  • SDR uses a ready-made receiver module that outputs digital I/Q samples for software processing instead of a traditional analog-only radio chain.
  • The mixer feeds the input signal and orthogonal signals from a local PLL generator into I and Q paths, leaving the rest to software.
  • Cheap RTL2832U-based USB DVB-T and DAB+ dongles cost PLN 40-60 and cover roughly several dozen MHz to 1.8 GHz.
  • These dongles can receive amateur bands, NOAA weather maps, ADS-B transponders, meteorological radios, and even online WebSDR stations through a browser.
  • USB DVB-T reception requires installing the appropriate driver.
  • SDR - Software Defined Radio
    Structures with inductance in the diagram are often troublesome to commissioning for electronic beginners. Some people can easily go through the stages of building AM receivers to superheterodyne receivers, for others it is a difficult barrier. Ready-made radio modules are a significant facilitation, for example, allowing for easy activation of digital transmission in ISM bands.
    A step further is SDR - software defined radio. The SDR receiver is usually based on a ready module supplying digital samples of I and Q signals. These samples come from mixers, on which the input signal and orthogonal signals from the local PLL generator were fed. The rest happens in the software processing I and Q signals. Sounds complicated, but we use such a solution, for example, when watching DVB-T TV on a broadband USB receiver and software installed on a laptop.
    What do you think about SDR receivers, do you prefer a traditional receiver design for specific bands or broadband SDR?
    Due to the mass production, USB DVB-T and DAB + receivers are very cheap. The receivers are miniature, powered from USB and cover the band from several dozen MHz to 1.8 GHz. It turned out that RTL2832U-based receivers can provide I&Q samples for use in a program other than that provided by the manufacturer for television and radio reception. This enabled hobbyists to receive signals on the amateur bands, as well as, for example, NOAA satellite weather maps, signals from ADS-B transponders, meteorological radios and many others.
    Usage programs type SDR # , HDSDR , GNU radio and a USB receiver for several dozen zlotys, allows you to start the listening receiver. You can find quite good descriptions of the launch here: RTL-SDR . Such a receiver can be helpful in many cases, e.g. for starting radio modules for digital transmissions. Application examples: https://www.rtl-sdr.com/about-rtl-sdr/
    For more demanding customers, more expensive devices with the ability to work from single KHz to 2GHz have appeared https://www.sdrplay.com/rsp1a/, https://airspy.com/airspy-hf-plus/ as well as devices with the 1MHz to 6GHz range and the possibility of broadcasting, for example, https://greatscottgadgets.com/hackrf/, but in basic applications a "dongle" for PLN 40-60 is sufficient.
    The use of the USB DVB-T receiver requires the installation of the appropriate driver: https://www.rtl-sdr.com/rtl-sdr-quick-start-guide/
    On this page: http://www.websdr.org/ you will find SDR receivers that enable online listening via a browser. Some receivers listed on the website are located in Poland.
    Do you have experience with SDR receivers, what do you use them for?
    Source:
    http://www.hdsdr.de/
    TechEkspert
    Editor
    TechEkspert wrote 7346 posts with rating 5714, helped 17 times. Been with us since 2014 year.
  • #2 16977645
    prosiak_wej
    Help: 501
    Rate: 1462
    A few years ago I bought an SDR dzyndzel, played with it a bit, and finally got the ADS-B receiver on for Flightradar24. For almost a year I have a factory receiver from FR24 and the dzyndzel serves only as a holder for hanging the Uniden scanner. Maybe in spring or summer I will run it in some interesting band :)
  • #4 16978663
    ZimnySobi
    Rate: 13
    I have a Tuner with RTL NotOnly TV - LV5DX and on an antenna made by myself at work, I could listen to radio almost 200-250 km away from my location. The same soft and drivers for this USB device, this device because it was not suitable for watching TV with DVB-T, the application hung until it died completely. One of my friends on the plane was listening to the cockpit on a laptop and an antenna from a paperclip. So a little but crazy ...
  • #5 16978688
    prosiak_wej
    Help: 501
    Rate: 1462
    For listening to the cockpit, a small Uniden with programmed frequencies used on a given route and a handset in the ear is more convenient.
