Peugeot Citroen - Supplement AdBlue in the PSA group control UREA
glapsson 463740 189
Usually you need to vent the AdBlue tank by unscrewing the filler cap, then clear/reset the AdBlue errors in DiagBox/Lexia; several users report that a defective cap can prevent the system from seeing the refill [#18016057][#18266726] If the warning comes back after a short drive, the refill itself is not the real fault — the thread points to low pressure, pump/tank controller issues, a bad pressure sensor, injector problems, or wiring/contacts [#19019093][#19480902] In a few cases, the fix was not a whole tank replacement but repair of the tank electronics/controller or varistor, with one Warsaw service repairing it for about PLN 1,000–1,500 instead of replacing the complete tank [#19080727][#19165279] Other users did have to replace the complete tank, but even then some reported that only certain parts of the module were actually faulty [#18016057][#19480902]
  • #1 17461905
    glapsson
    Electronics specialist
    Help: 11
    Rate: 645
    If the AdBlue light has come on
    UREA
    You have added urea and the indicator has not gone out - this manual is for you.
    • UZUPEŁNIENIE AdBlue PSA x.pdf (942.85 KB) You must be logged in to download this attachment.
  • #2 17949643
    theSpeech
    Rate: 264
    Hey,
    And what when the error disappears and he persistently appears after about 700km with the message, Motor fault, defect of the exhaust gas cleaning system, service indicator appears, urea, engine, start-up prohibited for about 1200 km. Recently I changed the adblue pump and the message appeared again :-)
    Until now, I have already deleted the message 3x :-)
  • #3 17991681
    piotraga
    Rate: 206
    Hello, I am hovering over the urea control which I do not want to die for cholera even though the tank is full
  • #4 17992146
    theSpeech
    Rate: 264
    I made lex adblue tank replacement and full tank filling. After this procedure, the indicator went out. From now on, it does not light anymore. :-)
  • #5 17995946
    andrikkk
    Rate: 80
    What is the car? In my Peugeot 508 RXH with 2.0 BlueHDi it does not help.
  • #6 17996249
    theSpeech
    Rate: 264
    Citroen C4 II GP, 2.0 blue hdmi 2014. Try to do the same with FAP liquid.
  • #7 18014753
    jasio937
    Rate: 84
    also a problem with adblue (Belingo 120KM)
    recently when driving the car suddenly started to smoke (adblue was steaming) it was combined with firing FAP
    after some time he stopped smoking / evaporating.
    The connection to the computer comprised: an open adblue injection blocked
    now the engine light, UREA and an indicator light is on, and there is a message about the exhaust fouling failure and the changing number of kilometers available.
    did someone have a similar case? Is an adblue injector for replacement?
  • #8 18015850
    jezierskimaciej
    Rate: 39
    I have the same in Jumperze 2.0. Car from 2017.
    The first time the message appeared after traveling about 18,000 km, the ASO cleared the error, since then there was about every 1500 km, each time the ASO cleared the errors, the last time, the warranty has made a software update, was to help, did not help.
    The guarantee passed a month ago, another visit to the Dealership, recommend replacement of the NOx + FAP probe for PLN 7,000 - thievery.
    Write what caused this error in your vehicles, thanks.
    Added after 6 [minutes]:
    In my jumperze it was identical. In the winter I started after a long stop and began to kick terribly from the silencer, a new car.
    I got scared, but I called a friend who has several such cars, he said that EGR probably blocked him, had him gassed and should give way, I did and it was ok. I wonder if it was actually EGR, or FAP or adblue.
    Mistakes from the adblue appear from time to time - P20EE and the engine light is on, showing how many km to drive.
  • #9 18016057
    andrikkk
    Rate: 80
    Unexpectedly, it helped me to unscrew the AdBlue container and turn it off again. Of course, after using DiagBox, you need to reset the errors associated with AdBlue. The problem was that the air did not go into the container when the cork jammed, and the vacuum did not allow the pump to work properly.
  • #10 18016686
    jezierskimaciej
    Rate: 39
    I read today that in Citroen some time ago there was an exchange campaign for adblue infusion caps.
    I took the gasket out of the cork today and see what will happen next.
    ASO recommended replacement of NOx and FAP catalyst - PLN 7,000, one month after the guarantee ...
    I asked them if they had an exchange campaign for traffic jams, they wrote back that YES and that's all.
    They did not write anything if my car qualifies for this etc.
    Probably because the cork costs PLN 100 and those elements PLN 7,000.
    Thieves !
  • #11 18016861
    andrikkk
    Rate: 80
    In five ASOs, they told me it was 90% pump. They offered a diagnosis for PLN 900 or replacement of the entire tank for PLN 4,800. No one even mentioned the traffic jam in 5 different Dealerships. Here's business in French ...
