Updating Firmware on Samsung GT-S5611 Using Samsung Kies 2.6: Connection Lost Issue
jackdanielsblack1984 26688 11
  • #1 14225396
    Well, I have an unusual problem with updating the firmware of the Samsung GT-S5611.
    When connecting the phone to a computer, the Samsung kies (2.6) shows info. that a new version of the software is available for the phone, but when going to the update download point, the information appears that the connection with the phone has been lost and over and over, tried by another usb port and other computer but always ends the same. I made a hard phone reset with a special code but that also did nothing. Besides, in the initialization settings (in the Kies program) updating when entering the S / N number of the phone pops up an error to check the data again ... and as I have already connected it shows that S5611 no supports initialization ...
    Does anyone have any solution or the latest Polish-language soft for this model?
    Greetings .
  • #2 14228793
    Paradise2017
    Rate: 13
    which versions of the phone phone shows you in the kies program, I have the same problem with the Samsung S5611 phone only I would like to branded it soft with the play network and step-by-step instructions on how to upload it without using the box.
  • #3 14236522
    Shows the current software version: S5611XXND3 / S5611OXAND2 (XEO)
    version of the available software: S5611XXNJ3 / S5611OXANJ2 (XEO)
    Unfortunately, it is not going to update by any program, this model is sucks !!! I regret that I did not buy the previous S5610.
  • #4 14258521
    0xC0FFEE
    Level 19  
    Help: 26
    Rate: 88
    Telephone from Polish distribution? Operator or free run?
  • #5 14301251
    pirania36
    I have the same problem.
    Current software: S5611BVNH2 / S5611IDENI2 (IDE)
    The latest version: S5611BVNK1 / S5611IDENK1 (IDE)
    Phone with Orange PL.
  • #6 14613214
    Mitecl
    Help: 11
    Have you managed to solve the problem of lack of subtitles after uploading this software?
  • #7 14785526
    daro4086
    Can anyone help with the lack of font?
  • #8 14998802
    labik
    Rate: 79
    You coped with this font. I did one and the Pole was smart and I wanted to remove the play and I do not have a font
  • #9 15186704
    dudzior73
    Will we get a reasonable answer about the founder of the topic?
    I will tread on that only once and only on 1 phone out of 10 I managed to accidentally update the software. I guess it's not really streamlined because sometimes I have bluescreen: File: wllc_xdsp. c Line: 1829 ASSERT (PS Asssert!)
    The only thing I can do is wake the battery.
    Soft branded PLUS would like to exchange for a free one.
  • #11 15283933
    yabollek
    Rate: 8
    I will play the chop, does anyone know if samsung plans to revive the flashlight in newer versions of the firmware in this model?
    Such a sell and in a newer version (5610 it had) to forget about this very useful addition.
  • #12 16015303
    piter65
    Hello. Regarding the softa upgrade. I downloaded the update normally through the purse. In my case I had to press and hold the keys 1 and 3 and then connect the cable. Only then did the update play without problems. There are also other variants, eg. The key 1, or the keys 2 and 5.
✨ The discussion revolves around issues faced while updating the firmware of the Samsung GT-S5611 using Samsung Kies 2.6. Users report persistent connection loss during the update process, despite trying different USB ports and computers. The current software versions and available updates are shared, with some users expressing frustration over the model's limitations. Suggestions include checking the phone's distribution type (operator or free) and using specific key combinations (e.g., holding keys 1 and 3) during connection to facilitate the update. Additionally, users inquire about the availability of Polish-language firmware and solutions for font issues post-update.
