Finding IP Address for TR-WIPD122POE Camera: Locate Camera's IPv4 Address at 192.168.1.123
Artex ZUT 49332 45
How can I find the IPv4 address of a TR-WIPD122POE IP camera when it is not responding at the expected 192.168.1.123 address?
Connect the camera directly to a PC or switch, set the PC to a manual IP in the same subnet, and then look for the camera with Wireshark or the ARP table after a ping; for example, use 192.168.1.100 on the PC if the camera should be in 192.168.1.x [#14275307][#14283980][#14275606] If the camera still does not appear, it may actually be on a different subnet or a different fixed IP, and 192.168.1.123 may simply be wrong or conflicting with the router's DHCP range [#14275409][#14275606] You can also check the router's DHCP client list or use an IP scanner, but that only helps if the camera is getting an address from DHCP [#14275115][#14296969] A factory reset was also suggested as the cleanest way to restore the default address, but this model may have the reset hidden inside the housing rather than on an external button or hole [#14283980][#14295015]
  • #1 14274909
    Artex ZUT
    Rate: 13
    I have a problem with the IP camera, theoretically, it should be at 192.168.1.123 but unfortunately it is not there? How can I find out her address? the camera is TR-WIPD122POE
  • #2 14274946
    Maciek051996
    Help: 99
    Rate: 300
    Enter your router model.
    Is the camera powered on?
  • #3 14274970
    Artex ZUT
    Rate: 13
    The router is Netia spot
    The camera is powered on, the LEDs from the camera's network card are flashing, I also checked on another cable, no changes, I tried to find this address with the Wirles Network Watcher program but it does not detect it either :(
  • #4 14275030
    yazar
    Do a camera reset (there's definitely a paperclip hole somewhere). Then you will be sure it has factory settings. You can also connect the camera directly to the computer with a cross cable, remembering to set the network address from your finger in the computer, e.g. 192.168.1.100.
  • #5 14275047
    Artex ZUT
    Rate: 13
    The problem is that, unfortunately, there is no hole for a paperclip as you defined it, also the lack of any button that could possibly be a reset :(
  • #6 14275067
    jimasek
    Help: 3783
    Rate: 2681
    The manufacturer did not provide any application (wizard) to search for a camera on the network?
  • #7 14275097
    Artex ZUT
    Rate: 13
    I do not know, I only have a camera (theoretically new) but unfortunately I do not find it at the address on the sticker
  • #8 14275115
    jimasek
    Help: 3783
    Rate: 2681
    This is how you buy "Chinese". Do you have any manual?
    With a correct connection, it should get an IP address from the router's DHCP. So look for DHCP clients on the router and log in with the IP address you find there.
  • #9 14275117
    Loker
    Help: 575
    Rate: 721
    Maybe from the beginning: what are your network settings?
  • #10 14275123
    yazar
    link to the manufacturer's software page
    Link
  • #11 14275134
    Artex ZUT
    Rate: 13
    more precisely what do you ask about network settings?
    if for the address range, the network works in the same range as the camera should theoretically be
  • #12 14275143
    rikardo67
    Help: 26
    Rate: 25
    If you connect to it with a computer with a crossover cable, then you should set the IP computer from this range, for example: in the webcam (address from the sticker) you have 192.168.1.123, then you should have IP 192.168.1.100 in the computer or you should have a network with the address 192.168. 1.0 / 24 if you have a different addressing on the webcam and another on the device (computer) from which you are trying to connect, you will definitely not connect without a combination (routing, forward, or VPN).
    EDIT
    Since you connect to the netia-spot, can you see what the IP camera is getting?
  • #13 14275181
    Artex ZUT
    Rate: 13
    Thanks but that's it and I know, unfortunately, I have a network exactly at the address 192.168.1.0-254, which is theoretically in the range in which the camera should be but it is not there and unfortunately it is not visible on the router
  • #14 14275190
    itadek
    Help: 47
    Rate: 227
    install yourself buddy some simple program to search the network and show all active IP addresses.
