Siemens S7-1200 + Lenze servo - Profinet <-> Ethernet communication
maly-p 8100 5
  • Configuring S7-1200 and Lenze 9400 Profinet communication
    #1 14708993
    maly-p
    I have a question for you: is it possible to communicate between the Siemens S7-1200 PLC (ProfiNet protocol) and the Lenze 9400 servo drive (with an Ethernet module)?
    I've been trying for a while and it doesn't work very well. I have TIA Portal v13, I added the GSDML file I downloaded from Lenze, I try with TSEND_C block, but still can't communicate.
    It probably doesn't matter, but I will add that there is a switch between the devices.
    If anyone knows the topic, please help.
  • #2 14709216
    liberateme
    Level 19  
    Help: 35
    After the profinet, I was communicating 8400 Highline, and was not using TSEND blocks. When adding the inverter to Hardware Configuration, I chose the appropriate I / O map, and connected the appropriate signals to the Engineers in the FB Editor. In PLC, I simply used PIW and PQW.
    Regards
  • #3 14710099
    maly-p
    I am more interested in servo parameterization, i.e. sending specific frames with data.
  • #4 14739929
    krzysiul
    Help: 36
    Rate: 31
    I have added in the attachment a detailed instruction with examples of 9400 communication over Profinet (TiaPortal).
    The switch does not interfere with operation.
    • S7_AppSample_v3__Tia_Portal_.zip (49.66 MB) You must be logged in to download this attachment.
  • #5 14739933
    krzysiul
    Help: 36
    Rate: 31
    And even more general.
    • 200_4_8_V1_0_Commissioning_9400_with_ProfiNET.pdf (3.18 MB) You must be logged in to download this attachment.
  • #6 16478591
    wangcx
    thanks a lotB
