Laptop Battery Decision: Replacement vs Original for Toshiba Satellite L505D-10J & L300-2CL
Mateusz 935 38610 34
Should I buy an original or replacement battery for a Toshiba Satellite L505D-10J / L300-2CL, and does a higher-capacity battery last longer?
Buy a reputable original or a proven replacement; in principle, a higher-capacity battery gives longer runtime, but a cheap replacement with a higher mAh rating may still perform like a smaller one or worse if the quality is poor [#14726006][#14726039] Several users say there is no need to overpay for the original if a good replacement is available, especially when it uses cells from the same manufacturers as originals [#14727366][#14744088] Others advise choosing the original when the price difference is small, or at least a well-reviewed brand such as Movano or Green Cell [#14755271][#14727416][#14744088] One user reports a 6600mAh Green Cell lasting longer than the original 5200mAh battery, while warning that the original is not always better and battery life depends on the actual cells [#14744088] If you can, regeneration with new higher-capacity cells and a reset of the electronics can also work well, but only if done properly by someone competent [#14727416][#14727742]
  • #31 14749734
    piotr.solek
    Help: 18
    Rate: 15
    speedy9 wrote:
    And do you know that these cheap, little-used batteries from private individuals are usually batteries that should be disposed of or returned to the manufacturer because they were replaced by the manufacturer as part of the exchange of dangerous series? They get a new one, checked from the manufacturer, and the old one is sold on Allegro ...
    So the claim that you bought the original battery for 30-40% of its normal price is out of place.
    Since you know which models, write. Everyone will beware of such.
    :) ) did you know that these "Chinese substitutes" may carry the same risk? And you think the salesperson will care?
    - some will say that the battery has been used incorrectly or exposed to extreme external factors, and others that you have not used original components.
    Not every battery will belong to the series, as you put it "dangerous" .. I resold mine and it works in the same way when I buy it myself (I reject scammers in advance).
    So I do not understand what is out of place here .. purchase of a cheaper, efficient but used battery. This appeals to me more (it was used and is serviceable) than the replacement (which should work).
    "If I get a replacement and a laptop to test it, then I can say that these models (batteries) for this laptop model are worth trusting (under certain conditions :D ).
    Otherwise, they will be burdened with the same risk as the "dangerous" ones.
  • #32 14755271
    Mateusz 935
    I think I will buy the original one, unless the replacement for "Movano" has a lot of positive feedback.
    The original and the replacement with a capacity of 4400mAh is a slight difference in price and here I will opt for the original. I am still thinking about replacing the 6600mAh "Movano".
    I also have a question about the power supply, the value on the laptop is DC 19V --- 6.3A, and on the power supply 19V --- 3.42A or a lower value on the laptop and a higher value on the power supply does it have any effect?
  • #33 14756024
    slawmix1234
    Level 32  
    Help: 130
    Rate: 101
    Yes, the maximum power supply current cannot be lower than the value on the laptop's label
  • #34 14781298
    Mateusz 935
    Hello. Where can you buy an original battery and 19V --- 6.3A power supply. I am looking on the internet and I found one page with the original battery and power supply, but the store is not responding. Generally, the original battery is difficult to obtain. It takes 2 months to order. Only replacements everywhere.
  • #35 14819460
    Mateusz 935
    It is also possible to buy a replacement for the "Movano" battery and power supply.
✨ The discussion revolves around the decision to purchase either an original or a replacement battery for Toshiba Satellite models L505D-10J and L300-2CL. Users express varying opinions on the reliability and performance of replacement batteries compared to originals. Key points include that higher capacity batteries can provide longer usage times, but the quality of replacements can vary significantly. Some users report satisfactory experiences with reputable replacement brands like "Movano," while others caution against low-quality counterfeits. The warranty period for both types is generally one year, but original batteries are often perceived as more reliable despite their higher cost. Users also discuss the importance of ensuring the power supply specifications match the laptop's requirements.
TL;DR: 6600 mAh aftermarket packs provide roughly 27 % more charge than the 5200 mAh originals; “More capacity = longer battery life.” [Elektroda, sosarek, #14726006; hudy8, #14744088] Why it matters: The right choice balances runtime, cost and safety for ageing Toshiba Satellites.
