Peugeot 307 SW + LPG AG System - Depollution System Faulty (P1339)
Kasia307 23106 2
  • P1339 appears only on gas at idle and takeoff
    #1 16523033
    Kasia307
    I connect the topic under Gas installations because the fault is on gas, but I do not know if I should not under some other faults, I'm sorry, I'm just a woman :)
    on the 307 SW the message Depollution System Fautly and engine light appeared to me.
    Car for the founded AG System.
    Of course, when the message appears, the car tugs and silts, barely gaining momentum. This only happens on gas. After a long ride, it's as if it warms up decently. Of course, he was connected to a computer on the website dealing with, among others Dutch installations. First, the replacement of candle insulators on the coil was to help 90%, of course it did not help. The second time - 99% - gas injections - were cleaned and calibrated, because apparently they did not require regeneration. Still nothing. A message continues to be attached.
    Option No. 3- a coil, well I replaced the coil and candles and the solenoid valve today, by the way, because it broke during these repairs :)
    It still didn't help. Filters, of course, are OK, quite recently replaced (in February) - so this should not be because I do not do too much km.
    The computer shows the message P1339.
    On petrol it fires normally and also drives. And generally I noticed that the message turns on as I stand (e.g. at traffic lights or I move). It doesn't switch on while driving, but how much I slow down and add gas again.
    What else do I need to mention to make it finally OK? I'm already in the back a few hundred. I am from Warsaw, maybe a hint as to the checked site?
  • #2 16564053
    panstalin2
    Help: 30
    Rate: 216
    There may be a pipe under the car too crumpled - a stone hit it and narrowed its cross-section.
  • #3 16564176
    psooya
    Help: 376
    Rate: 575
    I think that the problem is still the injection and regulation. I would rather dump it ag. The regulator may still release gas by vacuum. What are your injectors and reducer and how much has it gone and since when is the problem?
