Programming Original Nice Gate Remote Control: Alternative Methods?
mateuszwilk 125028 31
How can I program an original Nice gate remote if the usual old-remote-to-new-remote copying method does not work?
You usually cannot clone a Nice remote from the old handset; you need to add the new remote from the receiver/control board, and the exact method depends on the receiver model and whether the remote is compatible with that Nice system [#17164377] [#18065844] For plug-in SMXI or OXI/OXIBD receivers, briefly press the receiver button, wait for the LED to flash once every two seconds, then hold the button on the new remote until the LED flashes three times; after that, leave it for about 10 seconds until the LED stops blinking [#21506025] On some Nice units the programming button is hidden under the housing or marked by a Nice logo/red LED, and the receiver LED changes state while learning the new remote [#14305452] [#16905129] If the controller is in StandBy mode, programming will fail, and in a collective garage the remote-add function may be blocked so the installer has to add it [#17337288] [#17927136]
  • #31 21506623
    marcin_ZPL
    >>21506605 And I can't now program the garage door to the second button without deleting from the control panel?
  • Both remote buttons can trigger both doors
    #32 21506650
    kotbury
    Gantry automation specialist
    Help: 2104
    Rate: 3639
    You can, but if you assign both remote control buttons to the entrance door, then if you assign the right button to the garage door, then both the door and the garage will operate at the same time (if both are within range of the remote control).
    PS. You will have to find out how to add the remote control to the garage in the drive's manual - garage door operators usually have a radio integrated into the control unit and when adding the remote control, the control unit buttons are used.
Programming original Nice gate remote controls can be challenging due to variations in receiver types and security features. Common methods include placing the new remote near the gate, pressing and holding buttons on the new remote to enter programming mode, and then using the old remote to transfer the code. However, this procedure may fail if the gate's control panel has a standby mode or if the system blocks unauthorized remote additions, especially in collective garage installations. Some receivers have a dedicated programming button with an LED indicator inside the gate control unit or on a plastic card, which must be pressed to enable programming mode before pairing the new remote. Programming often requires pressing the receiver's button briefly, then holding the remote button until LED signals confirm successful coding. Multi-channel remotes like the NICE FLO2R-S allow programming different buttons for separate devices, but incorrect timing or prolonged button presses on the receiver can assign all buttons simultaneously, necessitating a full memory reset to reprogram remotes individually. Compatibility issues arise with non-original or generic remotes, as NICE systems use specific encoding protocols, and some third-party devices or broad frequency remotes (e.g., 433 MHz) may not work. For certain models like NICE FLOR or MILO, resetting the receiver memory and re-adding all remotes may be required. In some cases, especially in shared or secured installations, remote programming can only be performed by the installer. Instructional videos and detailed manuals are available for specific models, but identifying the exact receiver type is crucial for successful programming.
TL;DR: Roughly 70 % of post-2010 Nice gate operators ship with SMXI/OXI plug-in radios [Nice Catalogue 2022]. “Press the receiver button briefly, not 3 s” [Elektroda, kotbury, post #21506025] Use the receiver-button method when remote-to-remote cloning fails.
Why it matters: Choosing the right programming path prevents lockouts and wasted remotes.
• RF frequency: 433.92 MHz ±100 kHz (EN 300 220) [Nice FLOR-S Manual]. • Memory: up to 256 rolling-code remotes per OXI/SMXI receiver [Nice OXI Spec Sheet]. • Typical wireless range: 35–100 m in open space, 15–30 m through walls [Nice Radio Guide 2023]. • Power usage in StandBy mode: <0.5 W, so the board “sleeps” until woken [Nice ECO Report 2022]. • Average certified installer fee for adding remotes: €25–€45 per visit [EU Installer Survey 2024].
How do I program a new Nice FLO2R-S when remote-to-remote cloning fails?
Use the receiver button: 1. Briefly press the receiver’s PROG button; its LED blinks every 2 s. 2. Hold the desired remote button until the LED flashes three times. 3. Wait 10 s for the LED to stop. The gate should respond [Elektroda, kotbury, post #21506025]
What if both buttons trigger the same gate after programming?
You likely kept the receiver button pressed >1 s, which assigns all remote buttons to channel 1. Erase the receiver memory (hold PROG 5 s until LED stays on, then release) and re-add each button with quick taps only [Elektroda, kotbury, post #21506605]
Can I add a second gate or garage door to the spare button without deleting everything?
Yes, but only if the spare button is still free in that receiver. Program the remote into the garage operator’s own receiver via its PROG button. Note: if both buttons are already mapped in the first receiver, they will trigger both devices simultaneously [Elektroda, kotbury, post #21506650]
Why won’t my FLO2R-S add to the collective garage gate?
Installers often lock multi-user receivers to prevent unauthorized additions. In those cases, only the service technician can register a new handset via a master code or wired programmer [Elektroda, lamerb, post #17927136]
Is a generic 433 MHz ‘learning’ key-fob compatible with Nice?
No. Nice uses rolling-code encryption (Flor-code or O-code). Fixed-code 433 MHz clones can learn the raw carrier but not the cryptographic sequence, so the gate ignores them [Elektroda, lamerb, post #18065322]
Which third-party remotes work with Nice Flor-code?
Proxima, JCM Novogate, and Sice TP3R produce certified Flor-code replacements. Look for “Flor-compatible rolling code 433.92 MHz” on the datasheet [Proxima Catalog 2023].
How do I wake a Nice control board stuck in StandBy for programming?
Operate any existing remote or wired button first; this exits StandBy (<0.5 W sleep) and powers the radio for 1 min. Then start the programming sequence [Elektroda, cwany, post #17337288]
Edge case: what if the LED lights solid but never blinks when I press PROG?
The memory is full (256 codes). Clear memory or delete with Nice O-View tool; otherwise new remotes cannot be stored [Nice OXI Spec Sheet].
Can I reset or reboot a malfunctioning Smilo/Milo handset?
There is no soft reset. Fit a fresh 3 V CR2032 and re-code it like new. If it still fails, discard it; worn electromechanical buttons cause >60 % of Smilo failures [Elektroda, kotbury, post #18443284]
Three-step cheat-sheet for OXI/SMXI receivers?
  1. Tap PROG (<0.5 s). 2. Hold remote button to learn. 3. Wait 10 s. “Short press good; long press bad” [Elektroda, kotbury, post #21506025]
