Vectra Router Vnet WiFi Password Similarity & Changing Options: First 6 Characters Comparison
Yioosh 83871 18
Why do two Vectra/Vnet routers have very similar Wi‑Fi passwords, and can the password be changed?
In older Vectra/Vnet setups the Wi‑Fi key could be predictable because it was derived from the access point’s MAC address, so matching beginnings were not a coincidence [#14316960] [#16775892] The SSID and key were linked so that, for example, a network like `vnet-ABCDE2` could be joined by taking the AP MAC address and changing only the last character to match the number in the SSID [#16775892] One reply also says you can call customer service (BOK) and request a password change [#14317382] Later users reported that Vectra switched to a randomly generated 16-character password, and that it can now be changed in the subscriber’s Wi‑Fi panel/account [#16776579]
  • #1 14316922
    Yioosh
    I have been using WiFi on the vectra router for a long time and for some time something has been bothering me. Well, when I was at a friend's, who also uses a vectra router, I wanted to connect to WiFi - he gave me the password and it turned out that the first six characters are the same as mine. The point is that I am not sure if Vectra gives out almost the same passwords when configuring routers, because if this is true, then wifi networks will be very vulnerable to attacks. In addition, I do not know if it is possible to change the password, because when you called the hotline you said that they could not do something like that.
    Question for vnet users - what are the first 6 characters of your passwords? If my friend's password was not a coincidence, this matter needs to be resolved somehow.
  • #2 14316960
    Interesant
    Help: 204
    Rate: 249
    Because they are vulnerable. The first six characters are the manufacturer of the chipset / network module, the next six are the sequential number. The password to the network is MAC Adress and the preschooler is able to get into WiFi vectra.
    The worst part of all this is that the Vectra user cannot change the password himself - he has no access to the login and password to log into the Vectra router, nor to see how many "silent partners" he has to the Internet.
    To use the Vectra internet, it is enough for any program that displays to us, in addition to the network name, also the MAC address of the access point.
  • #3 14317382
    VooVoo
    Help: 215
    Rate: 266
    Nothing prevents you from calling BOK and requesting a password change - they have to do it.
  • Compilation of daily Vectra ARIS router passwords
    #4 14461945
    mefresek
    Rate: 11
    login: admin
    Password for each day different
    21.2.2015 V0ARK8TPKL
    22.2.2015 WR2BXQVS9K
    23.2.2015 SZX3N5XZLR
    24.2.2015 NUD21IPP07
    25.2.2015 WN9IXCRM3P
    26.2.2015 S36B7WVNPT
    27.2.2015 64Y3M0XLPN
    28.2.2015 2TAR28TPK3
    1.3.2015 IRHBX8V99K
    2.3.2015 N7V6US8KF8
    3.3.2015 G6JBPWYR6J
    4.3.2015 5F76UR6YOA
    5.3.2015 9463VD9Z3A
    6.3.2015 O9W2Q178AP
    7.3.2015 8722S287JP
    8.3.2015 IE5RWOCJS0
    9.3.2015 AUPBQEV7KL
    2015 IOTII7UM95
    11.3.2015 83RBPQ3PKZ
    2015-03-12 73SB78VYPT
    2013-03-13 64Y3MB9LB2
    03/14/2015 45036K9RC1
    15.3.2015 O2A2MLGZHJ
    16.3.2015 Q6YR2PNMSY
    17.3.2015 R5XR8N9YV6
    18.3.2015 WM9IQCRM3X
    19.3.2015 1V3IR4R4LW
    20.3.2015 ZV0B48HWPK
    21.3.2015 9ZD604P3IR
    22.3.2015 ZOU3MI3ZKT
    23.3.2015 PVA2PWORFP
    24.3.2015 RL93L0R2MR
    25.3.2015 ZXXR23NV04
    26.3.2015 0WFRKXSVSD
    27.3.2015 1TUIZQJ1LO
    28.3.2015 22EI0WLZLN
    03/29/2015 7776JZHJCZ
    30.3.2015 SZX3NG9ZSL
  • #5 14502951
    Interesant
    Help: 204
    Rate: 249
    Only the problem is that after restarting the device, the default wifi key returns. :-|
  • #6 14503410
    arcadioush
    If the consultant changes your password, the password remains. One-day codes for the ARRIS router are just a curiosity, because nothing can be saved there permanently. Even if you make a backup of your previously saved settings and after restarting you want to load it, the router automatically restarts and loads the top configuration.
