Toshiba Satellite A300-1EB: Specifications for RTC (CMOS) Battery Replacement?
blazejpop 9360 6
  • #1 16587088
    blazejpop
    The computer is quite old and there are probably no original batteries on the market.
    What replacement should I buy? I mean the specification: voltage, capacity.
  • #3 16587128
    blazejpop
    I know there is such a thing as google. I have used and seen this page.
    The key word in your post is "probably". It's a different model. The probability that the battery is different is low, but not nil.
    I would like to get information from someone who has replaced and knows what this battery should be.
  • #4 16587132
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10456
    Therefore, you should unscrew the computer and check it carefully.
  • #5 16587154
    blazejpop
    Then I will find out that the board has a similar-looking battery with a blue border, without any data.
    It doesn't change the fact that I still won't know what kind of battery it is.
    I cannot afford desoldering, because the computer is in use all the time.
  • #7 16587190
    blazejpop
    This answer is already more satisfying.
    Thanks!
The discussion revolves around the replacement of the RTC (CMOS) battery in the Toshiba Satellite A300-1EB laptop. The original poster seeks specific specifications such as voltage and capacity for a suitable replacement, noting the difficulty in finding original batteries due to the age of the device. Responses suggest checking online resources for similar models and emphasize the importance of verifying the battery type by inspecting the laptop. A key recommendation is the Maxell ML1220 lithium battery, which is reportedly used across the A300 series, indicating a commonality in battery specifications among these models.