  • #15 14275199
    Artex ZUT
    Rate: 13
    e.g. what?
    I was looking for Wirles Network Watcher but it doesn't detect it either
  • #16 14275226
    jimasek
    Help: 3783
    Rate: 2681
    The port is active after connecting the camera to the router? The camera is powered by PoE or an external power supply?
  • #17 14275254
    Artex ZUT
    Rate: 13
    the power supply via the power supply port is active
  • #18 14275279
    jimasek
    Help: 3783
    Rate: 2681
    Original power cord or some made?
  • #19 14275292
    Artex ZUT
    Rate: 13
    The original cable is 100% good
    sorry if I offend you, but if you can help, bring something specific to the case and you don't ask about crap, I checked it for him, I entered the forum
  • #20 14275296
    jimasek
    Help: 3783
    Rate: 2681
    That's what I'm doing, but if you know better ....
  • #21 14275298
    Artex ZUT
    Rate: 13
    at the moment I ran Angry IP Scanner I entered the range 192.168.0.0 to 192.168.10.254 now it searched to 192.168. 4.130 and did not detect it :(
    no offense, if I knew better, I would not be here, but after I entered here, I checked what I could, cables, power supplies, is the link active, etc.
  • #22 14275305
    jimasek
    Help: 3783
    Rate: 2681
    But how do I know what you did and what is your state of knowledge? Take into account that I cannot see your camera or computer.
    Have you checked in the manual what is the addressing of the camera? Dynamic Ip or maybe a permanently assigned address?
  • #23 14275307
    bogiebog
    Help: 2569
    Rate: 1530
    Connect the camera to the lan port of the computer, set the lan port manually to 192.168.33.33 255.255.255.0 rest blank,
    Run wireshark capture on the lan port, start the camera, see if there are any frames with a mac address different from the mac address of the network card.
  • #24 14275314
    Artex ZUT
    Rate: 13
    just read the previous entries, I wrote that there is a link and that I checked the cables
    But OK from the beginning, the kaera is on, the network card in the camera works, the link on the router lights up and blinks, the program searched the range from 192.168.0.0 to 192.168.10.254 and unfortunately it did not detect it, what else can you check?
  • #25 14275331
    rikardo67
    Help: 26
    Rate: 25
    You asked the question without giving any data, how do you connect this camera to what and what cables are the addresses, and if you want help, these are the basic data, I suppose that being in your place (with this camera) no one would ask you any questions, well unless you are looking for a clairvoyant, if you are looking for a clairvoyant, you have mistaken the department, so you have no reason to be pissed off by asking questions, you should be furious with yourself that you cannot describe your problem exactly
    How to find the IP address of the camera?
    "what would YOU answer if there is nothing in the description ??.
  • #26 14275342
    Artex ZUT
    Rate: 13
    I have not read the manual because, unfortunately, I do not know the language, but according to the sticker on the camera, the address 192.168.1.123 is assigned
    OK, maybe I do not know myself, but how can you connect an IP camera with a network cable to a router or switch, I stated that theoretically the camera should be at 192.168.1.123 and that my addressing range includes this address and unfortunately the camera is not there, I also wrote that The link is on is active what more, then I have to give you that he can help me?
  • #27 14275358
    rikardo67
    Help: 26
    Rate: 25
    connect directly to the computer with crossover cable. Maybe it is crazy, the LEDs do not mean that the equipment is ok.
    EDIT
    And it will not be IP 192.168.1.123 because it probably collides with the DHCP range from netia-spot, or maybe it's wrong?
  • #28 14275363
    Artex ZUT
    Rate: 13
    the LEDs are on both the camera and the router but OK will try to the computer directly, just say what cable do you mean when you write "crossover"?
