2.0 TFSI Engine Drop Out: Experiences with Ignition Cylinder 1 and Fuel Dose Issues
fludi26 25227 20
Why does a 2.0 TFSI engine flood the spark plugs and misfire on cylinder 1 even after new coils, injectors, checked compression, and tested fuel pressure?
Check for a left-air/vacuum leak in the crankcase ventilation system (PCV/odma) and related intake hoses, because several replies point to this as the likely cause [#16468437] [#16468739] [#16493210] If the engine runs almost normally with the hose from the odma to the intake manifold disconnected, that strongly suggests the ventilation valve or its connections are faulty or leaking [#16468437] [#16493210] One reply also notes that on a similar engine the problem turned out to be the intake manifold valves [#16447072] If the mechanical and air-leak checks do not solve it, measure the injector output with an oscilloscope on the non-working cylinder to verify whether the ECU driver/output stage is damaged [#16449160] [#16449182]
  • #1 16446373
    fludi26
    engine 2.0 tfsi firing ignition cylinder 1 mechanics with the service spread out hands fake air in the combustion chamber auto all the time comes on 3 gary the fuel dose is from the cosmos sparkles new comes from 10 mins ok and again floods, coils new, odmaew, new injections, head with shafts checked cleaned with carbon deposits valves fed sensors so confirmed because they do not crush any sensor error everywhere equals the camshaft is perfectly ok. now they want to disassemble the engine only I do not know why compression is all right and you know what it costs servisie audi do not know what to look for me I think I can roll any cam or driver I do not have the strength for this car please, any hints I will add even the pressure is also good that fuel filter has not been replaced only if it has some impact as with pressure is ok :(
  • #2 16446577
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4180
    And what about the parameters of the fault?
    Temperature, fuel pressure, injection time?
    No offense, I suggest you take the car from the site and look for someone recommended in the area.
    The websites do not have the knowledge that they have workshops that specialize in a given brand.
  • #3 16446587
    jenusz11
    Help: 33
    Rate: 196
    sensors do not cheat? does the meter measure well? pipes from the venting, these plastic pipes not cracked? a catalytic converter?
  • #4 16447072
    bula17
    Help: 52
    Rate: 295
    Recently I had a similar problem only on the 4th cylinder turned out the valves in the collector sucking.
  • #5 16447218
    fludi26
    I will say so the fuel pressure checked that it is ok injection time, they probably did not do anything, or at least they did not say sensors ok but they suggest that there is no error on the computer suction corrector twice downloaded, I do not know what with the catalyst of the tubes, probably not checked the worst is that like new candles or to clear it can be ok up to 20 minutes but as it floods the chapel candles black soothed all 4 not only one on this particular cylinder gentlemen and maybe you know some good professional because I do not have the strength of the car I have half a year I drove only a month, everything started as I dragged it 1, 2, 3 so to the max for a few days chekin followed by epc or something like that it is audi a6 c7 2012, 180 thousand km
  • #6 16447378
    Megawe
    Help: 246
    Rate: 1437
    Check whether the plugged off engine temperature sensor will also flood the spark plugs.
  • #7 16447740
    fludi26
    I check only until tomorrow, ie Tuesday I am going to the service and probably I will pick up the car, of course, not already done, 3 plant that did not solve the fault 2x service Bosch and now service audi kalisz :(
    Added after 9 [hours] 13 [minutes]:
    do you know any specialist from the audi engine 2 0 tfsi?
  • #8 16449160
    wojekkk
    Help: 14
    Rate: 32
    Check OSCILLOSCOPE! signal on the injector plug of the non-working cylinder pin 1 and 2 in relation to the mass and the working cylinder if the engine control section is significantly damaged.
