Zamel GNS921 Doorbell Installation: Wiring Guide for Long Distances & Multiple Walls
bonczek87 35433 12
How do I wire a Zamel GNS 921 doorbell/gong to a 230 V supply and switch so the live wire goes through the button and the neutral goes directly to the unit?
Connect the neutral (N) directly from the fuse box to the bell’s N terminal, and run the live phase (L) from the fuse box to the switch and back from the switch to the bell’s L terminal [#14820045][#14820479] The switch simply interrupts the phase, so one wire feeds L to the switch and the other wire returns it to the gong [#14820479] If your unit is marked 1 and 2 instead of L and N, the order does not matter [#15608461]
  • #1 14819824
    bonczek87
    Help: 5
    I have a problem with the installation of the bell, I am a layman, I had a wireless doorbell, but because of a large distance and the number of walls it worked as it wanted, so I released the two-wire cable for the Zamel GNS 921 doorbell, I get the electricity directly from the fuses that I have installed under the bell only as it is now connect?
    From the switch, I connected the brown cable to the L and the blue cable to the arrow, but how is it now to connect in the bell together with the cables from the fuse?
    Thank you in advance for your help :)
  • #2 14820045
    zdzisiek1979
    Help: 561
    Rate: 1254
    How? You have everything nicely described in the manual.
    You have led out L and N from the switchboard, L you give it to the switch, it returns, it goes to the terminal in the L bell and you give N directly to the bell on the N terminal.
  • #3 14820119
    zbich70
    Help: 1171
    Rate: 6666
    bonczek87 wrote:
    I let go of the two-wire cable
    And why didn't you "let go" of the single-core "cable" ???
  • #4 14820237
    bonczek87
    Help: 5
    What does it mean that it comes back from the switch? I have a brown and blue cable in the switch, this is how it should stay or only one cable will be there that will be responsible for the L?
    zdzisiek1979
    Help: 561
    Rate: 1254
    The switch activates the phase after pressing, so the phase goes from the protection with one wire to the switch and the second returns if you have two wires, then the brown phase is supplied from the switchboard, and the blue one returns to the terminal in the L bell and the N wire from the switchboard you give directly to the bell on the terminal. I cannot explain it more blatantly.
    You have nicely drawn up by the manufacturer from "power supply from the switchboard" to the bell itself. Although it's not a bell, but a gong, never mind.
  • #6 14821804
    bonczek87
    Help: 5
    Thanks, it helped, however, I have a problem because inside the electromagnet, it probably calls it, it gets very hot and stinks when ringing, is it normal?
  • #7 14821870
    haneb
    Help: 61
    Rate: 214
    bonczek87 wrote:
    I think the electromagnet is called when it rings it gets very hot and stinks
    bonczek87 wrote:
    I take the current directly from the fuses
    Do you have a 1-phase or 3-phase power supply at home?
  • #8 14821902
    retrofood
    Help: 1140
    Rate: 4797
    Yes, in principle normal, because the chime is not intended for continuous operation. It's supposed to bim-bam and shut up, so if you've played with it using the signal repeatedly, you've got a chance to burn it.
  • #9 14822134
    Krzysztof Reszka
    Help: 609
    Rate: 1551
    And the assembly is in accordance with the instructions
    quote ;
    Please note
    for the vertical arrangement of the bell (marked
    based).
  • #10 14822406
    zdzisiek1979
    Help: 561
    Rate: 1254
    And I ask you, this is the chime on 230V :D
    As a rule, the coil should not get too hot because the coil design is resistant to the constant short-circuit of the switch, otherwise it would be bad.
  • #11 14822413
    retrofood
    Help: 1140
    Rate: 4797
    zdzisiek1979 wrote:
    because it is a coil construction resistant to continuous short-circuit of the connector
    Unfortunately, this is not the case.
  • #12 15608271
    marthunia
    Rate: 21
    I'm just plugging this bell in and I'm stuck which cable should I connect where. I mean exactly the bell itself. Unfortunately, there are no L and N markings on the bell, only 1 and 2, where 1 is at the top and 2 at the bottom. The instruction is a bit poor for me. Someone will help?
  • #13 15608461
    Łukasz-O
    Admin of electroenergetics
    Help: 654
    Rate: 4290
    It does not matter.
The discussion revolves around the installation of the Zamel GNS921 doorbell, particularly focusing on wiring for long distances and through multiple walls. The user initially faced issues with a wireless doorbell due to distance and obstructions, prompting a switch to a wired solution. Guidance was provided on connecting the doorbell to the power supply, emphasizing the correct wiring of the brown and blue cables from the switchboard to the bell. Users clarified the function of the switch in activating the phase and discussed concerns about the electromagnet overheating during operation, with advice given on normal operating conditions and potential risks of continuous use. Additional queries about the bell's terminal markings were also addressed.
