Pendrive freezes the system - how to fix it?
jaymz 23976 18
How can I fix a Verbatim STORE N GO 16GB pendrive that freezes Explorer and the whole system when connected, and can it be saved?
Yes — this looks like an SMI controller/firmware problem, not a simple partition issue, so the best fix is to reflash or recover the firmware with the SMI tools for the SM3257ENAA controller, such as SMI Mass Production Tool / SMI OnlineRecovery [#14945731][#15540340][#15542611] If the drive is still accessible in DMDE, one suggested step was to delete the existing partition and create a RAW partition from all available space, then disconnect and reconnect it [#15537023] When saving the partition changes or formatting fails with timeout, the forum advice was that normal partitioning will not help anymore and only firmware upload may work, otherwise the flash drive is physically damaged [#15537467] In the thread, using SMI OnlineRecovery made the pendrive work again and stopped the system freezes [#15542611]
  • #1 14941096
    jaymz
    Help: 5
    Rate: 23
    I have a problem with the Verbati STORE N GO 16GB pendrive, it freezes the explorer, my computer and other file managers, when it is connected and I turn on the computer, the desktop appears only after 10-20 minutes, but when I take it out almost immediately. The problem is only with this flash drive, others work fine so it is not the fault of the computer. Fortunately, all files were successfully recovered DMDE and ChipGenius can see it, and now the crux of the matter is it possible to save it?
    Description: [G:] USB Mass Storage Device (Verbatim STORE N GO)
    Device Type: Mass Storage Device
    Protocal Version: USB 2.00
    Current Speed: High Speed
    Max Current: 500mA
    USB Device ID: VID = 18A5 PID = 0304
    Serial Number: AAOI3PIV9OY6JCNY
    Device Vendor: Verbatim
    Device Name: STORE N GO
    Device Revision: 1100
    Manufacturer: Verbatim
    Product Model: STORE N GO
    Product Revision: 1100
    Controller Vendor: SMI
    Controller Part-Number: SM3257ENAA - ISP 110401-AA-
    Flash ID code: ECDE98CE - Samsung K9BDGD8U1M - 2CE / Single Channel [TLC-8K] -> Total Capacity = 16GB
    Tools on web: http://dl.mydigit.net/special/up/smi.html
    Possible Flash Part-Number
    [1CE] K9ACGD8U0M (27nm) x 2 pcs / Channel x 1 Channel
    [2CE] K9BDGD8U1M (27nm) x 1 pcs / Channel x 1 Channel
    Flash ID mapping table
    [Channel 0] [Channel 1]
    ECDE98CE --------
    ECDE98CE --------
    Pendrive freezes the system - how to fix it? Pendrive freezes the system - how to fix it? Pendrive freezes the system - how to fix it?
    Is the entry in photo 2 correct? Invalid partition table.Error loading operating system.Missing operating system
    Win XP SP3 - Biostar M7VIQ (yes I know old)
    Thanks.
  • #3 14945731
    pidar
    Help: 1569
    Rate: 3591
    Try to update the firmware.
    • SMIMPTOOL_REPACK_v2_5_42_7_O0515v1.zip (3.31 MB) You must be logged in to download this attachment.
  • #4 14958279
    jaymz
    Help: 5
    Rate: 23
    I haven't tested these programs yet because I want to check something else.
    Someone knows a program that will recover data with original (modification, creation) dates of directories, most of these types of programs recover the dates for files.
  • #5 14958422
    wroteczek
    Rate: 27
    I had a similar problem with USB bluetooth and probably also with the USB flash drive. The only solution is to start the computer without a USB flash drive inserted.
    Apart from this strange event, the devices were operational.
  • #6 14958442
    jaymz
    Help: 5
    Rate: 23
    Unfortunately, it's not that simple, because even when the computer is turned on and I insert a USB flash drive, the system freezes. Besides, DMDE also crashes if I select "Logical Drives"
  • #7 15536956
    jaymz
    Help: 5
    Rate: 23
    I was away for a while, I'm still struggling with this flash drive
    @mbo, @pidar
    I checked these programs, unfortunately after starting the menu where the disks are selected it is empty - so far only DMDE sees it.
    Can I modify it somehow in DMDE? I don't care about the data.
