Experiencing Distortions in Microphone Sound Quality Despite GoldWave De-Noise
OxPamider 22251 10
How can I remove hum and background noise from a microphone recording without making the voice sound distorted?
The hum is likely caused by a grounding problem in the audio/power setup, so try running the laptop on battery, using a properly grounded outlet or extension cord, and testing whether the hum disappears when the charger is disconnected [#14102198] If needed, you can also bond the computer case to the microphone’s metal part with a wire to reduce the hum [#14104579] Software de-noising can remove only sampled noise, and it often makes the voice sound robotic, so it will not fix noise created in the analog path [#14101574] For a cleaner result, use better hardware such as a shielded preamp or an external USB sound card, or simply a better microphone [#14101574][#14101510][#14104579]
  • #1 14101495
    OxPamider
    Hello. I have a microphone that doesn't record sound "clean". In the background you can hear slight noises and distortions. The voice can be heard perfectly in my opinion. I tried to de-noise the microphone in GoldWave, but it did not help because my voice sounded like I was some kind of robot xD Anyone know how to help me? If so, please reply as soon as possible. Get another short sample of my microphone.
    • test.mp3 (110.2 KB) You must be logged in to download this attachment.
  • #3 14101522
    OxPamider
    or maybe there is some other way? maybe some program can fix it?
  • #4 14101574
    DominTR3B
    Help: 85
    Rate: 90
    Noises are generated in the analog path, the programs only cut out noise samples, eg "Audacity". The best solution is a good shielded preamplifier with a symmetrical input.
  • #6 14102360
    OxPamider
    Indeed, when I disconnect the power supply, the hum subsides, but you can hear a slight noise, but GoldWave made the noise also disappear and it's okay, but there is one problem. I need good audio quality in order to record videos on YouTube (games), and as you know, games eat up a lot of battery and here's the problem because if I want to play longer without hum (without power), I will record for a shorter time. Do you have a way to remove this hum when the power source is connected to the laptop?
  • #7 14104309
  • #8 14104538
    OxPamider
    the one attached to the headphones :D which is probably cheap :P
  • #9 14104579
  • #10 14104664
    OxPamider
    and if I connected the charger to an extension cord with grounding, would it help?
  • #11 14104713
✨ The discussion revolves around issues with microphone sound quality, specifically distortions and background noise despite attempts to use GoldWave for de-noising. Users suggest various solutions, including purchasing an external USB sound card to isolate analog circuits from the motherboard, using programs like Audacity for noise reduction, and ensuring proper grounding to eliminate hum. The conversation highlights the importance of using a good shielded preamplifier and the potential benefits of upgrading to a USB microphone for better sound quality. The original poster expresses concerns about maintaining audio quality while recording videos on a laptop, especially when using the device's power supply, which introduces hum. Suggestions include grounding techniques and using extension cords with grounding to mitigate noise issues.
