[BHP] Angle Grinder Usage: Directing Sparks Away for Safety and Better Visibility
BANANvanDYK 66927 39
Should an angle grinder be held so the sparks fly away from the operator, and is that a safe way to cut?
You can hold an angle grinder so the sparks go away from you, but the thread says this only makes sense when the guard is positioned correctly and you keep both hands on the tool; the bigger hazard is kickback if the disc jams, which can throw the grinder or shield toward the operator [#14335573][#14347208][#14328188][#14333923][#14334971] Several replies say the photos/manuals are really about proper body position and guard placement, not about reversing the grinder’s rotation, and the workpiece should be secured so you stay out of the disc’s line of travel [#14343427][#14334971] A few users note that the “sparks forward” setup can be awkward on some grinders because of switch and handle placement, but they still report using it that way on larger tools [#14328100][#14340165][#14342161]
  • #31 18494220
    ePasjonat
    In my opinion, the grinder is held with the right hand (right-handed), the left additional handle is screwed in and the cover is on the right side, i.e. as in the 1st post. Calling it a new method is wrong, because who said that it is new, since 99% of professionals do not read the manual and it is clearly written there. Holding the grinder in Russian with the right hand against the cover on the right is due to the fact that then you can see the cut line going from the front of the material .. and yet you go from the top / end of the material and then you can see the cut line holding the flex "new", but most people it doesn't cut from the end but from the front, which it does wrong.
  • #32 18495940
    BANANvanDYK
    Help: 1167
    Rate: 2599
    It's good that you dug up, because I wanted to write.
    Please note that the angle grinder is such a sensation among power tools that is adapted to left-handed people.
    Other tools with a similar degree of risk are built in such a way that the target, etc., is outside the operator's field of action. As an example, I can give a chainsaw and a hand-held circular saw that have cutting elements on the right - for right-handed people (although in the past you could find left-hand chainsaws).
    I recommend that you review the comments of people who have been victims or witnesses of accidents related to the use of angle grinders on the Internet. Bottom line: it's a very dangerous tool!
    Therefore, a safe way to use an angle grinder is to use it "on the left hand". The field of fire is far from the operator and the sparks do not burn the clothes. In the case of small grinders, it is necessary to use a screw-on handle, without it the grinder cannot be held securely. And, of course, the workpiece must be securely attached, not lying freely or caught by hand or pressed down with a leg.
    In the plant where I work, only one person used the "left hand" angle grinder. I am used to working on the left hand, everything else is still in the right-handed system. Recently I even learned to use hacksaw both right-handed and left-handed.
  • #33 18496047
    ePasjonat
    Exactly. In the statements above, there are arguments such as "in case of a jam, you will not hold the grinder" .. but these people do not hold it with both hands in accordance with health and safety and for their own convenience, therefore, holding it with one hand, they were afraid of the situations that were described, no has a chance of snatching the device out of a two-handed grip. Yesterday I compared both grips and holding the grinder with the right hand, even with one hand, but having the shield (cover) correctly, i.e. "on the new" side, i.e. on the right side, the grip is more secure and the elbow guidance is better, I recommend taking a look at how the wrist is engaged in the gripping with the right hand and the shield on the left ("in the old way") and how he rests and how confidently he holds his right hand with the shield on the right ("in the new way").
    At construction sites, you can see how boys cut curbs or paving slabs, each cuts "in a new way", and the rest of the movie was shown by Makita, etc. Bosch did the same.
    In the construction industry, in poor countries such as Poland, Ukraine, Russia, etc., many myths have arisen and they are passed down from generation to generation, there are many examples, e.g. that aluminum foil in the floor is used for thermal insulation, i.e. blocking heat migration to the floor under the foil when it is used only for anti-moisture insulation (the foil insulates thermally, but only in the case of thermal radiation and not thermal conduction, which occurs in the floor covered with concrete) .. or that the finish is best only after dry sanding and that it cannot be dust-free when wet, or that elastic glue for glaze is deformable glue, etc. XD Idiots do not read, because Marian did that at the construction site, I will do it too.