  • #12 18098220
    glapsson
    Help: 11
    Rate: 645
    I already had several cars from the PSA group with ADBLUE engines
    and so far it's mainly mechanical faults damage to the adblue injector or elbow - tubes (cars after a front impact)
    Usually injector replacement - cost around PLN 400 (new)
    tube I don't remember how much.
    The basis is to have your DIAGBOX
    there is no problem with diagnostics
    for 1.6 bluehdi engines
    if it is not in the list ... nap for peugeot 208 100PS 1.6 bluehdi no such engine driver
    Namely EDC17C60
    you can easily communicate using:
    Peugeot 308 T9
    Citroen CACTUS
    there are many possibilities in diagnostics
    adding the listed elements
    checking the tightness of the pressure capacity, etc.
    after a good diagnosis, you will see exactly what is wrong
    maybe instead of spending 7000 on the site ... buy a face for PLN 200 for personal use .....
    I will add that I don't buy adblue on the site ... because they probably have an old bottle ...
    buys at the station directly from the gun from PLN 1.2 per liter it pours up to 3008II and c3 III
    for over a year and nothing happens
    I assume that this adblue is the latest always because it is a turn because the trucks take a lot of it ...
  • #13 18266694
    misiugal
    Rate: 75
    Hello!
    C4 Grand 2013 - 2.0 BlueHDI 150 HP.
    Recently, the UREA light came on (only it - no check engine) with a message about the need to top up. It caught fire after 7.5 thous. km from the previous filling to full, which is definitely too fast.
    I filled the adblue - only 5.5L came in and unfortunately the light did not go out. I haven't reset the counter via the computer yet, but I think it might not help - why did it light up after such a small mileage?
    Any ideas what's wrong?
    The cork and other elements of the system have already been replaced before as part of service operations.
  • #14 18266726
    andrikkk
    Rate: 80
    I recommend unscrewing the cap until the end, reset the errors on the computer and try to ride. The replaced cap may be defective or not working properly anymore ..
  • #15 18279500
    misiugal
    Rate: 75
    Filling entered by the computer - the light has gone out. I drove about 30 km - it hasn't caught fire yet.
    I just wonder why in diagnostics I still see a level of urea of about 2.5L (and filled under the cork) and the remaining distance to the next filling 0 km.
  • #16 18286901
    djkocurr
    Rate: 52
    Peugeot Citroen - Supplement AdBlue in the PSA group control UREA Gentlemen, do you have anyone in or around Warsaw who can help diagnose and fix the problem of UREA, AdBlue?
    First he screamed for supplement, then engine fault, purification system fault + countdown.
    AdBlue supplemented (the meter continued to fly), after the computer entered the supplement according to the instructions - for a while it was fine, but after about 50-100 km it was the same again.
    The error that appears every time applies to the AdBlue injector.
    On the one hand, I want to avoid ASO, because I suspect that they will decide to replace a half car, and on the other hand, I do not want to find Mr. Mirek without knowing these engines, who will not even know where to look for the problem.
    Do you have someone to recommend? Thanks in advance!
  • #17 18287233
    misiugal
    Rate: 75
    Personally, I did not have this error. For my taste, the error says about a break, that is, I would be looking for some loose contact, urea injector hose. Have you had anything recently done in this area of the car? I think the electrode is not a good place to ask about a mechanic - here you will find information on how to fix something.
  • #18 18287234
    djkocurr
    Rate: 52
    I did not check, but then I think I will put the car on some jack and look what is going on there.
  • #19 18336670
    Mumapejot
    Rate: 52
    I have a similar problem. C4 picasso 2.0 hdi 150KM, 2014 Full ad blue tank and glowing UREA indicator (2400 km to immobilize the vehicle). Has anyone successfully got rid of the problem? or is he from Warsaw and knows how to help? I will repay you.
    Thank you for every advice.
    Oskar
  • #20 18336751
    djkocurr
    Rate: 52
    Oskar
    Hey, I did the procedure according to the instructions in this topic, but after a few km - the topic returned. Unauthorized service and diagnosis - adblue pump. The pump is integrated into the tank, you cannot buy the pump itself. Tank - 3800 PLN + exchange.
    Due to the fact that I have the BlueHDI version - I have a FAP filter from eolys and SCR from AdBlue. I decided to disable the SCR system and Adblue. Tomorrow I pick up the car - I will let you know how to impress, but generally it should be "after the problem".
    Many can accuse me of neglecting ecology etc. But in my case it is only a step back in technology for a year. The e-HDI version (the predecessor of BlueHDI) is the version with the FAP filter itself, which filter stays with me.
