[Solved] Comparing Siemens S7 Controllers: S7-200, S7-300, S7-400, S7-1200, S7-1500 - Selection Criteria?
5907 7
  • Request for Siemens S7 selection criteria and documentation
    #1 16683144
  • Selection criteria for Siemens S7 controllers
    #2 16683730
    rollinstone
    Automation specialist
    Help: 36
    Rate: 30
    Communication protocols available (profibus, profinet, fiber optic etc.)
    Maximum number of inputs / outputs
    Programming environment (Microwin / Step7 / Tia Portal)
    The speed of performing the operation
    Maximum memory per program
    There are so many factors that it's hard to really give a universal way to select a driver
    As for the parameters themselves - if you search well on the Siemens website you will find comparative tables
  • #3 16684717
    maly_ZE
    Help: 14
    You can find everything on the network, the problem is that you need to know what you do not know Unfortunately, you will not get a universal guide with step-by-step instructions on what driver to choose because this area is so extensive, objects controlled by plc so diverse that each control system differs from yourself:)
  • #5 16694912
  • #6 16715604
  • #7 16811390
    bigmaster
    Rate: 91
    I am also facing the selection of a new PLC application, the company should invest in a newer generation + software
    and the prices s7-1500 vary from PLN 5,000 to PLN 40,000
    I have to have ProfiBus (communication with ABB) on board ProfiNet bass Ethernet inverters for SCADA
    the number of IO is not known yet
  • #8 17430278
The discussion focuses on the differences between various Siemens S7 controllers: S7-200, S7-300, S7-400, S7-1200, and S7-1500. Key selection criteria include communication protocols (e.g., Profibus, Profinet), maximum I/O capacity, programming environments (Microwin, Step7, TIA Portal), operational speed, and memory capacity. Users emphasize the lack of a universal guide for selecting the appropriate controller due to the diverse applications and requirements. The S7-1200 is noted for its compact design, suitable for smaller applications, while the modular S7-300 and S7-400 are better for larger systems. Additionally, inquiries about specific documentation for WinCC and characteristics of PAC and DCS systems are raised, along with considerations for failsafe outputs.