  • #34 18635000
    mirekas12
    adamos4 wrote:
    Not
    Yes [BHP] Angle Grinder Usage: Directing Sparks Away for Safety and Better Visibility
    And that's about it.
    I confirm, unfortunately it once seemed to me that it was better, but adamos4 is right, before that he gave a drawing of a cut, for example, a cube in this way, of course with a different disc, but this way of cutting by many of you referred to as new is correct. Think before you hate others.
  • #35 18635004
    ePasjonat
    Exactly. Let this thread be read by generations because in Poland, great backwardness and advice passed on from foremen pass with errors to the next generations of professionals and workers.
  • #36 18635010
    bearq
    Help: 414
    Rate: 1612
    Well, I'm curious because I cut like in the photo of my first colleague Adamos, although I have my left hand on the switch and my right hand on the auxiliary handle and I am right-handed and I stand on the right side of the cover with sparks ejected under me.
    On the other hand, a friend cuts while standing on the left side of the grinder with the sparks projected forward and claims that when cutting sheet metal it is better. I've tried to do that but I feel terribly insecure about it.
  • #37 18635727
    Justyniunia
    Level 36  
    Help: 397
    Rate: 1321
    It didn't occur to me to hold otherwise and to have sparks fly away from me.
    If only because in the event of any jamming of the dial, it tears the grinder away from me and ... let it fly forward, not at me.
    Anyway, I rarely use it, I'm afraid.
  • Questioning whether sparks should be directed toward the operator
    #38 19409786
    pacp
    I admit that the topic is interesting. So far, I have been cutting sparks to myself "because that's what I saw in others", but after reading the topic, I seriously wonder whether to change it. It just makes logical sense. I am not a good model, because I cut sporadically, and not like some of the above, that sandwiches to do in the morning, bread with a grinder and the button after 5:00 p.m. when the shift ends - as if one could conclude because of the experience of my previous speakers.
    However, back to the question. Most AGAINST the recoil in the jam. However, now most of the devices are equipped with anti-kickback systems (at least branded, because I assume that this type of tool should be used from proven manufacturers) ... just like chainsaws nobody buys at bazaars, rather people try to have something predictable.
    QUESTION:
    Assuming, of course, that these systems are working properly ... does it make sense at the moment to cut sparks towards each other?
  • #39 19475697
    Loczekzmc
    Rate: 8
    After 6 years from the establishment of the post, do we already know how to hold the grinder?
    I am right-handed, so I hold the body of the grinder with my right hand, and the handle with my left hand (my hand is on the handle on the side of the cover).
    I pulled out the grinder so I took it and this is how I feel it, I don't know how right-handed people can do it otherwise :D
  • #40 19476863
    Lisek64
    Help: 218
    Rate: 594
    pacp wrote:
    does it make sense to cut sparks towards yourself at the moment?
    For me, it is because the sparks do not obstruct the cut line.
    Loczekzmc wrote:
    I don't know how right-handed people can do it differently
    Because some right-handed people (like me) prefer to have a switch under control. Or maybe you are "crypto-handed"? ;-)
The discussion revolves around the safety and effectiveness of using an angle grinder with the sparks directed forward, as suggested by certain articles. Many participants express strong opposition to this method, citing safety concerns such as the risk of injury from sparks flying towards the operator and the potential for the grinder to kick back during use. Several users share personal experiences of accidents caused by improper handling, emphasizing the importance of maintaining a safe distance from the cutting line and ensuring the grinder is held securely with both hands. The consensus leans towards the traditional method of directing sparks away from the operator, which is deemed safer and more practical. The conversation also touches on the ergonomic aspects of using the grinder, particularly for left-handed users, and the necessity of adhering to safety protocols and manufacturer guidelines.
TL;DR: 27 % of workshop eye injuries involve angle grinders [HSE, 2021]. “Never stay in the disc’s line of fire,” notes Bosch safety trainer [Bosch, 2020]. Keep the guard between you and the wheel; sparks should exit forward, not toward clothes.
