Best Grease for Gear Lever Lubrication & Identification of Attached Component
Mich43l 38796 2
  • #1 14457458
    Mich43l
    Help: 26
    Rate: 162
    I wanted to know what lubricates the gear lever
    and what is the name of this item?
    Silicone grease with Teflon suits plastic gear-lever components
    #2 14457527
    frantastic
    Rate: 11
    Generally, towot type mineral greases are used for metal components. Silicone lubricants for plastic elements. The grease has many parameters and one of them is adhesion to the substrate and this is the reason for the division of applications as above.
    Mineral greases have better lubricating properties but do not "wet" plastic surfaces. If the jack in the place of attachment is made of plastic, I suggest buying a small plastic jar of silicone grease with Teflon in an electronic parts store. It has a color between transparent and milky white. Perfect for lubricating anything made of plastic or rubber. The advantage of all silicones is that they do not flow in hot weather, so lubrication will last for a long time. It is also perfect for car door locks, even though they are metal. Towot will lubricate them better, but only until the first heat, after which it will flow without leaving a trace of presence.
    There are also new lubricants, copper, ceramic and other based on silicones, but they are terribly dirty.
  • #3 14643861
    Mich43l
    Help: 26
    Rate: 162
    I used silicone grease and everything works fine
