Cyfrowy Polsat, they cut Eleven and TVP1 channels (or no signal)
QQRyQQ2008 21522 6
  • #1 16475669
    QQRyQQ2008
    I have a problem with TVP1 and Eleven (three sports channels). Well, when watching these channels I have a continuous jamming of the picture, sound and the message no signal. I had a router connected to the LTE internet in another part of the room, but I read on the forum that it was making a problem and disconnected completely to watch the match, but it did not help. I attach the parameters of the signal and photos from the TV picture to the post. Please help me how to deal with it?
    Cyfrowy Polsat, they cut Eleven and TVP1 channels (or no signal) Cyfrowy Polsat, they cut Eleven and TVP1 channels (or no signal) Cyfrowy Polsat, they cut Eleven and TVP1 channels (or no signal)
    andpol 33
    Help: 513
    Rate: 1146
    Defective decoder or converter. Rather, I bet on the decoder. Take it under the armpit and connect to another antenna.
    LeDy
    Help: 1990
    Rate: 2938
    Connect another decoder to this installation. The signal you have is very beavers so the fastest decoder wine. .
  • #4 16476827
    QQRyQQ2008
    Thanks for the suggestions for the damaged decoder because how it looks like now, I did not take this into account and tormented this picture: I will check if connecting other equipment will help and let me know.
    Sorry, it lasts so long. This weekend I will work with a different set-top box and let me know. Until now, disconnecting the router in the room sometimes gives you the opportunity to watch these programs which were problems, but sometimes it still jams.
  • #5 16508997
    enkel
    I had the same problem with my friend. It turned out that the guys from the Net additionally established a GSM internet antenna on the mast with a satellite and terrestrial antenna. The signal was just on the eleven.
  • #6 16509680
    Krzys55
    Help: 89
    Rate: 303
    I had the same and the problem disappeared after the antenna was positioned exactly.
  • #7 16509704
    QQRyQQ2008
    I live in a block of flats and setting up the antenna on the roof is a rather difficult thing because it's probably some collecting antenna or cusine. The flat is small so devices in a circle can be disturbed as the router does. But I will not turn off the fridge, so I'll check another decoder :)
    3.1.17. Do not send very basic questions that can be found in the user manual or generally available sources. Do not present the attitude that I am due. Take care of the level of questions and discussions. Thank you.
The discussion revolves around issues with receiving TVP1 and Eleven channels, characterized by picture and sound jamming and a "no signal" message. Users suggest potential causes and solutions, including a defective decoder or converter, and recommend testing with a different decoder. One user mentions that positioning the antenna correctly resolved similar issues, while another highlights interference from a GSM internet antenna. The original poster notes that disconnecting the router sometimes improves the situation but is limited by living in a block of flats, complicating antenna adjustments.