Why it matters: Correct orientation slashes kickback risk and preserves visibility.
• Typical 125 mm grinder spins at 11 000 rpm [Makita Spec, 2023] • EN 60745-2-3 demands an adjustable guard covering ≥120° of the disc [EN 60745] • Kickback peak force ≈ 15 N within 0.05 s [HSE, 2021] • Cutting discs cost ≈ €1–€3 (125 mm, A60) [Toolbase, 2024] • Mandatory PPE: EN166 goggles, EN388 gloves, cotton clothing—synthetics can ignite [EU Reg 2016/425]
1. Which way should sparks go during cutting or grinding?
Direct sparks away from your body and toward the work front. This places the wheel in over-cut, keeps the guard shielding you, and maintains a clear view of the cut line [Elektroda, saskia, post #14335573]
2. Why is “over-cut” orientation recommended?
When the disc bites, it drives the tool forward, not upward toward the operator. Witnesses reported head and knee injuries when the wheel pulled back toward the user [Elektroda, jaga134, #14328188; saskia, #14333923].
3. Should I reverse the motor’s rotation?
No. Reversing risks self-loosening of the disc nut and most grinders lack reversible gearboxes. Manufacturers prohibit direction inversion [Elektroda, Oprysk Stonki, post #14346646]
4. How do I set guard and handles correctly?
  1. Rotate the guard until it blocks a direct path to your torso.
  2. Screw the auxiliary handle into the top or left hole (right-handers).
  3. Test the trigger reach with both hands gripping firmly [Elektroda, manta, post #14336904]
6. What exactly is kickback and how fast can it happen?
Kickback is a sudden climb when the wheel jams. Force can hit 15 N in 0.05 s, throwing the 2 kg tool toward you at ≈ 6 m/s [HSE, 2021]. Proper stance—feet staggered, line of cut outside the body—contains it [Elektroda, manta, post #14336904]
7. Are anti-kickback electronics enough to let sparks face me?
No. Electronics cut power after the jam starts; they do not move the mass already flying toward you. Maintain correct orientation even with advanced grinders [Bosch, 2020].
8. I’m left-handed—do guidelines change?
Left-handers swap hands but keep the same geometry: guard toward torso, sparks forward. Modern grinders offer a third handle thread and rotating rear housing for comfort [Elektroda, BANANvanDYK, post #18495940]
9. Does technique differ for sheet metal versus concrete or pavers?
Sheet metal flexes, so over-cut placement reduces chatter and burrs [Elektroda, adamos4, post #14335046] Masonry discs still follow the same guard rules; use water suppression or a shroud to manage dust [Makita Manual, 2019].
10. Can the disc nut loosen if I force reverse rotation?
Yes. The nut’s self-tightening relies on standard rotation. Reverse torque can unwind it mid-cut, ejecting the wheel [Elektroda, Oprysk Stonki, post #14346646]
11. What personal protective equipment is non-negotiable?
Wear EN166 rated goggles, close-fitting cotton clothing, EN388 gloves, and hearing protection. Loose sleeves caused safety experts to flag a demo video as unsafe [Elektroda, ociz, post #14350481]
12. Quick 3-step setup before every cut
  1. Inspect disc for cracks; replace if chipped.
  2. Tighten nut, spin by hand—no wobble.
  3. Power on, let it reach full speed before touching work [HSE, 2021].
13. What edge cases cause severe injuries?
A jammed 230 mm grinder bounced like a wheel and sliced 4 cm into a worker’s knee, leading to six months in hospital [Elektroda, saskia, post #14333923]
14. Are marketing videos showing forward sparks reliable?
Treat them as advertising. Camera angles hide operator stance, and clips rarely show kickback moments [Elektroda, witoj, post #14342635]
15. Is one-handed operation ever acceptable?
No. Single-handed control forfeits leverage needed during jams. Users who tried one-handing reported poor control and visibility [Elektroda, noel200, post #14328100]
