SanDisk 16Gb USB3.0 VID=0781 PID=5581 Pendrive Failure: Formatting Issue and Unresponsiveness
rmroz80 17220 4
  • SanDisk Sumeru reports 64 MB before becoming unresponsive
    #1 15402278
    rmroz80
    As the topic. A student recently brought me a job on a Sandisk Ultra flash drive
    USB 3.0. The flash drive is like new because the student received it for Christmas. After inserting the pendrive into the laptop, a message appeared that the pendrive should be formatted.
    The formatter indicated that the capacity of the device is .... 64MB! The format attempt was unsuccessful and after some time the pendrive stopped giving any signals of life.
    The only thing I was able to do was read data such as VID and PID with Chipgenius 3.0. The entire Chipgenius screenshot is below:
    Description: USB mass storage device (SanDisk Sumeru)
    Device Type: Mass Storage Device
    Protocal Version: USB 3.00
    Current Speed: High Speed
    Max Current: 296mA
    USB Device ID: VID = 0781 PID = 5581
    Serial Number: 0123456789ABCDEF
    Device Vendor: SanDisk Corporation
    Device Name: Sumeru
    Device Revision: 0100
    Manufacturer: SanDisk
    Product Model: Sumeru
    Product Revision: 1.00
    For comparison, the result of Flash Drive Information Extractor 8.4
    Volume: None
    Controller: SanDisk
    Possible Memory Chip (s): Not available
    VID: 0781
    PID: 5581
    Manufacturer: SanDisk Corporation
    Product: Sumeru
    Query Vendor ID: SanDisk
    Query Product ID: Sumeru
    Query Product Revision: 1.00
    Physical Disk Capacity: 67108864 Bytes
    Windows Disk Capacity: 0 Bytes
    Internal Tags: BW2F-SAHK
    USB Version: 3.00
    Declared Power: 296 mA
    ContMeas ID: 2AD8-03-00
    Microsoft Windows 8.1 x64 Build 9600
    http://www.antspec.com/usbflashinfo/
    Version: 8.4.0.588
    I tried various formats from Russian and Chinese but to no avail, neither of them can see the device. Only ChipGenius and the latter can see them.
    Anyone have any idea?
  • #3 15402390
    rmroz80
    safbot1st wrote:
    Twin:
    https://www.elektroda.pl/rtvforum/topic3157067.html
    I set the time of death to 10:05. It self-immolating. Blood and fire ...
    Added after 43 [seconds]:
    In your post I read about Phision. My guess is that it is service software for memories produced by this company.
    I tried some version before but to no avail. Can not see.
    safbot1st wrote:
    Personally, you can still try USB Oblivion.
    As for Obilivion, I do not know if I understood the description correctly, but it is probably used to make the computer "forget" which USB flash drive was connected to it before. For me, after starting Oblivion, the pendrive after connecting is no longer visible in Windows Explorer. I must keep digging.
    pidar
    Help: 1569
    Rate: 3590
    There are no tools available for this specific controller. :|
    rmroz80 wrote:
    ... after running Oblivion, the pendrive is no longer visible in Windows Explorer after plugging in.
    I am asking for info about him from:
    • Usb Drive Info v5.0.2.0.zip (350.71 KB) You must be logged in to download this attachment.
  • #5 15421841
    rmroz80
    Mikołaj found a receipt so resuscitation does not make sense, and since there are no tools, it would be impossible anyway. Thank you, however, for the information. I think that others with the same problem will be helpful.
    I close the thread and greet all forum members.
