Samsung S5610: SIM Card Not Detected - Possible Causes & Data Recovery Solutions
retrofood 4620 5
  • #1 16601540
    retrofood
    Help: 1140
    Rate: 4797
    Nothing happened (apparently) and yet the phone stopped seeing its SIM card. In the morning I talked, everything was fine, I put the phone in a plastic bag in the car and it traveled several dozen kilometers. He did not fall, he was not hit, he was traveling on the rear seat uncomfortable. But the SIM card can no longer be seen. Of course, no one looked there, no one took the battery out, much less the card.
    There are such situations? Is the data in memory somehow recoverable? It is especially about phone numbers. In general, the camera looks functional, turns off, turns on normally. Now I took out the battery and so did the card. No effect.
  • #2 16601561
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2089
    Staszek, start by washing the sim card with e.g. alcohol and then check if it works. Insert another sim card into the phone and you will have the answer whether the phone or the card is damaged.
    This Samsung model is very successful and I bet that the card has been damaged.
    Yes of course. :)
  • #3 16601654
    mobista
    Help: 257
    Rate: 365
    And after entering the code * # 06 # what do you see?
  • #4 16601674
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2089
    Even if imei fell, this model sees the card.
  • #5 16601699
    retrofood
    Help: 1140
    Rate: 4797
    Card failed. Others see, with others it would probably work, but they are out of date. But he sees what's on them.
    Added after 7 [minutes]:
    "Emergency calls only. Insert SIM card to access network services."
  • #6 16601762
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2089
    So drive to the salon and they will exchange this card for you.