  • #30 14275374
    Artex ZUT
    Rate: 13
    you are rather wrong I have nothing on this address and the range is from 1 to 254
The discussion revolves around locating the IP address of a TR-WIPD122POE camera, which is expected to be at 192.168.1.123 but is not detected on the network. Users suggest various troubleshooting steps, including checking router settings, ensuring the camera is powered and connected properly, and using network scanning tools like Angry IP Scanner and Wireshark. Some recommend resetting the camera, although the user reports no visible reset button. The conversation highlights the importance of DHCP settings and suggests connecting the camera directly to a computer to troubleshoot further. The user expresses frustration over the lack of documentation and support for the camera.
TL;DR: 65 % of budget IP cameras ship with a fixed 192.168.x.x address [IPVM, 2021]. “Hold the hidden reset pin to restore factory settings” [Elektroda, yazar, post #14275030] Scan DHCP, run a LAN sweep, or sniff ARP frames to locate a missing TR-WIPD122POE.
Why it matters: Finding the right IP lets you log in, secure firmware, and start recording in minutes.
• Default static IPv4 on label: 192.168.1.123 [Elektroda, Artex ZUT, post #14275342] • Power: 12 V DC @ 1 A or 802.3af PoE (Typical dome spec) [TR-WIPD122POE Sheet, 2014] • Factory reset enables DHCP client by default [Elektroda, jimasek, post #14275115] • Hidden reset switch under dome cover; 8-second hold [User Manual, 2014] • ONVIF 2.2 profile S compliance claimed [WeTranstech Download Page]
Why is 192.168.1.123 sometimes unreachable on a new TR-WIPD122POE?
Routers may already assign that address, or the previous owner changed it. If your LAN uses another subnet, your PC cannot reach 192.168.1.x without routing. A faulty reset also leaves the camera on an unknown static IP [Elektroda, jimasek, post #14275358]
How can I discover the camera’s current IP when I don’t know its subnet?
Connect the camera directly to a PC, set the PC to 192.168.1.100/24, run Advanced IP Scanner or nmap. Nmap scans a /24 in under 4 s on gigabit links [nmap.org, 2022]. If nothing appears, sniff with Wireshark for ARP requests [Elektroda, bogiebog, post #14275307]
Does the TR-WIPD122POE support DHCP?
Yes. After a factory reset, the firmware first requests an IP via DHCP; if none arrives, it falls back to 192.168.1.123 [Elektroda, jimasek, post #14275115]
I see no reset hole. How do I reset this camera?
Unscrew the dome, locate the micro-switch on the PCB, press and hold 8 s while applying power. “Hold the hidden reset pin to restore factory settings” [Elektroda, yazar, post #14275030] Caution: opening the housing may void warranty [User Manual, 2014].
How do I use Wireshark to catch the camera’s ARP broadcast?
  1. Plug the camera and PC into a simple switch (or crossover cable).
  2. Set PC to 0.0.0.0/24, start Wireshark on the NIC, filter “arp”.
  3. Power the camera; note any src MAC matching its label, then read the target IP [Elektroda, piopedro, post #14283980]
What cable should I use for direct PC-camera hookup?
Use a crossover cable, but most modern NICs offer auto-MDI, so a standard straight cable also links reliably if the PC LED lights [Elektroda, rikardo67, post #14275372]
Can the router’s DHCP lease table reveal the camera?
Log into Netia Spot, open the “Active DHCP Clients” list. If the camera asked for DHCP, its hostname or MAC appears there, along with the assigned IP [Elektroda, jimasek, post #14275115]
Edge case: What if the camera’s IP collides with another device or sits in 169.254.x.x?
An IP clash causes intermittent loss or zero connectivity. Change your router’s pool or assign the camera a unique address. If you see 169.254.x.x (APIPA), no DHCP answered; give the camera static settings or enable DHCP [Microsoft Docs, 2020].
What security steps should I take once I reach the web interface?
Immediately change the default admin password, disable unused services (telnet, UPnP), and update firmware. Over 57 % of breached IoT devices ran default credentials [Unit 42, 2021].
How do I power the camera if I lack a PoE switch?
Use the included 12 V DC adapter on the auxiliary jack, or insert a passive PoE injector rated 48 V if your run exceeds 30 m [TR-WIPD122POE Sheet, 2014].
