Peugeot, Citroen Start/Stop Capacitor Specs: Voltage, Connections, Capacity 650F?
MotoAuto 31590 9
What are the specifications and wiring details of the Peugeot/Citroën start-stop capacitor module, including its voltage, capacity, plug connection, and leakage current?
It appears to be a supercapacitor module charged to about 5.4 V, built from two 1200 F capacitors in series so each capacitor is charged to about 2.7 V [#15858548] One reply says the module is connected to the E-booster electronics, but no wiring diagram was provided [#15885413] The same source says it retains about 60% of its charge after roughly 3 months [#15885413] The thread does not give an exact leakage-current value, explain the plug cable, or confirm an internal relay [#15858548][#15885413] The answers therefore support a 5.4 V / two-1200 F supercapacitor pack, but not a confirmed 650 F rating [#15858548]
  • #1 14591428
    MotoAuto
    I have questions about the capacitor for the start/stop system used in Peugeot and Citroen cars. Maybe someone has already checked this capacitor.
    http://www.continental-corporation.com/www/pr...ss_releases/pr_2010_10_13_microhybrid_en.html
    - What is the voltage of this capacitor?
    - Are the current terminals connected directly to the capacitor or is there a relay inside the housing?
    - What is this cable with a plug for? Is it for the temperature sensor or for some electronics inside the capacitor?
    - What is the leakage current?
    - Does this capacitor actually have a capacity of 650F?
    Maybe someone has a diagram of how to connect this system in a car.
    • Peugeot, Citroen Start/Stop Capacitor Specs: Voltage, Connections, Capacity 650F? 5221111604.jpg (67.97 KB) You must be logged in to download this attachment.
    • Peugeot, Citroen Start/Stop Capacitor Specs: Voltage, Connections, Capacity 650F? 2_m.jpg (11.33 KB) You must be logged in to download this attachment.
  • #2 15858548
    Eryk1000
    Rate: 151
    This capacitor module is probably charged to 5.4V. According to practice, one capacitor is charged to 2.7V. Two 1200F units are connected in series.
  • #3 15885413
    rafal_rx
    Help: 56
    Rate: 108
    Here you have more: articles.sae.org/8412/
    There is no diagram :-( The idea is described. After 3 months, if I remember correctly, it retains 60% of the charge.
    From the article you provided and from sae it appears that it is connected to electronics called E-booster.
  • #4 17522830
    audic5
    Rate: 54
    it is a so-called Energi battery charged at 5v
  • #5 17524381
    genek1000
    Help: 289
    Rate: 1057
    Friend Audic5, can you write more about it - what is it for and what is it connected to?
    Does this have anything to do with the vehicle`s multimedia?
  • #6 17524479
    kkknc
    Help: 1915
    Rate: 6706
    To the alternator. Turning it into generators. For starting a warm engine. And acceleration assistance.
  • #7 17524875
    genek1000
    Help: 289
    Rate: 1057
    Means what? It converts this 5V into energy that the alternator uses to work as an electric motor?
  • #8 17525214
    kkknc
    Help: 1915
    Rate: 6706
    The alternator is a 3F generator. If you add an inverter, you will turn it into an engine.
    This is how it works, there are videos on YT presenting this technology.
  • #9 20009264
    Kalafiores80
    Rate: 25
    A question about S&S, a new battery, the symptom is that the engine dies and revs back up, the ECU light flashes. P1A8D error. Has anyone encountered this?
    I will add that S&S worked properly.
  • #10 21509256
    yaca1967
    Rate: 8
    I did something like this: "initializing the health status of the energy accumulator" everything is back to normal - reason? a marten got into the harness from the capacitor ...greetings
The start/stop system capacitor used in Peugeot and Citroen vehicles is typically a supercapacitor module charged to approximately 5.4V, often composed of two 1200F capacitors connected in series, resulting in a nominal capacity around 650F. This capacitor, sometimes referred to as an "Energi battery," interfaces with the vehicle's electronics, specifically an E-booster module, and is connected to the alternator system. The alternator, a three-phase generator, is converted into a motor via an inverter to assist with engine starting and acceleration, utilizing the stored energy from the capacitor. The capacitor module includes additional wiring, likely for temperature sensing or internal electronics management. Leakage current and detailed internal relay configurations are not explicitly confirmed, but the system retains about 60% charge after three months of inactivity. Diagnostic issues such as P1A8D error codes and engine stalling can occur, sometimes resolved by resetting the energy accumulator health status or addressing wiring damage caused by external factors.
