, very warmly. I would like to know how to set the timing in kia 1.6 petrol, i.e. what is the distance between the individual links of the timing chain and the marks on the battles and the shaft. I have seen schematics for 1.4 engine but I can not find for 1.6. Thank you very much for your help.
  • #3 16661625
    ben_eb
    Rate: 9
    From what I learned, this setting is correct.
    • Kia Ceed 1.6 Petrol - Timing Chain Setting, Distance Between Links & Marks on Gear Shaft Screenshot_20170824-214135.png (1.26 MB) You must be logged in to download this attachment.
  • #4 16679732
    ben_eb
    Rate: 9
    Good day. I am after replacing the timing parts, i.e. the tensioner, slides and timing chain. After the exchange, the car went without charge for some time. Only at the revolutions within 3.5 to 4 thousand revolutions, the engine strangely buzzed (it became much louder and walked normally after crossing this limit.) Today, unfortunately, the same problem appeared again, namely the car ceased to walk evenly and a check appeared. in the car was done: 1- replacement candles
    2- the head has been regenerated
    3- Camshaft position sensors have been replaced
    4- was replaced timing (chain tensioner slides)
    5- ignition coils postponed from the second kia ki and unfortunately the same.
    During the diagnostics the same error: single or multiple misfiring and previously there was still an error in timing. I am asking you for help or some information about a good specialist in the area of Giżycko. Thank you
  • #5 16691273
    Glica
    Rate: 16
    Buddy ben_eb. The timing is not only the chain and the slides, the timing wheels are also important elements and you have not mentioned the ones, so the chain has too much clearance on the wheels and from there can be an ignition span.
  • #6 18320129
    speaker1
    Could someone send a manual to Kia Ceed 1.6 G4FC 2008 gasoline or describe how to set the timing in case the timing jumped and the signs can no longer be counted?
    Thank you for all the help.
  • #7 18372336
    Glica
    Rate: 16
    Unless I'm wrong, it's diesel, but the rules for setting characters are the same .... I hope it will fit.
  • #8 18372525
    carrot
    Moderator of Cars
    Help: 1315
    Rate: 3603
    how to set the timing in case the timing has skipped and the characters can no longer be counted
    The chain has colored links that do not get blurred. And if it jumped, you still need to replace the set (chain, slides and tensioner), because it is already so worn that it will do it again soon. The mileage here is of little importance, I changed the timing into a ceed after 50kkm (car from the salon, first owner, so the German did not cry ...), the chain was so stretched that it hung between the wheels like panties drying on a string ;)
  • #9 18372565
    Aleksander_01
    Help: 1167
    Rate: 3435
    I have also heard of such cases and I wonder how you can allow such a state in such a short time. I have a rio with a 1.4 engine new, and now with less than 160 thousand mileage the computer shows 0.2 mm chain slack and the standard is up to 6 mm. Probably people succumb to the magic of oil changes every 30,000 km.
  • #10 18376305
    speaker1
    Thank you for the diagram and all info. The entire timing kit + other defective engine components have been replaced. The old chain didn't have colored links and it jumped one link relative to the new one. On the new one after a few turns, I noticed that the color rubs off the marked links faster than marks made with a felt-tip pen, also a failure.
    Regards
  • #11 20271438
    łukasz19ll
    Rate: 25
    I have to replace the variable valve timing wheel in which direction to unscrew the right or left thread and one more moment of tightening this wheel of variable valve timing and the other wheel knows something
  • #12 20272006
    piotrek gti_abf
    Help: 7
    Rate: 37
    Tightening torque of the camshaft wheel 63.7-73.5 Nm. Regarding the direction of unscrewing, rather to the left because there is no attention to unscrewing, but I am not 100% sure.
  • #13 20276050
    łukasz19ll
    Rate: 25
    Thanks a lot for the hint
The discussion revolves around setting the timing for the Kia Ceed 1.6 petrol engine, specifically regarding the timing chain, its link distances, and gear shaft marks. Users share diagrams and experiences related to timing issues, including the importance of timing wheels and the potential for misfiring if the chain has excessive slack. Several participants mention replacing timing components such as the chain, tensioner, and slides, and highlight the necessity of using chains with colored links to avoid misalignment. Additionally, there are inquiries about the torque specifications for the variable valve timing wheel and the direction for unscrewing it. Overall, the conversation emphasizes the critical nature of proper timing setup and maintenance in preventing engine performance issues.