    And there is an error in the event viewer:
    Podczas operacji stronicowania wykryto błąd urządzenia \Device\Harddisk11\.
    mati211p
    HDD and data recovery specialist
    Help: 2585
    Rate: 1133
    Then delete this partition in DMDE and then create a RAW partition from all available space and save the changes. Disconnect and reconnect the flash drive, check the effect.
  • #9 15537388
    jaymz
    Help: 5
    Rate: 23
    After deleting the partition and creating the RAW partition, I cannot save the changes, I have these errors:
    Also tried HDD Low Level Format Tool - also failed formatting error (timeout)
    What else can I do?
    mati211p
    Help: 2585
    Rate: 1133
    Then there is a problem with the pendrive, only firmware upload or it is physically damaged. No partitioning will help here.
  • #11 15539893
    jaymz
    Help: 5
    Rate: 23
    I ran chkdsk on this flash drive - can that help?
    Microsoft Windows XP [Wersja 5.1.2600]
    (C) Copyright 1985-2001 Microsoft Corp.
    C:\Documents and Settings\Michał>chkdsk g:
    Typ systemu plików to NTFS.
    Etykieta woluminu: STORE N GO.
    OSTRZEŻENIE! Nie określono parametru F
    Uruchamianie programu CHKDSK w trybie tylko do odczytu.
    CHKDSK sprawdza pliki (poziom 1 z 3)
    Ukończono sprawdzanie plików.
    CHKDSK sprawdza indeksy (poziom 2 z 3)
    Ukończono weryfikację indeksów.
    CHKDSK sprawdza deskryptory zabezpieczenia (poziom 3 z 3)
    Ukończono sprawdzanie deskryptorów zabezpieczeń.
    Trwa sprawdzanie dziennika Usn...
    Naprawianie segmentu rekordu pliku dziennika Usn.
    Zakończono sprawdzanie poprawności dziennika Usn.
    System Windows znalazł problemy z systemem plików.
    Aby je poprawić, uruchom program CHKDSK z opcją /F (naprawa).
      15740951 KB całkowitego miejsca na dysku.
      15543184 KB w 4125 plikach.
           860 KB w 127 indeksach.
             0 KB w uszkodzonych sektorach.
        123515 KB używanych przez system.
         65536 KB zajętych przez plik dziennika.
         73392 KB dostępnych na dysku.
          4096 bajtów w każdej jednostce alokacji.
       3935237 ogółem jednostek alokacji na dysku.
         18348 jednostek alokacji dostępnych na dysku.
    Unfortunately I cannot run CHKDSK with the / F option because there is not enough disk space.
    Can I upload the firmware?
    pidar
    Help: 1569
    Rate: 3591
    Try with:
    • SMI SM3257ENAA MPTool V2.03.58 v8 K1129.zip (3.94 MB) You must be logged in to download this attachment.
  • #13 15540817
    jaymz
    Help: 5
    Rate: 23
    Is this correct behavior? I changed the driver to SMI, I launched SMI Mass Production Tool - I chose Config Hub - scan usb (automatic) then OK - then Scan Usb (F5)
    I mean the Capacity and VID / PID loudspeakers - are they correct? - can I upload the firmware?
    and one more thing - should Auto Start over Factory Driver and Hub be checked?
  • #14 15542611
    jaymz
    Help: 5
    Rate: 23
    I used SMI OnLineRecovery and the pendrive probably works and does not crash the system anymore - now ChipGenius sees it like this:
    Description: [G:]Masowe urządzenie magazynujące USB(JetFlash Transcend 16GB)
    Max Current: 200mA
    USB Device ID: VID = 8564 PID = 1000
    Serial Number: 7E15JN2KC62L9LZU
    Device Vendor: JetFlash
    Device Name: Mass Storage Device
    Manufacturer: JetFlash
    Product Model: Transcend 16GB
    Controller Part-Number: SM3257ENAA - ISP 140218-AA-
    Flash ID code:      ECDE98CE - Samsung K9BDGD8U1M - 2CE/Single Channel [TLC-8K] -> Total Capacity = 16GB
    [1CE]K9ACGD8U0M(27nm) x 2 pcs/Channel x 1 Channel
    [2CE]K9BDGD8U1M(27nm) x 1 pcs/Channel x 1 Channel
    ECDE98CE	--------
    ECDE98CE	--------
    SMI Mass Production Tool like this:
    DMDE like this:
    First of all the LBA size was changed was: 31494144 and now it is: 30855168
    How can I restore it to the previous settings, e.g. such
    Please help.
    pidar
    Help: 1569
    Rate: 3591
    jaymz wrote:
    How can I restore it to the previous settings, e.g. such ...
