2.0 TDI CAHA 170 KM - Uneven Engine Idling, Misfires at Traffic Lights, Low Fuel Level Impact
michal19885 62319 17
Why does a 2.0 TDI CAHA engine idle unevenly and misfire at stops, especially when the fuel level is low, even though there are no fault codes and the injectors were already replaced?
Check the fuel system first: used injectors can still be faulty, so do injector return/overflow tests and compare them (about 4–5 ml/min per injector), then watch injector corrections and rail pressure while the problem is happening [#14142611] [#14142683] [#14143123] If the rail pressure fluctuates, suspect the common-rail pressure control valve/regulator, the rail pressure sensor, or the high-pressure pump rather than the injectors alone [#14143135] [#14143340] Also inspect the rail valve/strainer for dirt particles and check the injector-control wiring, since damaged wiring or a released driver can cause this kind of intermittent misfire at idle [#14143373] [#14142617] Measure compression as well, because a mechanical cylinder issue can also show up as rough idle without stored errors [#14142617]
  • #1 14142471
    michal19885
    Help: 27
    Rate: 286
    Hi, I have a problem with the 2.0 TDI engine code CAHA, 170KM, CR injection.
    Engine idling sometimes runs erratically - looks like misfire. The problem appears most often after stopping, for example, at traffic lights. When idling for a long time, the engine runs smoothly, after a few minutes the ignition starts to misfire and then runs smoothly again. The owner says the problem occurs more often when the fuel level in the tank is low.
    The car had this problem in one workshop, all the injectors were replaced there (for used ones). Nothing has changed.
    There are no errors in the controller, all current parameters look ok.
  • #2 14142611
    Kitek_1982
    Rate: 21
    The injectors used are not always good. Let them make overflow tests and it will be known.
  • #3 14142617
  • #4 14142683
    michal200848
    Help: 41
    Rate: 281
    Injections for transfers and it will be known.
  • #5 14143123
    michal19885
    Help: 27
    Rate: 286
    Transfers from 4 to 5 ml per minute on each injector.
    I noticed that the easiest way to cause a problem at a standstill is a short gassing. After the engine comes off the revs, there is a moment of uneven work.
    While viewing the current parameters, you can notice pressure fluctuations in the rail. The pressure increases and decreases once, then it stabilizes and the engine runs smoothly.
  • #6 14143135
    michal200848
    Help: 41
    Rate: 281
    Jumping pressure is a symptom of a crashing pump cr.
    rzemyk90
    Help: 25
    Rate: 277
    Or damage to the drv, the dispenser and the pressure sensor on the ramp.
  • #9 14181805
    michal19885
    Help: 27
    Rate: 286
    The vibrations are particularly bright in the region from 11 to 16 seconds and from 41 to 50. The photos probably show everything.
    2.0 TDI CAHA 170 KM - Uneven Engine Idling, Misfires at Traffic Lights, Low Fuel Level Impact 2.0 TDI CAHA 170 KM - Uneven Engine Idling, Misfires at Traffic Lights, Low Fuel Level Impact 2.0 TDI CAHA 170 KM - Uneven Engine Idling, Misfires at Traffic Lights, Low Fuel Level Impact
  • Stable idle RPM but persistent engine vibrations at cold start
    #10 15050601
    pepe_lodz
    Rate: 65
    I have the same engine and I am writing an inquiry. Have you had engine vibrations and RPM fluctuations during this unequal engine operation?
    Because I was at home this morning at +1.5 C, I noticed that the engine seems to work evenly, i.e. the idle speed is stable, it does not vibrate, but the engine has vibrations. I can hear and feel him sitting in the seat, on the gear lever ... I don't know what is. Fire up, he fired up ok without a hitch ... The rotation does not wave ... but there are vibrations and I can feel it on the kennel and sitting, and on the lever and steering wheel. Please help.
  • #11 15080233
    marcino_16
    Rate: 23
    @pepe_lodz
    I also have this engine, it looks like a clutch is ending, you can also try the "Liqui moly diesel spulung" preparation, it supposedly affects the smooth operation of the engine.
  • #12 15080283
    pepe_lodz
    Rate: 65
    Is there a slight tingling that ends the clutch? Yes, there are no problems with the gearbox ... uphill, it accelerates ok in high gear and does not slip ...
  • Persistent fuel pump hum remains after replacement
    #13 15136431
    Ronivw
    I have the same CAHA engine and after firing it will melt for a while, probably the fault is one glow plug burned because there is a bug from it. So this topic is worth checking out. My car has already been repaired after filings occurred. It seems to drive nice, but hears a hum under the front passenger seat, i.e. the fuel pump. I have already replaced it with the second used one and the same. My hands fall.
  • #14 15136735
    Kune
    Help: 23
    Rate: 212
    I suggest starting with the valve on the pump. Alternatively, try to get a second one for a change.
    If the pressure drops on the CR, it is usually the culprit. There is also a defect of the high pressure pump, but these are individual cases. For me, this valve / sensor or whatever it is called was to blame.
  • #15 16524114
    robert19760
    I propose to adapt the new one, or even the old one. The car even twitches, the revolutions are constant. You can also replace a thousand new sensors, without adaptation it will be the same. good luck.
  • #16 17427951
    spidi_87
    Rate: 10
    Buddy, write how to make this adaptation? Because probably most of them cannot find it
  • #17 18008925
    MCZ007
    Rate: 8
    Hi. I have replaced the valve on the common rail, but without any adaptation. The fuel pressure continues to jump strangely, I will take care of the valve on the pump and check the pressure sensor on the rail. Are any valve adaptations required that I missed that would help to compensate for vibrations at idle?
    Regards
  • #18 18017831
    Razor1711
    Rate: 49
    They are not needed, but there is such an option in vcds in Adaptations.
The discussion revolves around issues with a 2.0 TDI engine (CAHA, 170 KM) experiencing uneven idling and misfires, particularly noticeable at traffic lights and when fuel levels are low. Despite replacing the injectors with used ones, the problem persists. Participants suggest conducting overflow tests on the injectors, measuring compression pressure, and checking the fuel pressure on the rail. Fluctuations in rail pressure are noted as a potential symptom of a failing high-pressure pump or issues with the pressure sensor. Other suggestions include inspecting the valve on the pump and considering adaptations for new or old components to stabilize engine performance. Some users report similar experiences, indicating a broader issue with this engine type.
