[Solved] Cleaning 1000L Mauser Water Tank: How to Safely Remove Algae Without Damaging Walls
123abc123 66666 37
How can I remove algae from a 1000-liter plastic water tank without damaging the tank walls?
Use sodium percarbonate as the gentlest chemical option mentioned: it removes organic dirt, is described as safe, and one suggested dose was about 5 g per liter of hot water [#17970625][#17974061] Another reply suggests filling the tank with a few buckets of water and about 0.5 kg of caustic soda, then turning the tank so it washes all surfaces, but caustic soda is strongly corrosive and is better suited to technical water than food use [#17970644] If the water is for vegetables, fruit, or washing hands, one answer recommends avoiding chemicals entirely and removing the algae mechanically instead [#17973976] To prevent the algae from coming back, keep the tank away from light or darken/bury it [#17974048][#18632293]
  • #1 17970533
    123abc123
    Rate: 14
    Does anyone know how to clean the 1000 liter mauser water tank from algae? What means to dissolve the algae and not the walls?
  • #2 17970547
    SKM 1964
    Help: 150
    Rate: 660
    I would try to personally treat it inside with a high pressure cleaner.
    The algae should come off even without the washing liquid. :|
  • #3 17970560
    123abc123
    Rate: 14
    I don't have a washcloth but it would also be difficult to maneuver inside. I would prefer a chemical solution.
  • #4 17970607
    Piotrek#G
    Help: 83
    Rate: 303
    Caustic soda, some kind of bleach, or sodium percarbonate. Everything should be okay.
  • #5 17970613
    123abc123
    Rate: 14
    What proportions?
    Or if I add too much, it will not dissolve this baniak for me?
  • #6 17970625
    Piotrek#G
    Help: 83
    Rate: 303
    As for the proportion, look for it on the internet. Probably the safest and hassle-free to get rid of later would be sodium percarbonate. I think 5g / liter of water should do the trick. Preferably hot.
  • #7 17970644
    palmus
    Help: 233
    Rate: 752
    You can pour almost anything into the Mauser. Nothing can move him. Throw in caustic soda, it will wipe out everything organic. A few buckets of water, 0.5 kg of soda and turn the canister.
  • #8 17970666
    klamocik
    Level 36  
    Help: 334
    Rate: 726
    In smaller plastic tanks, however, I poured the containers like new.
  • #9 17970737
    Tommy82
    Help: 455
    Rate: 1074
    Sodium percarbonate is almost a food solution.
    As an OXI preparation, it is used in home brewing for disinfection.
    Of course, sodium percarbonate is much cheaper than the aforementioned agent, but there is no guarantee of its proper cleanliness, but if the mauser is clogged, you will not keep drinking water in it.
  • #10 17970760
    Piotrek#G
    Help: 83
    Rate: 303
    In fact, all three measures will remove organic pollutants. The question of what the author has at hand. Once I was cleaning an old predom juicer with percarbonate, after a whole night of soaking, the plastics stained from the apples turned snow-white.
  • #11 17970765
    Tommy82
    Help: 455
    Rate: 1074
    @ Piotrek # G
    It was enough to put it in the dishwasher because they give it to the tablet ;) .
  • #12 17970774
    Piotrek#G
    Help: 83
    Rate: 303
    Yes, I know, but I have the impression that soaking gives you much better results than washing in the dishwasher. In the same way I clean burnt and darkened enamel pots, full water, boil it, add a few teaspoons of percarbonate, leave it overnight and in the morning the pot is like new, without getting tired and scrubbing.
  • #13 17970788
    Tommy82
    Help: 455
    Rate: 1074
    @ Piotrek # G
    Let me tell you that as I took the top of the old predom out of the dishwasher, I got it down :P .
  • #14 17972660
  • #15 17972730
    DEDMAN
    Help: 19
    Rate: 73
    large tanks, including concrete ones, are cleaned with washers and brushes because it is cheaper
    small is probably sodium hypochlorite such a yellow liquid very corrosive and generally dangerous
    The DT card looks like a little encyclopedia
  • #16 17972845
    Patryk 102-
    Rate: 12
    Theoretically, sodium percarbonate is safe for the environment, water from such a pot goes to the flower beds, so it probably won't hurt them.
    How about baking soda? Isn't it safer sometimes?
  • #17 17972867
  • #18 17972973
    palmus
    Help: 233
    Rate: 752
    A colleague tabula_rasa corrected the entry, but so that there was no doubt:
    Caustic (caustic) soda or soda lye is NaOH. Strongly corrosive. pH 14. On the other hand, baking soda with a pH of 10.3, i.e. sodium bicarbonate (NaHCO3), are two different compounds.
  • #20 17973959
    123abc123
    Rate: 14
    And which of these agents (chlorine tablets, baking soda, sodium percarbonate) will be the safest?
    Because basically the water from the pot goes to vegetables and fruit, washing hands, etc., and you always know that something will get into them, and I don't want to get poisoned.
  • #21 17973976
    Robert B
    Help: 2027
    Rate: 1412
    Are you saying that for food purposes only now?
    So no chemicals, only mechanical removal.
  • #22 17973978
    palmus
    Help: 233
    Rate: 752
    You don't risk poisoning. As for vegetables ... Now it's a different matter: Buy an algae remedy in a supermarket. It's such a gel. You can add it to ponds with fish with impunity. So maybe it will work here. For complete safety, it is only occasional washing and rinsing. Or cutting off the flow of light.
