Dedicated devices for SDR on RTL2832U + R820T2 vs DVB-T dongle conversion for t
PalomaBlanka 20490 15
Is it worth buying a dedicated RTL-SDR receiver instead of using a converted DVB-T dongle, and is there any real difference in how they work?
There is no major difference in SDR operation, because the dedicated units and the blue DVB-T dongle use the same RTL2832U/R820T-style chip and driver, so a BSOD caused by the chip/driver would likely happen with either one [#16521986][#16237718] The dedicated models mainly add an upconverter or direct sampling for lower frequencies, plus a better metal enclosure and sometimes protection diodes on the antenna input [#16521986] If you need reception below about 100 MHz, those extra features can help, but the basic receiving capability is otherwise very similar [#16521986] Making an upconverter yourself is also described as not difficult or expensive [#16409011] Several replies also stress that the antenna matters a lot, often more than the dongle itself [#16522062]
  • Comparing dedicated RTL-SDR receivers with DVB-T dongles
    #1 16183713
    PalomaBlanka
    I recently purchased a blue DVB-T at a Polish well-known auction site for a price of ~ PLN 55
    I changed the drivers, started and completed the first listens.
    The device works, however, during work I scored a bsoda (blue screen) with standard text, whether there I did not have to install new devices and such blablabla.
    I came to the conclusion that I can buy a specialized device and I found one on Ali ...
    01. 100KHz-1-7GHz-VHF-UHF-band RTL-SDR-Upconverter-SDR-Receiver-NFM-FM-DSB-LSB-CW for 55.47 $
    02. Best-RTL-SDR-receiver SDR-USB-dongle-with-the Realtek-RTL2832u-SDR-Rafael-and-micro-R820t for the price of 38.97 $
    03. 100-KHZ-a-1-7-all-GHz-band-radio RTL-SDR-receiver-RTL2832-R820T-RTL-SDR at $ 38.65
    04. 100-KHZ-a-1-7-all-GHz-band-radio RTL-SDR-receiver-RTL2832-R820T-RTL-SDR for $ 56.01
    and 'original' from the RTL-SDR website
    05. buy-rtl-sdr-dvb-t-dongles for the price of 24.95 or 19.95 $ additionally 2 (Air Mail) or 18 $ (courier) for transport to Poland.
    My questions:
    Is it worth buying?
    Is there a clear difference in the operation of SDR between the devices and the typical converted DVB-T tuner, which can also be purchased there at a much lower price.
    Of course, you can see that dedicated devices are better equipped: a converter, switches, double aerial sockets of another type. As for the insides I do not speak, but maybe some colleague undressed the above devices and could share knowledge.
  • #2 16237045
    flinc
    Level 30  
    Help: 93
    Rate: 155
    I would not wonder what is inside, what factory is factory
    browsing websites - radio qrz- is similar radio IC-PCR1000 iTecsun PL 660 shocking prices resp. SD-era
    Added after 1 [hour] 29 [minutes]:
    Enter the Translator in your browser, and translate these links to SDR Translator
    for Polish I have Mozilla Fi ... with Translator and in a few seconds the translator translates pages in different languages into Polish and not only
  • #3 16237718
    yes2mike
    Help: 258
    Rate: 322
    I also have a blue version and death screen I have never seen.
    I would rather look for a solution, because the "dzyndzel" itself works very well and I do not know if there is a point in putting cash on something that works practically the same.
    Yes, it happened that something happened twice. How is it in life ...
    Well, customs officers can still charge you, but that's another matter.
  • Questions about 100 kHz and 3 kHz reception
    #4 16250163
    PalomaBlanka
    Indeed, after the time that has elapsed since the device was turned on, I have not detected any more bsodes. Occasionally, 'pendants'. It is not burdensome as it also stems from my lack of skills in using the software.
    I asked the questions from # 1 and maybe I did not formulate it properly, because I was interested in the ability to listen to what, these devices mentioned by me guarantee in bands from 100kHz. So you do not need to buy a dongle for the dongle, and get an efficient and guaranteed device in a neat package with a very wide range of reception at a relatively low price.
    Another question is whether you can receive correctly in the range of 3kHz because such devices are offered, or will I not use these possibilities in home conditions?
    From what I know at prices such as those given in # 1 UC should not charge any fees.
    Edytka:
    As of today, I am happy with the action of the blue dongle, and I still have a lot of exploration space, but if the devices with a larger range created many new interesting places to visit, I will gladly order now.
  • #5 16409011
    gdkj
    Help: 49
    Rate: 84
    Hello, the topic is already aging but I will add something, making up the converter is nothing difficult or expensive, on the blue dongle I pick up Warsaw 1 and on short even stereo from the wire wired in the room.
    Greetings.
  • #6 16434432
    flinc
    Level 30  
    Help: 93
    Rate: 155
    to gdkj
    View on the 20m band. 14,000-14.350 KHz, if there is CW reception on USB or LSB in the band area 14,000 -14.070 MHz, At 14.230MHz on saturday / Sun give the SSTV mode. The program for receiving SSTV is in the goggles MixW 3 .... A collection CW Fldigi and commercial MULTIPSK
    Is Up Converter receives 14.000-14.350MHz band
  • #7 16436752
    gdkj
    Help: 49
    Rate: 84
    I receive something here at 14.4MHZ
    it disappears after removing the antenna for this comb appears
    I assume that there are some interference laptop-mixer or external interference, for some time I could calmly listen to the PR1 225KHZ until recently barely breaks through the distortions. Sam dongle on 64MHZ does not show such a comb (my mixer = 50MHZ).
