Installing K-2 BR Satel Reed Switches in PVC Oknoplast Windows: Drilling Guidelines?
stonefree 15807 10
Where in a PVC Oknoplast window can I drill to install K-2 BR Satel reed switches, and what is the proper way to do it?
Install the reed switch in the line of the fittings, where factories and installers normally drill, and follow the general rules for the specific PVC profile and manufacturer. If the window is still under warranty, read the warranty terms first or ask the supplier whether this kind of installation is allowed, because some installers will warn about warranty loss [#14669509][#14765268][#14763033] A properly drilled hole for the sensor should not by itself affect the parts covered by the window warranty, as long as the work is done according to the rules [#14671389] The thread does not give a detailed drilling template or drill-bit recommendation, only that an experienced installer should know the approved drilling points for that profile [#14765268]
  • #1 14669495
    stonefree
    Help: 85
    Rate: 321
    Hello. I need instructions on installing K-2 BR Satel reed switches. The facility has windows made of PVC Oknoplast. I mean tips if it is possible, and if so, where and how to drill holes for reed switches.
    suworow
    Help: 650
    Rate: 1278
    Always in the line of fittings where the factory and assemblers also drill. Several times, when the customer had objections, I reported the matter to the supplier. So far, I've always received a positive response, with detailed information on how to do it.
    Read Zbych's topic about reed switches.
    https://www.elektroda.pl/rtvforum/topic2942435.html#14200560
    Regards
  • #3 14670855
    darzec
    Help: 13
    Rate: 24
    Now I also wanted to install contracted, 3-glazed windows with warm assembly in windows made of windowplast
    and I did not get approval because I will lose the warranty.
    Window fitters want 150 zlotys for one reed switch per installation.
    All I had to do was put on the glued ones. If it's under warranty, make sure you don't void it.
  • #4 14671366
    stonefree
    Help: 85
    Rate: 321
    And if I decide to drill for these K-2, what do you recommend? A wood pen or a regular drill bit for steel?
  • #5 14671389
    _ZBYCH_
    Help: 10
    Rate: 71
    You should not ask the manufacturer or window supplier for such things as the installation of recessed reed switches. It is known that they themselves want to earn on it (and they do not necessarily know what and how to do), so they will threaten to lose the warranty.
    I wrote and showed what a factory messed up sensor assembly looks like (for a lot of money) in the thread linked above by the Moderator Suvorov .
    By the way, I've seen so many messed up reed switch installations that it's hardly surprising that manufacturers or window suppliers are trying to defend themselves.
    If you hire someone else to install, they assume the risk.
    If you want to experiment on your own windows and you feel up to doing the installation yourself, then do it and don't ask.
    If you screw something up and the window falls apart (or there is a window or hardware failure related to your work), don't go to the window supplier to fix it, because you have a guarantee.
    If the written warranty does not say that it is not allowed, and you do it in accordance with the art, then no one has the right to withdraw the warranty for windows, because a properly drilled hole for the sensor does not affect anything that is covered by the warranty.
    My friend! You're asking for problems...
  • #6 14763033
    eAlarmy
    He will take over the risk of possible incorrect installation, but he will not give a guarantee for windows, which we can theoretically lose during installation.
    It is necessary to read the warranty whether such installation does not involve interference / violation of the window structure. Or as he wrote suvorov it is worth writing to the supplier and asking how and where the factory and fitters install it.
    eAlarmy.pl Marcin Borowski
    Armii Krajowej 1/3, Częstochowa, 42-202 | Tel.: 34 X XXX XXX (Show) | Company Website: https://ealarmy.com.pl
  • #7 14763187
    _ZBYCH_
    Help: 10
    Rate: 71
    My many years of experience show otherwise. If any of you think that the factory will do it best, I refer you to the thread:
    Reed switches in windows - request for opinion
  • #8 14764934
    eAlarmy
    I didn't write that the factory will do it best because I know it won't. I wrote that before installation, it is worth finding out where the "factory" mounts it to make sure that we can install it there ourselves and we will not damage the window.
  • #9 14765268
    _ZBYCH_
    Help: 10
    Rate: 71
    eAlarmy wrote:
    I didn't write that the factory will do it best because I know it won't. I wrote that before installation, it is worth finding out where the "factory" mounts it, to be sure that we can install it there ourselves and we will not damage the window.
    We don't need a factory for that. I don't even think that they will provide such information (I won't even mention the drawing), because what interest do they have in it?
    All you need is information about the manufacturer and profile type (if it is a PVC or aluminum window). There is no problem with wooden ones at all. Besides, there are general rules where you can drill and every experienced installer knows them.
  • #10 14765434
    eAlarmy
    From user questions stonefree I conclude that he does not have such knowledge and is not an experienced installer, so I try to help him.
  • #11 14767028
    reweriko
    Help: 65
    Rate: 99
    Maybe I won't help ... but wouldn't it be easier to enter in a popular search engine - reed switch installation in the window ....?
    Accurate drawings reviews and what your heart desires....
    Why all these emotions?
    ALLSYSTEM
    Krzyżowa, Bytom, 41-909 | Tel.: 530XXXXXX (Show) | Company Website: http://allsystem.eu
Instructions for installing K-2 BR Satel reed switches in PVC Oknoplast windows emphasize caution regarding warranty implications and drilling techniques. Users are advised to drill in alignment with factory fittings to avoid damaging the window structure. Concerns about voiding warranties arise when modifications are made, and it is suggested to consult the window supplier for guidance on installation locations. Various drilling tools, such as wood pens or steel drill bits, are discussed, with a consensus that experienced installers should be aware of general drilling rules. The importance of understanding the manufacturer's specifications and installation practices is highlighted to ensure proper installation without compromising window integrity.