    In my attic I have a simple dipole tuned slightly higher than the airband, but I sometimes hear the T sector (Wrocław), J (Katowice) or even R (Radom). On the other hand, set to listen on frequencies 132.700, 134.925, 129.075, 130.875, 127.275, 119.650 and 118.100 sometimes he talks a lot, you can listen in the background when doing something :)
  • #6 16978703
    c2h5oh
    Moderator
    Help: 502
    Rate: 754
    Maybe it is worth promoting what is on the electrode instead of presenting old "news" from the world?
    The discussion on this topic has been going on since 2012:
    https://www.elektroda.pl/rtvforum/topic2353101.html#11180605
    The topic is quite long, but contains many solutions to the problems that you will have to deal with when starting this type of receiver. It also describes, for example, the issues of shielding, interference, preamplifiers, antennas and the latest curiosities in this field.
  • #7 16980360
    TechEkspert
    Editor
    Help: 17
    Rate: 5714
    @ArturAVS I suspect that not only I missed the mentioned topic in radio engineering. I think that SDR will interest not only amateurs. Once, I had the opportunity to test a bit more advanced SDR and I believe that the practice and knowledge gained even from SDR for PLN 50 can be transferred and used in other more advanced SDRs.
  • #8 16980812
    vayo
    Rate: 126
    After the publication of this topic https://www.elektroda.pl/rtvforum/topic3144164.html, I bought a USRP1 and RFX1800. I had a little fun with OpenBTS and that was where my SDR experience ended.
  • #9 16981867
    arordrg
    Help: 6
    Last year I bought "DVB-TE4000 USB DVB-T + RTL-SDR Realtek RTL2832U + R820T DVB-T Tuner Receiver". I played a few days and is lying. Works well in the FM, air and police bands. Unfortunately, you can't hear anything on the CB band (although theoretically it can). Works with PC (win and Linux) and android phones (same, high frequencies work with CB not anymore). I also tested the DAB. It works, although I'm far beyond the range of the transmitter, but I live quite high up.
  • #10 16982067
    zworys
    Help: 519
    Rate: 573
    arordrg - below 30MHz you must have a converter. Not every module wants to work in this band despite formal data that it works properly.
  • #11 16984162
    nocot
    I bought an RTL2832U fascinated by the ability to listen to virtually any band from 24 MHz to 1.7 GHz. Unfortunately, the joy ended after firing SDR # because it turned out that this radio does not receive anything but the strongest FM FM stations. No CB, air band, amateur radio, or anything else that should normally be heard on an ordinary receiver. Silence everywhere and sometimes rumble on different strands. For me, it's a waste and a waste of money.
  • #12 16984319
    arordrg
    Help: 6
    I assume that you have connected a better antenna than the one included in the set? Mine was so hopeless that it broke on the first day. Check the antenna adapter if necessary.
  • #13 16988258
    sq1gpr
    Help: 5
    Rate: 27
    Extending the topic with transmitting devices - I built and launched a transceiver for bands from 160 to 10m. The device is called Avala-01 in the network you can find descriptions and diagrams. Construction and commissioning did not cause great difficulties, and I am not a particularly experienced constructor. Certainly, building a multi-band trx in traditional technology would be a much more difficult task. The device works very well, the reception is better than on the factory equipment I have. But this is not due to the trx itself, but to the signal processing performed by the sound card.
    Here you can see what it looks like:
    Link
    Link
    Link
  • #14 16988424
    TechEkspert
    Editor
    Help: 17
    Rate: 5714
    Advanced design, maybe worth presenting in DIY .
    Connecting a laptop gives great flexibility, but there are also compact designs:
  • #15 16990031
    sq1gpr
    Help: 5
    Rate: 27
    The Avala project is already a few years old, in the meantime devices that do not require a sound card and a computer were created. By observing and reading about news in radiocommunication, you can see that the future belongs to SDR. For example, radio stations for the army produced by Radmor are only SDRs.
  • #16 16990246
    rosomak19
    Rate: 402
    Just don't tell me you wanted to receive something with that funny antenna? I have 2 RTL2832U ordered from China and I have been doing well for so many years. After adding a converter, I receive the entire HF band decoding all digital and analog broadcasts, meteo data (faxes and rtty), digital DRM radio (something similar to DAB), and also CB. On the VHF-VHF band I won't even write because it's too much. Maybe you bought a damaged one, or you naively thought that you would receive something on this pseudoantence. Okay, maybe some strong FM stations will be picked up by.