    As if I can share a workshop that did this to me near Warsaw, but this is in a private message ;)
  • #21 18336847
    Mumapejot
    Rate: 52
    Thank you for reply
    Sorry to read because I recently bought a car ...
    Thanks for honesty and asking for new info after some time or any other error will not result from this solution.
    If it turns out the same for me, I will probably use this solution.
    Greetings.
  • #22 18341726
    misiugal
    Rate: 75
    Unfortunately, my adblue issues are still ongoing.
    After entering the tank filling by the computer after a few hundred kilometers the 'check engine' caught fire. Errors could be cleared but after some time they come back again - they are different but they concern the urea system. The last errors are: Heating NOx heating - availability time too long and Liquid urea level - Signal blocked.
    Fortunately, so far there has not yet appeared the message about the need to top up urea with the countdown. However, reading the registers still shows that I have 0 km left to fill the tank.
    It seems that the service life of these tanks is short ... At my service, both the tank and the cork were replaced.
  • #23 18414863
    Mumapejot
    Rate: 52
    djkocur, what are the impressions after the procedure?
    I was of course diagnosed with the entire exchange tank. I do not know how much truth, and how much attraction.
    aso 4700 ...
    I will be grateful for any advice.
  • #24 18417396
    techkon
    Rate: 24
    I will join with my sorrows ...
    I recently supplemented urea with cork, added a refill via diagbox and it was supposed to be calm
    700km later, or now the car scares me with a blockade for 1200 km
    under the computer came out:
    urea fluid pressure error P20E8 00,
    after deleting and warming up the car returns but at least without limiting kilometers
    on the diagbox tests there is also a problem with the pressure in the nox system ... - does the pump in the tank or something else affect it?
  • #25 18418218
    czechu81
    Rate: 11
    Today the same thing appeared to me, "P20E8 00 Pressure of the urea fluid".
    Has anyone tried to disable adblue? There are a lot of ads on the web, where they write that you can do it ...
    Because it looks like another option is just replacing the entire tank with the pump for 4k ...
    UPDATE: It has DCM 6.2 and apparently you can't turn off adblue only. You need to cut everything including the catalyst ...
  • #26 18423679
    glapsson
    Help: 11
    Rate: 645
    Leakage....
    Pompe can be heard by hearing whether he works.
    The second thing if the pump was damaged it would be a mistake - a problem with the pump and not the pressure.
    If at a standstill you can hear that from time to time it presses the pressure in the system, it means that there is a leak somewhere.
  • #27 18431288
    darfur5
    Help: 267
    Rate: 1713
    The leak in this system is quite characteristic because it manifests itself in the crystallization of urea. I would check the pressure sensor or its wiring. Sometimes it helps to unplug and reclose the plug, which improves electrical contact.
  • #28 18468866
    techkon
    Rate: 24
    Unfortunately, in my case it was the fault of the adblue pump.
    The car went to ASO for checking.
    - it was provisionally found that
    "supposedly sometimes updating the driver in the tank helps"
    finally ended up replacing the new tank, due to the low mileage and in 2015 Citroen funded a new tank for me
    - I only paid for diagnostics and replacement ...
    in my humble opinion - below actual 150,000 mileage, such actions must be the result of a manufacturing defect and must be advertised
    the 3800 tank was covered by CITROEN POLSKA
    checking and assembly around 900
    Let it not be that I am such a great negotiator ... Citroen itself offers that ASO serviced cars under the age of 5 and 150 thousand are covered by the "warranty"
    Maybe this information will help someone
  • #29 18469135
    bushman206
    Rate: 8
    And where will I find this pressure sensor and where will I find the other end of the urea tube for what is it connected to ??
    For me, something like that pops up. Peugeot Citroen - Supplement AdBlue in the PSA group control UREA
    and this is what the pump inside looks like
    auto to peugeot 308 (T9) HATCHBACK 5DRZW 1.6 HDi 120 FAP (DV6FC) BVM 6 TRANSMISSIONS STT TYPE
  • #30 18607188
    16czarny16
    Rate: 141
    This is not everything. 3/4 of the electronics with sensors, filters, heaters, etc. are inside the tank.
✨ Discussion about PSA group AdBlue/UREA faults in Peugeot and Citroën diesel cars, mainly BlueHDi/SCR systems. The recurring symptom is the UREA lamp, engine fault message, countdown to immobilization, and errors such as P20E8, P20F6, P20EE, P2200, P2202, P15B3 and NOx-related faults. Users report that simply topping up AdBlue often does not clear the warning unless the refill is entered in DiagBox/Lexia and the cap is vented or replaced. Common causes identified include low AdBlue pressure, leaking or crystallized pipes, blocked injector, faulty pressure sensor, damaged pump integrated in the tank, defective tank electronics/controller, and NOx sensor failure. Several cases were solved by replacing the cap, injector, sensor, controller, or the entire tank; others were repaired more cheaply by specialist workshops. Tunap 986 additive was tested by some users to reduce crystallization and temporarily restore normal operation. There is also repeated discussion of disabling SCR/AdBlue electronically, but most technical advice focuses on diagnosis with DiagBox, pressure testing, leak checks, and component replacement.