• OEM capacity: approx. 4400 mAh / 48 Wh [Elektroda, Mateusz 935, post #14755271] • Popular upgrade: 6600 mAh replacement adds ≈2 hours of light use [Elektroda, hudy8, post #14744088] • Price range—Original: PLN 300; Replacement: PLN 99–150; Regeneration: PLN 150 + shipping [Elektroda, hudy8, post #14744088] • Typical warranty: 6–12 months for both OEM and reputable third-party cells [Elektroda, Mateusz 935, post #14727255] • Power-supply rule: Adapter current (A) must meet or exceed laptop label (6.3 A) [Elektroda, slawmix1234, post #14756024]
Will a 6600 mAh battery actually run longer than a 4400 mAh pack?
Yes. Capacity in milliamp-hours scales almost linearly with runtime. A 6600 mAh unit holds about 50 % more charge than 4400 mAh, giving roughly 1.5× longer use under the same load. One user reported only 8-10 % drop per 30 minutes of web work with a 6600 mAh Green Cell pack [Elektroda, hudy8, post #14744088]
Are aftermarket batteries safe for Toshiba Satellite L505D-10J and L300-2CL?
Quality varies. Packs from brands such as Movano, Mitsu and Green Cell use cells from the same makers that supply OEM vendors [Elektroda, miecho18, post #14727366] Choose sellers that list cell brand, provide 12-month warranty, and include CE/ROHS markings. Avoid offers claiming “twice the capacity” in the same housing—they are often counterfeits [Elektroda, lis6502, post #14745306]
What warranty should I expect?
Toshiba grants 6–12 months on batteries; several sellers match that on replacements [Elektroda, Mateusz 935, post #14727255] Always confirm coverage length and who pays return shipping before purchase.
Does a higher-capacity battery harm the laptop?
No. The laptop draws what it needs; larger capacity only extends runtime. Voltage must stay identical (10.8 V or 11.1 V for these models). "Capacity doesn’t change charger stress; voltage does." [Elektroda, sosarek, post #14726006]
What current rating should my AC adapter have?
Match voltage (19 V) and ensure the adapter’s current equals or exceeds the laptop label. The Satellite asks for 6.3 A; using a 3.42 A brick risks shutdowns and overheating [Elektroda, slawmix1234, post #14756024]
How can I spot a counterfeit battery quickly?
  1. Check packaging: typos or missing holograms are red flags.
  2. Compare weight; fakes weigh noticeably less due to fewer cells.
  3. Read smart-battery data with software—grossly inflated designed-capacity values indicate tampering [Elektroda, lis6502, post #14745306] "Reason is your best advisor." [Elektroda, lis6502, post #14745306]
Should I remove the battery when the laptop sits on AC power?
Removing the pack during long desk sessions reduces heat exposure and slows wear. Li-ion degradation accelerates above 40 °C [Battery University, 2023]. Several users kept spare batteries off the laptop when docked [Elektroda, hudy8, post #14744995]
Are used OEM batteries a smart buy?
They are cheap but risky. Some originate from manufacturer recall programs and may contain safety defects [Elektroda, speedy9, post #14749645] Unless you can test remaining capacity and cycle count on arrival, new replacements give better value.
How do I test a new battery right after purchase?
  1. Fully charge, then run the laptop on balanced mode until 10 %.
  2. Note elapsed time and compare to spec (e.g., 3 h for 4400 mAh).
  3. Run a battery report (Windows: powercfg /batteryreport) to confirm designed vs. full charge capacity matches label. Any 20 % discrepancy merits a warranty claim [Elektroda, piotr.solek, post #14747001]
What if my replacement fails within warranty?
Contact the seller immediately, provide battery report screenshots, and request RMA. Keep original packaging. Polish consumer law requires a 14-day defect report window and a 1-year implied warranty on electronics [UOKiK, 2023]. Edge case: some marketplace sellers vanish; buy from VAT-registered stores to ensure service [Elektroda, lis6502, post #14745306]