TL;DR: On the Kia Ceed 1.6 G4FC, chains can stretch even by 50,000 km; “The chain has colored links that do not get blurred.” Align those links with cam/crank marks and replace the full set if it jumped. [Elektroda, carrot, post #18372525]
Why it matters: This FAQ helps DIYers and techs fix timing alignment, diagnose misfires, and apply correct torques on the Kia 1.6 petrol.
How do I set timing on the Kia Ceed 1.6 petrol (G4FC) after a jump?
Use the colored chain links to align with the cam and crank timing marks. Replace the entire set if the chain jumped. “The chain has colored links that do not get blurred.” This ensures marks remain countable even after a slip. Count link positions carefully during installation. Do not reuse a stretched chain, guides, or a weak tensioner. This method restores correct phasing without guessing tooth counts. [Elektroda, carrot, post #18372525]
What’s the quick 3‑step procedure to align the chain and marks?
  1. Rotate the engine to TDC and align cam/crank timing marks.
  2. Place the colored chain links on the marked sprocket teeth.
  3. Install guides and tensioner, then rotate two turns and recheck marks. Follow with final torque steps. [Elektroda, carrot, post #18372525]
What torque should I use on the camshaft sprocket bolt?
Tighten the Kia 1.6 petrol camshaft wheel bolt to 63.7–73.5 Nm. Apply clean threads and steady pull. Recheck alignment after torquing because sprocket movement can nudge the marks. This range matches workshop figures shared by experienced users. Use a calibrated torque wrench. [Elektroda, piotrek gti_abf, post #20272006]
Which way do I loosen the variable valve timing (VVT) wheel bolt?
The shared guidance indicates loosening to the left, with no reverse-thread warning noted. However, confirm during disassembly and mark rotation direction. If resistance feels abnormal, stop and check service data. Avoid impact tools until you confirm thread direction. [Elektroda, piotrek gti_abf, post #20272006]
What if my chain’s colored links have rubbed off or are faint?
Remark the links with a durable paint marker before installation. One user reported the new chain’s color wore faster than a felt‑tip mark. Always verify by counting links between marks after several rotations. If in doubt, replace the chain rather than guessing positions. [Elektroda, speaker1, post #18376305]
Can a diesel diagram help me set timing on the 1.6 petrol?
Yes, the illustrated principle of aligning marks is the same. Use the petrol engine’s specific marks and torque values, but the method—marks to colored links—still applies. Always verify G4FC-specific references before final torques. [Elektroda, Glica, post #18372336]
Why am I getting misfires and a check engine light after a timing service?
Misfires and rough running can follow if phasing is off or parts are still worn. One report noted buzzing at 3,500–4,000 rpm, then misfires and a timing error. Recheck alignment, compression, and component condition. Scan codes, then verify cam/crank correlation. [Elektroda, ben_eb, post #16679732]
Could worn sprockets cause ignition timing span even after a new chain?
Yes. The timing system includes the chain, guides, tensioner, and sprockets. Excess wear on sprockets adds clearance that shifts ignition timing. Replace worn wheels when installing a new chain to lock phasing. “The timing wheels are important elements.” [Elektroda, Glica, post #16691273]
How soon can these chains stretch on the Kia Ceed 1.6?
A documented case showed severe stretch by 50,000 km, causing the chain to sag between wheels. Early wear happens regardless of odometer if maintenance is weak. Replace the full set once stretch or jumping appears. [Elektroda, carrot, post #18372525]
What’s a practical indicator for acceptable chain slack?
A user with a 1.4 sibling engine measured 0.2 mm slack against a tool standard up to 6 mm. Treat this as a directional check, not a substitute for factory specs. Excess slack increases jump risk and phasing errors. [Elektroda, Aleksander_01, post #18372565]
If my timing jumped and marks are unreadable, how do I proceed?
Use the chain’s colored links to re-establish alignment with cam and crank marks. Then replace chain, guides, and tensioner as a set. This prevents repeat jumping due to underlying wear. Do not rely on guessed tooth positions. [Elektroda, carrot, post #18372525]
What symptoms suggest I should replace more than just the chain?
Buzzing at mid‑to‑high rpm, misfires, and timing correlation faults point to broader wear. Inspect sprockets and the tensioner. Worn wheels create extra clearance and unstable timing. Replacing only the chain often fails to fix span errors. [Elektroda, Glica, post #16691273]