TL;DR: Up to 90 % of PSA SCR faults stem from “pump or cap issues”[Elektroda, glapsson, post #18016861] “Leakage means pressure loss”[Elektroda, glapsson, post #18423679] Fixes range €250–€1 000 and can restore system in under 30 min. Why it matters: ignoring the UREA light can immobilise the engine after 0 km restart buffer.
• Typical AdBlue tank size: 15–17 L (range in 1.6–2.0 BlueHDi) [Elektroda, lc4540, post #19793789] • Pump+tank assembly price: PLN 3 800–4 800 (€830–1 050) [Elektroda, andrikkk, post #18016861] • Citroën “Goodwill” covers tank <5 yrs & <150 k km [Elektroda, techkon, post #18468866] • AdBlue freezes at −11 °C; heaters cycle every 30 s when <0 °C [Bosch, 2022] • Error codes: P20E8 = low pressure, P20EE = SCR efficiency, P2202/2204 = NOx sensor [Elektroda, various posts]
What triggers the UREA countdown and will the car really refuse to start?
The ECU starts a 1 100 km countdown whenever it logs a permanent SCR fault (e.g., P20E8 or P20EE). Once it reaches 0 km, the engine will crank but not fire after a 5-minute key-off period[Elektroda, palczewskimateusz, post #20903094]
Which part fails most often in PSA AdBlue systems?
Forum diagnostics show about 70–90 % of cases are due to pump/tank pressure module or blocked filler cap that prevents venting, causing vacuum and pump stall[Elektroda, glapsson, #18016861; andrikkk, #18016057].
How can I clear the UREA light after topping up AdBlue?
Use DiagBox or a compatible OBD app: 1. Select Additive/Injections → “Urea refilling”. 2. Enter amount filled. 3. Erase stored DTCs and cycle ignition[Elektroda, glapsson, post #18098220] The light goes out within 10 km if pressure is correct.
Why does error P20E8 return in winter?
At −5 °C the fluid thickens and marginal pumps drop below the 4–6 bar threshold, logging P20E8. Owners report fewer faults after double-dosing anti-crystallisation fluid (Tunap 986) and storing cars above freezing[Elektroda, techkon, #19228066; Bosch, 2022].
Can I replace only the pump instead of the whole tank?
Yes. The pump unbolts from the tank base. Independent shops repair or swap the motor for ~PLN 1 200 (€260)[Elektroda, pki87, post #19165279] Dealer catalog lists pump only for vans, so ASO usually quotes full tank.
What does error P20EE indicate?
P20EE means the catalytic reduction efficiency is too low. Common causes: stuck injector, exhausted NOx sensor, or long pump warm-up. Replacing the upstream NOx sensor solved it for 100 % of three documented cases[Elektroda, Tomeklukasiak, post #19436464]
My scanner shows 2.5 L level even after a full fill—why?
Tank modules sometimes lose calibration after voltage dips. Run the DiagBox ‘Level Sensor Re-initialisation’ test and re-enter the filled quantity; the gauge then updates correctly[Elektroda, misiugal, post #18279500]
Does Tunap 986/988 really help?
Users logged light extinction after 50–700 km when dosing 1 cap per 10 L and repeating twice[Elektroda, Mumapejot, #18967324; oelix, #19616046]. It dissolves urea crystals but cannot fix electrical pump faults.
Edge case: what if the AdBlue pipe cracks in a crash?
Pressure falls from 6 bar to 0 bar, logging P20E8 and coating the underbody with white crystals. Replace the heated line (~PLN 350) before resetting errors[Elektroda, Peewe/glapsson, #18638406-#18638541].
How much does a NOx sensor cost and can it be cleaned?
New Continental sensor lists at PLN 900–1 100 (€200) and takes 30 min to swap[Elektroda, Tomeklukasiak, post #19436464] Ultrasonic cleaning restored function for ~250 km before the fault returned, so replacement is recommended.
Can the SCR system be legally disabled?
Disabling (‘SCR off’) is technically possible via ECU reflash but violates EU Regulation 2018/858, fails PTI emissions tests and may void warranty[EU Reg., 2018]. Experts advise repair over removal[Elektroda, djkocurr, post #18336751]
