Lenovo Z500 can't identify network via WiFi or cable on TP-Link WR741ND after OS change
KANQAKS 48693 8
  • #1 14038116
    KANQAKS
    Rate: 11
    I have a big help request, I'm completely green in this area and I have a problem with my laptop: It can't identify the network. Despite the lack of knowledge, I will try to describe the problem as accurately as I can.
    The laptop connected to the wifi network for a long time without problems, one day it just stopped. I do not see a connection between this, but it coincided with the change of the system on the PC, exactly after this change, the laptop could not identify the network. If I connect a cable to the paw without a router and create a direct connection, everything is fine, but connection via a router with a cable and wifi is not possible. Other devices (PCty or phone) connect without problem, the router reset did not help.
    Lenovo z500 laptop
    router tp-linkWR741ND
    ipconfig of a directly connected laptop:
    Spoiler:
    Microsoft Windows [Version 6.1.7600]
    Copyright (c) 2009 Microsoft Corporation. All rights reserved.
    C: \ Users \ aa> ipconfig
    Windows IP configuration
    PPP radionet card:
    Connection-specific DNS Suffix:
    IPv4 address. . . . . . . . . . . . . : 217.28.154.130
    Subnet mask. . . . . . . . . . : 255.255.255.255
    Deafult Gateway. . . . . . . . . . : 0.0.0.0
    Ethernet adapter Local connection:
    Local connection IPv6 address. : fe80 :: 1d93: a0c8: 1453: bd09% 16
    Auto-configuration IPv4 address. . . . : 169.254.189.9
    Subnet mask. . . . . . . . . . : 255.255.0.0
    Wireless LAN adapter Wireless LAN connection 3:
    Condition of the media. . . . . . . . . . .: Media disconnected
    Wireless LAN adapter Wireless LAN connection 2:
    Wireless LAN adapter Wireless LAN connection:
    Local connection IPv6 address. : fe80 :: e1e6: f055: 174a: 314c% 13
    Auto-configuration IPv4 address. . . . : 169.254.49.76
    Ethernet Bluetooth Network Connection Card:
    VirtualBox Host-Only Network Ethernet Adapter:
    Connection Specific DNS Suffix:
    Local connection IPv6 address. : fe80 :: 5cb2: 6e8c: 6e26: a008% 22
    IPv4 address. . . . . . . . . . . . . : 192.168.56.1
    Subnet mask. . . . . . . . . . : 255.255.255.0
    Isatap tunnel card. {19814983-A0E9-4C08-AE05-A35279AB8505}:
    Isatap Tunnel Card. {87D47207-DBDD-4262-8ABF-7923D350C498}:
    Isatap Tunnel Card. {355F374F-AB6E-42A8-BACD-9B3974F176B8}:
    Isatap Tunnel Card. {CE4F6CE5-86B6-48D2-AB8B-CBFD60B4F4B9}:
    Isatap tunnel card. {3C969E30-ACFB-46B6-8C49-1AC2AE436EA3}:
    Teredo Tunneling Pseudo-Interface Card:
    Isatap tunnel card. {954E6259-6619-4236-90B5-A076113117CF}:
    6TO4 Tunnel Card Adapter:
    IPv6 address. . . . . . . . . . . . : 2002: d91c: 9a82 :: d91c: 9a82
    Deafult Gateway. . . . . . . . . . : 2002: c058: 6301 :: 1
    Isatap Tunnel Card. {0716F97D-00D2-414C-ADA8-972528D917AE}:
    C: \ Users \ aa>
    ipconfig
    trying to connect via wifi
    Spoiler:
    Isatap tunnel card. {355F374F-AB6E-42A8-BACD-9B3974F176B8}:
    C: \ Users \ aa>
    Please help
  • #2 14058308
    DriverMSG
    Help: 3984
    Rate: 4890
    KANQAKS wrote:
    connection via router via cable and wifi is not possible.
    This is normal.
    Show screen from device manager with expanded list of network cards.
  • #4 14058957
    DriverMSG
    Help: 3984
    Rate: 4890
    Uninstall or disable virtualbox host-only ethernet adapter.
  • #5 14059093
    KANQAKS
    Rate: 11
    Unfortunately, no changes. In the network connection status tab, the IPv4 and IPv6 connection points are annotated with
    No internet access as well
    no network access -> Picture
    When looking for a solution on other forums, I found a recommendation to manually enter the IP address and DNS, but it resulted in a wrong IP error. Maybe this is a good method, but I entered the wrong addresses, so if this is a reasonable solution, maybe I could ask for specific addresses to enter in the sense - IP from the router or maybe the latter, from the WAN category? In the picture I also put a screen from the server settings. I'm hiding the values, I'm green, and I don't know if it's completely safe to give this data.
  • #6 14059241
    DriverMSG
    Help: 3984
    Rate: 4890
    As long as WIFI connects to the router, the screenshots above show that you can use addresses 192.168.0.2 up, unless the router is set differently (IP range).
    In other words, if not 192.168.0.2, then another one - 192.168.0.3, etc.
    Also set DNS 8.8.8.8 and one of those you masked.
  • #7 14059370
    KANQAKS
    Rate: 11
    Unfortunately, manually entering addresses all the time does not change anything. Selecting the option to check the correctness of the settings after finishing generates a Windows diagnostic which of course does not indicate a problem.
    I think I will have to look for a professional service, however, so that someone sensible can see it on the spot.
    DriverMSG - thanks for your interest in the topic.
  • #8 14061140
    fanfiction
    Help: 10
    Rate: 16
    Recently, I was struggling with a similar problem on a TP-Link like yours. Changing the channel to e.g. 1 solved the problem.
    I did not have time to delve into the topic, but when it was set up from the machine, or at 11, it could not identify the network.
    Delete all saved profiles for wireless networks in the Network and Sharing Center -> Manage Wireless Networks
  • #9 14160890
    KANQAKS
    Rate: 11
    I finally fired up ubuntu from the disc - wifi worked there. As I couldn't find the problem any further, I decided to format, reinstalled the system and now everything is fine. I still don't know what exactly it was about but the topic is now closed, thanks for the advice.
The discussion revolves around a Lenovo Z500 laptop that is unable to identify a Wi-Fi network after a system change, despite functioning correctly with a direct cable connection. Other devices connect to the TP-Link WR741ND router without issues. Suggestions include checking the device manager for network cards, uninstalling the VirtualBox host-only Ethernet adapter, manually entering IP and DNS settings, and changing the router's Wi-Fi channel. The user ultimately resolved the issue by formatting the laptop and reinstalling the operating system, which restored Wi-Fi functionality.