  • Compare injector control signals with an oscilloscope for ECU faults
    #9 16449171
    fludi26
    Thank you very much for the hint tomorrow means I'm going to the service today and I will tell them to do it only if they will have an oscilloscope :( and maybe you know about a good professional because I do not want to offend anyone but where I have a car they do not have too much idea even though this is an audi service I tell them that maybe I could exchange a computer or fight and they can try because they do not have a computer check :(
  • Oscilloscope testing can confirm ECU injector driver failure
    #10 16449182
    wojekkk
    Help: 14
    Rate: 32
    I sometimes make hopeless cases for a familiar mechanic, I know something like this happens in these engines. The car floods 1 cylinder, the short-term corrections are very much in the red then. Measurement of the oscilloscope by someone who can interpret what he sees on the screen will unambiguously show whether the output stages of the motor controller work okay or not. If not a driver either for repair or replacement for new / used.
    #11 16449897
    fludi26
    You know what I was on the site I read to them this message what you wrote and suddenly some enlightenment they got that they do because they think so only why they did not do it and only after reading the news :( if I know something more I will write it down because on Friday I have to answer thank you and best regards :)
  • #12 16456356
    fludi26
    [Quote = "fludi26"]
    hello I am just leaving the service men said that there is a difference on the first cylinder I'm asking if there is such a difference saying that if it was great, you would not run the car at all ... I mean understand that this driver will be damaged anyway?
  • #13 16456374
    wojekkk
    Help: 14
    Rate: 32
    Unfortunately, not seeing the mileage and not standing at the car, I will not say anything interesting but the car is not a space rocket to get enough doctorescence and expose the client to unnecessary costs and exchange of random parts ... Your way of translation without sense since the car does not work on 1 this cylinder could not be there during the injection time or be a constant voltage and would not work on it anymore and would fire on the other three.
  • #14 16468437
    fludi26
    Hello. the engine driver was tested and replaced but it is not a driver but today the electro-mechanic has pulled a hose or a tube from odma which goes to the suction equalizer and it has blinded the car and goes off perfectly but as soon as it plugs back you hear a whistling for about 10 seconds and again the tragedy begins with a telepac car :(
  • #17 16468739
    grala1
    VAG group specialist
    Help: 1495
    Rate: 5052
    Some PLN 170 on the site.
    Usually, if it breaks down, there is a mistake in the left air.
    The valve is supposed to let only one side and there is a mushroom which breaks behind the valve in the middle and lets go both ways.
  • #18 16468765
    fludi26
    odma is the new original bought on the site has a week, nothing helped the cost odmie 350 PLN audi a6 c7 2.0 tfsi year 2012/13
  • #19 16493210
    fludi26
    Gentlemen, you do not know any good specialist from Audi engine 2.0 tfsi because the audi service spreads your hands so that I have to find someone and no matter what region is all the time there is a problem with left air if pneumothorax is connected normally car walks tragically the cork does not go away As soon as you break free, the car strangles and goes out after that it does not go on for 5 minutes. when I turn odme from the intake manifold and catches the suction collector and the hose from the odmy let go slowly, the car goes almost perfectly ...
  • #20 16959777
    tomzo69
    Check the PVC valve cost with a seal is about 170 PLN
    Added after 5 [minutes]:
    Before replacing, unscrew the engine oil filler cap if it sucks air to 100% PVC 2.0 TFSI Engine Drop Out: Experiences with Ignition Cylinder 1 and Fuel Dose Issues
  • #21 18250777
    lopat84
    Rate: 98
    Did you solve the problem
The discussion revolves around issues with a 2.0 TFSI engine, specifically focusing on ignition problems in cylinder 1 and fuel dosing complications. The original poster describes symptoms including flooding of spark plugs, black soot accumulation, and intermittent performance issues. Various suggestions are made, including checking fuel pressure, injection timing, and the condition of sensors and hoses. Recommendations include using an oscilloscope to diagnose injector signals and checking the engine temperature sensor. The poster expresses frustration with multiple service attempts yielding no solutions and seeks recommendations for a knowledgeable mechanic. The conversation highlights the importance of diagnosing air leaks and the potential impact of the PCV valve on engine performance.
