Hello. I wonder if, apart from installing reed switches in the windows, it would be good to have reed switches in the roller shutters. The roller blind is probably the first point of attack, so if the alarm was triggered when the roller blind was lifted, it could potentially save the window from damage. After all, the blind is always cheaper than the window. By the way, will the Satel Versa 15 control panel for a single-family house be sufficient? There will be a smoke detector, gas detector, about 7 detectors and 16 reed switches attached to it. Potentially second 16 reed switches for roller shutters.
yaro30
yaro30
Rate: 10