  • #7 14504490
    Interesant
    Help: 204
    Rate: 249
    Not all settings are restored, eg Channel hardness and bandwidth is not restored.
  • Vectra Wi-Fi passwords derived from MAC addresses
    #8 14504901
  • #9 16394669
    kamilek2207
    @mefresek I have a question, do you have a password that is valid at the moment?
  • #10 16394941
  • #11 16395098
    przeqpiciel
    Help: 285
    Rate: 238
    Vectra is not so (or I am confused with another operator) that the password for your WiFi needs to be modified through some customer panel on the service provider's website and not directly in the modem?
    LINK TO VECTRY'S OWN WIFI MANAGEMENT CAMPAIGN
  • #12 16395227
    kamilek2207
    It doesn't bother me. I need to access the general panel of the router at the address 192.168. . . But for this you need a password, which unfortunately I did not receive from the installer.
  • #13 16395230
    przeqpiciel
    Help: 285
    Rate: 238
    Then put your router behind the vectra router, and set the vectra equipment to bridge mode or set your router to DMZ. And the topic of SOLVED
  • #14 16395245
    kamilek2207
    I know that it is possible to add an additional router, but it does not work for me. : / They probably do not give this router for free, in which you can add a lot of additional security elements (if you have access) ps. Remotely, it is not possible to enter what I care about (unfortunately).
  • #15 16395807
    KOCUREK1970
    Help: 3863
    Rate: 5493
    kamilek2207 wrote:
    I know that it is possible to attach an additional router, but it does not work for me. : /
    What is it, or who is the problem here to use such a variant?
    Especially since then you modify your wifi network as it suits you and with a password given by you, where the possibility of breaking into such wifi is much smaller than leaving it as it is and relying on the operator.
  • #16 16396124
  • Use a customer-owned router for better security and control
    #17 16396753
    VooVoo
    Help: 215
    Rate: 266
    kamilek2207 wrote:
    I know that it is possible to attach an additional router, but it does not work for me. : / They probably do not give this router for free, in which you can add a lot of additional security elements (if you have access) ps. Remotely, it is not possible to enter what I care about (unfortunately).
    The problem with the equipment belonging to the operator has always been there. Be it adsl, dsl or ISP of cable TV. Instead of crying that they can't be blocked etc etc, you should ask for a regular modem and buy a router that will make you happy. The discussions about poor coverage, no access, blocked XXX port, insufficient speed and similar nonsense will end!
  • #18 16775892
    Interesant
    Help: 204
    Rate: 249
    This can not be true...
    Due to the fact that more than two years have passed since I wrote this post, and the problem has already been resolved. I will present the matter to posterity in the form of a curiosity. To be able to connect to the Vectra access point, you had to find the Vectra network, eg "vnet-ABCDE2", and in any program displaying the name of the point (SSID), channel, Mac Address of the point, etc., read the Mac address of the point. When entering the key, which is the mac address of the access point, e.g. 00-11-22-AB-CD-E0, you only had to change the last character that appeared in the network name. in our case, zero for two and kick the soul ...
  • #19 16776579
    VooVoo
    Help: 215
    Rate: 266
    It's a fact, a lot has changed since then. Currently, a random password of perhaps 16 characters is generated. Of course, it is possible to change this password in the wifi panel via the subscriber account.
The discussion revolves around concerns regarding the similarity of WiFi passwords generated by Vectra routers, particularly the first six characters, which appear to be consistent across different users. This raises security concerns about potential vulnerabilities in the network. Users report that the default password is derived from the MAC address of the router, making it easy for unauthorized access. While some users suggest that Vectra's customer service can change the password, others indicate that the password resets to default after a reboot. There are mentions of the ARRIS router and its temporary passwords, as well as suggestions to use additional routers for enhanced security. Recent updates indicate that Vectra now generates longer, random passwords, and users can change them through a subscriber account.