    Probably it will be difficult for me to pick something up on Saturday, but I will try :) Thanks for the info.
    What time to look for it? At the moment you can not see anything.
    The hairpin approx. 14.5MHZ visible always covered by noise when connecting the antenna, there are several pins in the 0-50MHZ band.
    I'm making a mix now for NE612 (SE612) with 50-100MHZ quartz.
    Greetings.
  • Jack 2.5 routes SDR audio to decoding software
    #8 16438933
    flinc
    Level 30  
    Help: 93
    Rate: 155
    In the 14,000 -14.070MHz range, set the CW to receive the Morse code *
    From Uncle Goo ... install Jack 2.5, it is a virtual input for receiving audio from all programs KF.jak Fldigi, MixW 2.19 to receive SSTV 14.230MHz Multipsk-all modulations, I am so wise on the part of Krzysztof Dąbrowski OE1KDA worth reading about any programs KF * worth *
    Added after 13 [minutes]:
    Why Jack 2.5 because you receive signals from KiwiSDR or WEB SDR, equating the reception with SDR up converter 1.7-30MHz
    Added after 39 [minutes]:
    On CW signals are in the range of 14,000-14.070MHz. SSTV 14.230MHz at different times Also a FAX signal is sent to map atmospheric conditions 3.855MHz at different times from Germany, the program for receiving FAX is JVCom32.de. Cool program is Orbitron to track amateur satellites only you need a trx band of 70cm / 2m. To run the transmitter in the satellite (Uplink-broadcast downlink-receive)
  • #9 16512052
    flinc
    Level 30  
    Help: 93
    Rate: 155
    For Paloma BL ...
    The offer 3 is a kit with RTL 2832 T820U tuner
  • #10 16515736
    gdkj
    Help: 49
    Rate: 84
    For some time now I have the impression that the sensitivity of my dong (less station) has dropped.
    Is it the charm of the blue dongle or maybe the impact of changing the weather?
    Greetings.
  • #11 16520968
    flinc
    Level 30  
    Help: 93
    Rate: 155
    gdkj
    You do not write about what stations or commercial FM 88-108 MHz or KF 1.8-30MHz or 70cm / 2m. Check the PC / Laptop hardware requirements for the dongle. On the dongle package, there should be a description of the PC / LAP hardware requirements ...
  • #12 16521884
    gdkj
    Help: 49
    Rate: 84
    Of course, KF and medium which I like to listen to, but also in other areas as if it is not much, the VHF works but I do not know if it is worse here.
    Greetings.
  • #13 16521986
    Tommy82
    Help: 455
    Rate: 1074
    I would think seriously about the purchase because of the price, that is, first I would use this little blue and then jump out of the coins. But everything depends on the level of advancement and determination.
    There, in these devices is exactly the same, as it causes something with you BSOD is the same thing will do the device because there is the same chip and the same driver.
    What these devices give is the so-called upconverter. At low frequencies there are two options either the upconverter or the so-called direct sampling.
    The advantage of the integrated solution is better shielding of the metal box in relation to the plastic one.
    It is worth noting if there are protection diodes right behind the antenna input.
    The base and so the antenna that is in this set is suitable for rummaging in the ear.
    On this stock antenna, sdr was simply deaf.
  • #14 16522062
    flinc
    Level 30  
    Help: 93
    Rate: 155
    Polemizing about receiving from the dongle, the best receiver is the antenna suitable for different frec. ANT switch. e.t.c.
  • Possible dongle sensitivity drop after heating
    #15 16523462
    gdkj
    Help: 49
    Rate: 84
    Antenna is a wire a few meters, I calmly receive PR1 225 khz, medium and short (and there German DRM for about 7mhz), for some time is weaker, fewer stations and I wonder if it's a dongle problem or just at this time it can be.
    On the same without the converter, even on this short factory antenna I caught some signals in the air band (above FM) when I took the dong out of the parcel post and now practically silence.
    I have not changed any drivers, SDRSharp ver.14.
    Blue cuddle dongle from aliexpress popular and hence the question if others also had such a phenomenon. Maybe the sensitivity decreases after heating.
    The next up-converter is planned with a switch (relays + atmega) controlled under the second usb or additional hub but have to have time.
  • Propagation effects dominate below 100 MHz
    #16 19978806
    wilkunek
    Rate: 15
    When it comes to receiving signals below 100 MHz, and especially low frequencies of 1 to 1000 KHz, the reflection of the signal is influenced by many factors - the known ones are clouds, air humidity, wave propagation style, and less obvious reflections from the stratosphere (i.e. at night should catch better during the day), magnetic storms, solar activity and stratospheric layering. The effects of such reflections are sometimes amazing. For example, a few years ago, a radio amateur from Australia heard a call for help from the Himalayas. Right now I can't find this article.
    In summary, the higher the frequency, the less willing the waves are to bounce spectacularly.
The discussion revolves around the performance and reliability of RTL2832U + R820T2 based SDR devices compared to DVB-T dongles for software-defined radio (SDR) applications. Users report experiences with a blue DVB-T dongle, including issues like blue screens of death (BSOD) and varying sensitivity. Some participants suggest that while the blue dongle works adequately, specialized SDR devices may offer better performance and broader frequency coverage. The conversation also touches on the potential for DIY upconverters and the importance of antenna quality for optimal reception. Users express mixed feelings about investing in new devices, weighing the benefits against the functionality of existing equipment.
