Gorenje WS50109N Washing Machine: Fixing Error F7, Filter Removal, and Water Draining Issues
adasios7 13524 3
  • #1 16380449
    adasios7
    Hey, I recently have a problem with the Gorenje WS50109N washing machine, namely I am getting the F7 error, I read that it is a filter, but it cannot be removed from my washing machine, so I turned it around and did everything manually. However, the washing machine has not drained water for some time. Can it be fixed somehow?
    kot mirmur
    Help: 206
    Rate: 561
    Hello, why can't it be pulled out, which stands in the way? If there is so much dirt that it has blocked the filter and therefore it cannot be removed, you must remove the entire pump assembly and simply disassemble it [separate the motor from the filter chamber]. By the way, clean the hose from the tank and the drain.
  • #3 17956389
    SZPANER_
    And how is the filter chamber separated from the engine? Because I unscrewed the filter and you can see that it broke and probably the pieces flew on. After washing, water in the drum remains
  • #4 17956436
    Kenworth 18
    Help: 2442
    Rate: 3749
    If the pump filter with the nut is damaged, it is available: https://north.pl/czesci-do-pralek/czesci-gore...09n-pralki-gorenje,235,WS50109N,m1786687.html
    To separate the motor from the pump body, remove the 3 screws securing the motor.
    It's best to remove the pump from the washing machine for this operation, but you can also pimple and remove the motor itself.
