Dell Vostro 2520 (DV15 MLK MB) – R2941 resistor value or schematic?
gregory30 11631 5
  • #1 14697772
    gregory30
    I have a laptop as after flooding..
    Unfortunately, the pads corroded so much that one resistor fell off.
    I can't find a schematic anywhere.. Does anyone have this?
    Or at least, if someone could tell me the resistance of this element, I would be very grateful.
    It's about R2941 with the U2901 chip.
    Plate:
    DV15 MLK MB
    11280-1
    MXRD2 Rev:A00
    Thanks in advance for your help.
  • #2 14697944
    boro1234567
    IT specialist
    Help: 2772
    Rate: 1540
    U2901 designation?
    Post a macro photo of its surroundings.
    Album cast?
    Is there a 48...... style mark on the disc?
  • #3 14698006
    gregory30
    Sorry.. I actually did not show off the above photo.
    I put the plate designation as well as the place where the resistor is missing.
  • Identifying the audio codec via related DV15 schematics
    #4 14698345
    lisek
    Service technician RTV
    Help: 6352
    Rate: 6883
    This is the Wistron DV15 platform on KBC NUVOTON NPCE885PA0DX
    From the Polish forum Link_Elvikom
    It's probably a sound chip from Cirrus A213DC?/*the name is hard to see link
    * but the Cirrus company uses designations according to code e.g. CS 5333 (Cirrus)
    Typically Dell used to have a series codec Link_ 92HD87B1X5NDGXTBX
    Then helpful:
    - SM from Quanta R53 and find the diagram on page xx under U35 (92HD87)
    - meter and "on ohms find connections with the answer pin.u35"
    This was done on Wistron Enrico Caruso DV15 HR MB 10316-1. Rev: A00
    there were several revs in this DV15 series. sometimes differing in circuits in the audio path, KBC, chipset, in DC-DC converters, FAN control _no data and SM ,
    * different numbering and descriptions of items elements per MB different rev.
    - it ver. mainly for the US market
    your model is on KBC NPCE885 and HM75 chipset (slj8f) under i3 (sandy bridge)
    DV15 MLK MB
    11280-1
    MXRD2 Rev:A00
    *similar
    Dell Inspiron 3520 / apparently it (48.4IP16.011) ?
    DV15 MLK MB
    11280-1
    PWB:MXRD2 Rev:a00
    bios chip MX25L6406
    DC-DC RAM ISL95838x HR
    link
    (' :!: ') Vostro 2520 (DV15 MLK MB) no schematic
    Take a look, for example, at the solutions from ENRICO's DV14
    ___________________
    Dell Inspiron N5050 ( - DV15HR 48.4IP16.011 / 10316-1)
    i.e. (Wistron DV-15 HR)
    KBC (NPCE795P)
    HM67 chipset
    stby TPS51123
    charger BQ24707
    VCORE power-phase (ISL9583 )
    under item U2901 there is the Azalia IDT92HD87 - B1 - A5NDG system
    DV15 CP UMA MB 10263-1 (48.4IP01.011]
    or
  • #5 14700941
    gregory30
    Thanks for your answer, but I still can't solve it.
    I found a sticker that might come in handy.
  • CS42L55 identification and R2941 pin assignment
    #6 14701604
    lisek
    Help: 6352
    Rate: 6883
    There you have a system in a 36QFN housing (i.e. 4x 9 pin)
    Reading the brochure from the 2012 CirrusLogic company it turns out to be a CS42L55 chip
    link_datasheet
    marking on case: APPLE, 338S0394, A1GIO736, MAL
    *unless it's something from early production
    read the datasheet, compare by pins
    - comes out of the photo. that the resistor is R2941 connected to pin.25 (A2INB analog signal input)
    • CirrusLogic_Audio_Solutions_Brochure_2012-07.pdf (16.86 MB) You must be logged in to download this attachment.
