Connecting Legrand Differential: Correct Installation, Phase Conductors & Importance
rarytas86 115797 19
Does it matter whether the phase and neutral are connected on the left or right side when wiring this single-phase Legrand differential?
For a single-phase differential, it does not matter electrically whether L and N are connected on the left or right, because the device works by measuring current difference, not voltage potential; in 3-phase devices the N terminal designation matters [#14039354] However, if the manufacturer’s diagram is available, follow it: L on the left and N on the right, with supply on terminals 1-L and 3-N and load on 2-L and 4-N [#14039474] If you are using a comb busbar, you may need to adapt the arrangement to match that terminal layout [#14039477][#14039621]
  • #1 14039241
    rarytas86
    Rate: 40
    Is the connection of the differential in the photo correct?
    Should the phase conductors be on the right or left side ??
    Does it matter ???
  • #2 14039254
    elpapiotr
    Electrician specialist
    Help: 1015
    Rate: 3530
    The electrician will know no need to worry.
  • #3 14039270
    rarytas86
    Rate: 40
    that's for sure, but I would like to know them too, so please answer the question.
    because I found various connection diagrams on the net.
  • #4 14039275
    Łukasz-O
    Admin of electroenergetics
    Help: 654
    Rate: 4290
    There is also a diagram on the camera. Can't you see him?
  • #5 14039277
    niewolno2
    Level 40  
    Help: 628
    Rate: 1258
    What does the producer say?
  • #6 14039289
    rarytas86
    Rate: 40
    Legrand.
    I can see the schematic and that's why it seems to be a good connection.
    I'm right???
    Today I found a photo of the differential connected differently on the net, so I am asking how is it correct ??
  • #7 14039299
    remik_l
    Help: 144
    Rate: 325
    And I think it's bad.
  • #8 14039310
    rarytas86
    Rate: 40
    hmmm, the connection in the drawing is wrong ???
  • #9 14039354
    niewolno2
    Level 40  
    Help: 628
    Rate: 1258
    In the case of a 1-phase differential, it does not matter where you connect L and N, because in both cases the differential mechanism will work (it works on the principle of the difference of currents in the circuit, not voltage potentials). In 3-phase differentials we have 3 differential modules with a common N terminal, so there is required the designation of the N terminal.
  • #10 14039474
    tomix
    Help: 7
    Rate: 99
    According to art, L on the left, N on the right.
    Access on terminals with a fixed element (terminals 1-L, 3-N), output on terminals with an element (2-L, 4-N).
  • #11 14039477
    elpapiotr
    Help: 1015
    Rate: 3530
    And if I want to use a connecting comb for "es", I have to figure it out.
    Isn't it better to make your job easier?
  • #12 14039621
    rarytas86
    Rate: 40
    As for mycelium, that is, rails, I used it. It is enough to cut out one of the teeth and the differential will be connected according to the art.
    So L on the left and N on the right.
  • #13 14039646
    kkas12
    Help: 1076
    Rate: 4312
    There is no "art". There are manufacturer's recommendations, which means (or does not mean) the clamp for connecting the N conductor, so please do not create abstract "art", because one person is already deceiving you, my friend tomix you introduced.
    This is no art.
  • #14 14039655
    rarytas86
    Rate: 40
    Well, maybe not the art, but everywhere I put the phase wire on the left.
    From what my colleague writes, the difference in the picture is correct, right?
    In a single-phase connection, a differential that has no marking for N connection does not matter from which we connect the phase and which N. I understand well ???
  • #15 14039700
    niewolno2
    Level 40  
    Help: 628
    Rate: 1258
    If you have any doubts, it is enough to call the manufacturer or sales representative and that's it.
  • #16 14039783
    remik_l
    Help: 144
    Rate: 325
    Buddy, in your drawing, you have marked the phase wire and N, but you have not given where the power is plugged in and where the drains are.
    If so, I connect the RCD, will it be okay?
  • #17 14039794
    rarytas86
    Rate: 40
    On the website and in the technical specification, I also did not find where N is to be connected and where the phase.
    Therefore, I am asking you for advice.
    I understand that in this case the side on which the N wire is installed is indifferent?
    Top supply according to the current flow diagram which is on the differential.
    Why do you think it should be alternating as described in the picture?
  • #18 14039898
    remik_l
    Help: 144
    Rate: 325
    I did not write that it should be alternating, but I asked if it would be good if I connect it in this way, because it did not follow from your drawing.
    I asked this question so that you would learn something, not because someone said so.
  • #19 14040006
    serwisor
    Help: 96
    Rate: 164
    Gentlemen, no one has asked the question yet:
    What is the network layout you want to connect this camera to on the circuit?
    What protection is against and what is behind this RCD.
    How did you measure your PE? Did you even measure? There is PE at all?
  • #20 14040116
    BILGO
    Help: 393
    Rate: 725
    Are you sure ?
    In my opinion what you write is not true. In RDC 3f, the N line is only marked because it is the first to be connected and the last to disconnect ;)
The discussion revolves around the correct installation of a Legrand differential circuit breaker, specifically addressing the placement of phase (L) and neutral (N) conductors. Users express concerns about varying connection diagrams found online and seek clarification on whether the phase conductors should be connected on the left or right side. It is noted that for single-phase differentials, the connection of L and N does not significantly impact functionality, as the differential operates based on current differences rather than voltage potentials. However, for three-phase differentials, proper designation of the N terminal is crucial. The conversation emphasizes the importance of adhering to manufacturer recommendations and suggests consulting technical specifications or the manufacturer for definitive guidance.