    Keep trying. :wink:
    http://www.usbdev.ru/articles/a_smi/smimptool-repair/
    • SMI MPTool v2.5.36 v7 N0725v1.zip (5.3 MB) You must be logged in to download this attachment.
  • #16 15552372
    jaymz
    Help: 5
    Rate: 23
    How can I set such a Serial in this tool: AAOI3PIV9OY6JCNY
    EDIT: I've already dealt with it.
  • #18 15554595
    jaymz
    Help: 5
    Rate: 23
    pidar wrote:
    What program and how was the serial number changed?
    Basically every SMI MPTool I have used v2.5.41 as you prompted me on PW. At first, I created Verbatim.ini for the flash drive:
    Later, on the Extra Setting tab, select "Enable Unique Serial Number"
    then create a file, e.g. serial.ini (regular txt file) and indicate as in the picture:
    First, I just entered the series, the rest was added by the program in the form of:
    AAOI3PIV9OY6JCNY
    [TEST]
    SERIALMETHOD=0
    SNLEN=16
    SERIALBEGIN=201302IP000200010000
    SERIALEND=201302IP000299999999
    SERIALMASK=201302IP0002########
    AUTODATE=0
    AUTODATESTART=3
    AUTODATEEND=10
    HEXCHARS=
    I changed the entries in the notebook:
    on:
    SERIALBEGIN=AAOI3PIV9OY6JCNY
    SERIALEND=AAOI3PIV9OY6JCNY
    SERIALMASK=AAOI3PIV9OY6JCNY
    and save
    After starting the program and entering Setting it looks like this:
    at the end Start ...
    H2testw:
    Test finished without errors.
    You can now delete the test files *.h2w or verify them again.
    Writing speed: 8.97 MByte/s
    Reading speed: 11.1 MByte/s
    H2testw v1.4
    Flash Drive Information Extractor:
    Volume: G:
    Controller: Silicon Motion SM3257 ENAA
    Possible Memory Chip(s):
      Samsung K9ACGD8U0M-2
      Samsung K9ACGD8S0M *2
      Samsung K9ACGD8U0M *2
    Memory Type: TLC
    Flash ID: ECDE98CE 74C3
    Flash CE: 2
    Flash Channels: Single
    Chip F/W: ISP 140218-AA-
    MP: P0310V1
    MPTOOL Ver.: 2.05.41
    PTEST Date: 2014-02-18
    VID: 18A5
    PID: 0304
    Product: STORE N GO
    Query Vendor ID: Verbatim
    Query Product ID: STORE N GO
    Query Product Revision: 1100
    Physical Disk Capacity: 16225665024 Bytes
    Windows Disk Capacity:  16208863232 Bytes
    Internal Tags: QT2R-T99G
    File System: FAT32
    Relative Offset: 24 KB
    USB Version: 2.00
    Declared Power: 500 mA
    ContMeas ID: 2B91-04-FF
    Microsoft Windows XP SP3 Build 2600
    http://www.antspec.com/usbflashinfo/
    Program Version: 8.4.0.588
  • #19 15556577
    jaymz
    Help: 5
    Rate: 23
    Special thanks to colleagues: pidar and mati211p - many thanks, gentlemen!
    Happy Easter to everyone !!!
The discussion revolves around a Verbatim STORE N GO 16GB pendrive that causes system freezes when connected, particularly during boot-up. Users suggest various troubleshooting methods, including using recovery tools like PNY Flash Drive Repair Tool and Silicon Power RecoverTool, updating firmware, and running CHKDSK. The original poster experiences difficulties with data recovery and partition management using DMDE, leading to suggestions to delete and recreate partitions. Eventually, the user successfully repairs the pendrive using SMI OnLineRecovery, which resolves the freezing issue. The conversation highlights the importance of firmware updates and potential physical damage as causes of the problem.