The discussion revolves around Software Defined Radio (SDR) and its advantages over traditional radio systems. Users share their experiences with various SDR devices, including the RTL2832U and USRP1, highlighting both successes and challenges in reception capabilities across different frequency bands. Some participants mention using SDR for specific applications like ADS-B reception and monitoring air traffic, while others express frustration with limited performance, particularly with stock antennas. The conversation also touches on the importance of proper antenna selection and the potential of SDR technology in modern radio communication, including military applications. Resources and links to related discussions are provided for further exploration of SDR topics.
TL;DR: Under-$20 RTL-SDR USB sticks cover 24 MHz–1.7 GHz [Elektroda, TechEkspert, post #16977350]; “the future belongs to SDR” [Elektroda, sq1gpr, post #16990031] Beginners can receive FM, ADS-B or HF (with converter) within minutes using free apps. Why it matters: One dongle plus software replaces dozens of fixed-hardware radios, cutting cost and boosting experiment speed.
• RTL2832U + R820T2 dongles: 24 MHz–1.7 GHz, ~€15–20 [Elektroda, TechEkspert, post #16977350] • SDRplay RSP1A: 1 kHz–2 GHz, 12-bit ADC, 10 MS/s max [“RSP1A Technical Information”, 2018]. • Airspy HF+: 9 kHz–31 MHz & 60–260 MHz, 14-bit ADC [Airspy Specs]. • 70+ SDR applications listed for Windows/Linux/Mac [“Big List RTL-SDR Software”]. • Typical HF up-converter adds 125 MHz LO, costs ≈€25 [RTL-SDR Blog Spec].
What is Software-Defined Radio (SDR)?
SDR moves filtering, detection and demodulation from analog circuits into software that processes I/Q samples produced by a simple front-end mixer and ADC. Updating features means flashing code rather than soldering new boards [Elektroda, TechEkspert, post #16977350]
Which low-cost dongle should beginners buy?
Most start with an RTL2832U + R820T2 USB stick. It tunes 24 MHz–1.7 GHz, works on Windows, Linux and Android, and costs about PLN 40-60 (€15) [Elektroda, TechEkspert, post #16977350]
Why can’t my RTL-SDR hear CB or HF bands?
The tuner loses sensitivity below 30 MHz. You need an external HF up-converter or a native wideband receiver; otherwise you hear only strong stations [Elektroda, zworys, post #16982067]
How do I extend coverage below 30 MHz?
  1. Insert an up-converter between antenna and dongle (e.g., 125 MHz LO).
  2. Select the converter offset in your SDR software.
  3. Calibrate frequency using a known HF broadcast. Users report decoding DRM and meteo fax after adding converters [Elektroda, rosomak19, post #16990246]
Driver installation looks scary—any quick guide?
  1. Plug dongle, run Zadig, replace factory TV driver with WinUSB.
  2. Install SDR# or HDSDR; pick “RTL-SDR (USB)” device.
  3. Click “Play”; adjust gain. The full illustrated guide is at rtl-sdr.com/quick-start [“RTL-SDR Quick Start Guide”].
Can low-cost SDRs transmit too?
RTL-SDR sticks are receive-only. For QRP transmit you need HackRF (1 MHz–6 GHz, half-duplex) or LimeSDR (10 MHz–3.8 GHz, full-duplex). Prices start around €300 [Great Scott Gadgets Spec].
How does a premium receiver like RSP1A compare?
RSP1A covers 1 kHz–2 GHz without converters, offers 12-bit resolution and 10 MHz bandwidth. Sensitivity is –140 dBm at 7 MHz (typical), beating RTL dongles by ~15 dB [“RSP1A Technical Information”, 2018].
Edge case: my dongle hears only strong FM stations—what went wrong?
Common causes are the stock mini antenna, broken MCX adapter, or excessive tuner gain. One user fixed the issue by replacing the whip and checking connectors [Elektroda, nocot, #16984162; arordrg, #16984319].
What real-world projects do hobbyists build with SDR?
Forum members use SDR for ADS-B feeders, NOAA weather maps, digital ISM debugging and even building full HF transceivers like Avala-01 (160–10 m) [Elektroda, sq1gpr, post #16988258]
Is SDR adopted in professional or military gear?
Yes. Polish manufacturer Radmor supplies SDR tactical radios; many modern military sets are SDR because firmware upgrades add new waveforms without new hardware [Elektroda, sq1gpr, post #16990031]
