[Solved] Creating a Server Without Router Access: Vectra Technicolor Router Scenario
DDoS132 3675 6
  • #1 17950779
    DDoS132
    Rate: 21
    Good day. I wanted to create my own server, but I don't have access to the router. Does anyone know how to do it without access to it? Or how to get into the router without a password. The router is from Vectra (Technicolor).
  • #2 17950782
    sanfran
    Help: 963
    Rate: 3004
    It is not possible.
    Also, do you have a static IP?
  • #3 17950791
    DDoS132
    Rate: 21
    My IP is permanent.
    Pedros050
    Help: 2471
    Rate: 3927
    Co to za model? Technicolor TC7200?
  • #5 17950839
    DDoS132
    Rate: 21
    TC7230
    Pedros050
    Help: 2471
    Rate: 3927
    If you have this model, you will not get the password from Vectra. The Wi-Fi password is on the back of the router. You can change to your own via the panel: https://ebok.vectra.pl/#/login
  • #7 18410903
    DDoS132
    Rate: 21
    PIETERRR's reply
Creating a server without router access is challenging, particularly with a Vectra Technicolor router. One user inquired about server setup without router access or password retrieval. Responses indicated that accessing the router without a password is not feasible. However, if the user has a static IP, they can still proceed with server creation. The specific router model mentioned is the Technicolor TC7230, which does not allow password recovery from Vectra. The Wi-Fi password can be found on the router's back, and users can change it via the Vectra online panel.
