Clearing Overdue Document in Printer Buffer: Windows Printer Properties Queue Management
Qool_Luki 116729 7
  • #1 5410551
    Qool_Luki
    Rate: 29
    I have a problem in Windows, one document is overdue in the printer properties and is effectively blocking other documents waiting in the queue. Unfortunately, removing this overdue document is a very difficult thing for my system to accomplish. How to deal with this problem ??
  • #2 5410571
  • #3 5410703
    Qool_Luki
    Rate: 29
    That's what I do, the document has been in "delete" status for two hours now
  • #4 5410709
  • #5 5410720
  • #6 5410729
    Qool_Luki
    Rate: 29
    I did so, and the document did not want to be deleted. Resetting the computer helped.
    KowaI
    Rate: 49
    run the command line and type cmd and your console will fire up
    type
    NET STOP spooler
    then go to the windows \ system32 \ spool directory
    throw out everything that's in there
    and then NET START spooler
    and it will be git
  • #8 5410900
    Qool_Luki
    Rate: 29
    Thanks, I was expecting such an answer.
✨ The discussion revolves around resolving an issue with an overdue document stuck in the Windows printer queue, preventing other documents from printing. Users suggest various solutions, including canceling the print job via right-click, taking the printer offline, and restarting the computer. A more technical solution involves using the command line to stop the print spooler service, clearing the spool directory, and then restarting the service to remove the stuck document effectively.
