Seeking PJL File for Brother HL-5450DN Printer Counter Reset
sdanielos77 12780 6
  • Seeking PJL reset file for Brother HL-5450DN counters
    #1 14741515
    sdanielos77
    I need to reset the counters in the hl-5450dn printer.
    In most Brother printers, the brmainte program or the appropriate key combinations sufficed, but here the solution is more complicated :(
    From the analysis of the service documentation, page 222
    ...(3) Double-click "FILEDG32.EXE" on the computer to start it, and select the "BrotherMaintenance USB Printer".
    (4) Drag and drop the periodic parts resetting PJL file onto the "Brother Maintenance USBPrinter" icon...
    As you can see, I need a file with PJL commands, which unfortunately I don't have.
    I would like to ask you to send or information where you can download such a file, or information if there is any other method of resetting for this printer.
    Regards, Danielos77
  • #2 14762969
    dr.master
    Help: 518
    Rate: 927
    Dude, you're having a hard time reading.
    PJL is a software file that you do not have access to and you will not get it outside of an authorized service, although you do not need it for anything.
    Depending on the toner/drum, there are different combinations.
  • #3 14764990
    sdanielos77
    Regarding the previous answer:
    1. I'm not talking about drum or toner resets, but about fuser and PF-KIT consumption counters
    2. PJL en.wikipedia.org/wiki/Printer_Job_Language
    Such a file can be used to load firmware, but not necessarily, for example
    in HP printers after sending a PJL file with the content to the printer
    %-12345X@PJL
    @PJL SET SERVICEMODE=HPBOISEID
    @PJL DEFAULT LANG=ENGLISH
    @PJL SET SERVICEMODE=EXIT
    %-12345X
    we will set the printer language to Polish.
    So I'm still looking for how to reset the fuzer and download.
    Regards
    Sdanielos77
  • #4 14932173
    leny84
    I have a similar problem with this model, I need to delete the fuser, but this brmainte program does not have this model in its inventory. Anyone have a solution? Maybe advice where the PJL file for deletion can be downloaded.
  • #5 16163950
    tosiaczus
    PJL files should match the HL-5450, because the language change is for this model.
    %-12345X@PJL
    @PJL DEFAULT COUNTRYCODE="0001"
    @PJL DINQUIRE COUNTRYCODE
    @PJL EXCUTE MAINTENANCE74
    %-12345X
    Contents of the archive signed as BL_PJL_Reset_Files.zip
    Reset Parts HL5452DN
    Spoiler:
    DefaultPaperLtr.pjl
    HL5440D_0001_USA.pjl
    HL5450DN_0001_USA.pjl
    PREDISCHARGESET_RESET.pjl
    REPLACEFUSER.pjl
    REPLACELASER.pjl
    REPLACEPFKIT1.pjl
    REPLACEPFKIT2.pjl
    REPLACEPFKITMP.pjl
    SQWAVE.pjl
    next package:
    Reset_HL5452DN_5472DW_6182DW_DCP8112DN_8157DN_8152DN_MFC8512DN_8712DW_8912DW_8952DW/
    PREDISCHAGESET_RESET.zip
    SQWAVE.zip
    Refer to the service manual before use because you may need a service program to enter the laser code when you reset etc. and you probably won't. So you use at your own risk.
    • PREDISCHAGESET_RESET.zip (246 Bytes) You must be logged in to download this attachment.
    • SQWAVE.zip (197 Bytes) You must be logged in to download this attachment.
    • BL_PJL_Reset_Files.zip (1.79 KB) You must be logged in to download this attachment.
  • #6 16870212
    Batya27
    Hello everyone!
    You need to reset the page counter on the HL-L2340 (HL-L2300, HL-L2360). Please help me.
  • #7 18552621
    yanwei
    Think you!!!
The discussion revolves around resetting the counters for the Brother HL-5450DN printer, specifically the fuser and PF-KIT consumption counters. The original poster, Danielos77, seeks a PJL (Printer Job Language) file to facilitate this reset, as traditional methods like the brmainte program are ineffective for this model. Responses indicate that PJL files are necessary for certain maintenance tasks, and while some users suggest that such files may be available, they caution that accessing them typically requires authorized service. One user provided a sample PJL command sequence and mentioned a ZIP archive containing reset files for similar models, advising users to consult the service manual before use. Other users also expressed similar needs for resetting counters on different Brother printer models.