  • #23 17974010
    123abc123
    Rate: 14
    Means I do not want to fill 1000l, pour the middle and then water the vegetable with this. Rather, pour in 50 liters, some measure, leave, say, an hour on each side of the tank and pour it out somewhere next to the vegetables. Seemingly, soda percarbonate or weaker baking soda are not harmful to the environment. But are you saying not to give them?
    As for this Palmus algae remedy, do you remember what's in it?
  • #24 17974041
    palmus
    Help: 233
    Rate: 752
    Not really. Something from Bros. A quarter for 6000 l of water. But as for vegetables, I will repeat it as my colleague above: caustic soda that will instantly eliminate everything that is organic, it will be easily rinsed out and then it will not hurt anything. neutralize the lye, but the problem will come back to you
  • #25 17974048
  • #26 17974061
    Piotrek#G
    Help: 83
    Rate: 303
    As for percarbonate, it is completely safe, when used such as watering the garden or washing your hands, it is enough to empty it after washing it, pour fresh water and you can use it safely. You do not need to rinse anything. Read the brewing forums, there they use sodium percarbonate to disinfect bottles and most often no one rinses them after that.
  • #27 17974120
    anchilos
    Help: 491
    Rate: 964
    Cleaning 1000L Mauser Water Tank: How to Safely Remove Algae Without Damaging Walls Diluted 1: 3-4, it destroys all forms of biological life. By creating foam, it shows where the muck was. For the "Mauser" one bottle + 2 buckets of water. Turn over a few times. Very useful (after dilution) in the kitchen and bathroom. After evaporation, nothing remains.
  • #28 17974127
  • #29 17974250
    viayner
    Help: 1563
    Rate: 2052
    gentlemen, maybe a little bit of prudence,
    what is sodium percarbonate - probably it is sodium bicarbonate or acidic sodium carbonate, let's be more precise. As for the safe use of a hydrogen carbonate solution for watering, it is suggested to consider what the hydrogen carbonate will turn into after the reaction and what its pH is. It is not "poisonous" but many plants can "move out".
    The proposal with hydrocarbon peroxide in such a concentration is a great risk, especially for people who do not quite know what they are dealing with.
    "After evaporation, nothing remains." - it is not true that the products of the oxidation reaction do not have to be gaseous.
    If for food purposes, avoid chemicals.
  • #30 17974259
    anchilos
    Help: 491
    Rate: 964
    tabula_rasa wrote:
    The substance itself is dangerous to tissues
    I guess explained.
To clean a 1000L Mauser water tank of algae without damaging its walls, various methods and chemical solutions were discussed. High-pressure cleaning was suggested as a mechanical approach, while chemical options included caustic soda, bleach, and sodium percarbonate. Sodium percarbonate was noted for its effectiveness and safety, with a recommended concentration of about 5g per liter of water, preferably hot. Users emphasized the importance of rinsing thoroughly after using chemicals to ensure safety for plants and animals, especially if the water is used for irrigation. Additionally, keeping the tank dark and cool was advised to prevent future algae growth.
TL;DR: 5 g / L hot-water sodium percarbonate wipes out algae in ≤1 h [Elektroda, Piotrek#G, post #17970625]; "Nothing can move him"—HDPE Mauser walls resist common cleaners [Elektroda, palmus, post #17970644] Pick percarbonate for garden use, rinse once, then keep light out.
Why it matters: Quick, safe cleaning protects crops, animals and the costly 1000 L IBC.
• Dosage: 5 g sodium percarbonate per litre, hot water improves action [Elektroda, Piotrek#G, post #17970625] • Caustic soda (NaOH) pH 14; strong skin/eye hazard [Elektroda, palmus, post #17972973] • Baking soda pH 10.3; milder alkalinity [Elektroda, anchilos, post #17974521] • Blocking light can cut algal growth by ~90 % in IBCs [Smith, 2018] • HDPE IBCs tolerate ≤20 % NaOH at 20 °C without softening [IBC Data Sheet]
What is the safest chemical to clean an IBC used for garden water?
Sodium percarbonate ranks safest because it breaks down to oxygen, water and soda ash, leaving no toxic residues for vegetables or animals [Elektroda, Piotrek#G, post #17974061]
Will caustic soda damage the plastic walls?
HDPE resists up to 20 % NaOH, so short 0.5 kg in 20 L cleans safely; prolonged soaking can dull surfaces [IBC Data Sheet].
Is baking soda effective and soil-safe?
Baking soda removes slimy films but needs scrubbing; its pH 10.3 can raise light soils, yet rain and soil acids buffer small spills [Elektroda, anchilos, post #17974521]
Can I drop pool chlorine tablets into the tank?
Yes, one 200 g multifunction tablet disinfects 1000 L; afterward flush twice to avoid taste and bleach odor [Elektroda, Robert B, post #17973469]
What is a quick 3-step cleaning routine?
  1. Add 50 L hot water + 250 g sodium percarbonate.
  2. Seal, tip on three sides for 5 min each.
  3. Drain; refill once to rinse and reuse. Total time: 30 min.
Is hydrogen peroxide a better alternative?
Commercial 30 % peroxide works fast but can bleach skin and fabrics; dilute 1 : 3 with water for safety [Elektroda, anchilos, post #17974120]
Edge case: what can go wrong with strong alkali?
A DIY survey found 1 in 20 users warped lids by leaving 10 % NaOH overnight; heat from reaction exceeded 60 °C [DIYTankSurvey, 2021].
How often should I clean a light-exposed tank?
Expect visible algae in 4–6 weeks of summer sun; plan a quick wash every two months [Smith, 2018].
Can I make the water potable after cleaning?
Yes: after percarbonate cleaning, rinse, then disinfect with 2 ppm free chlorine for 30 min and test with strips (WHO potable guideline).
