Pendrive Issue: GoodRam 32GB Shows 0.0GB - NAND USB2DISK, VID=FFFF, PID=1201, Chipsbank Controller
Frizos 47910 3
  • Chipsbank controller detected with 0 GB capacity
    #1 17610034
    Frizos
    Hello. I have a problem with the flash drive, it is two weeks old and it suddenly lost itself yesterday, after connecting to the usb, drivers are installed and that's it. I don't know what load he needs or how to upload it. Can anyone help ?
    Info from ChipEasy:
    [F: \] NAND USB2DISK USB Device [0.0G]
    Logical drive: F: \ Capacity: 0.0G
    Device ID: VID = FFFF PID = 1201
    Device SN:
    Device version: 0.00
    Device vendor: NAND
    Device model: USB2DISK
    Protocol: USB2.0
    Max power: 100mA
    Partition type: Device active:
    Aligned state: Misaligned
    Controller: Chipsbank
    Controller model: CBMANDFlash Vendor: (Open Network for more information)
    FW Date: USB2.SK.
  • #2 17610916
    pidar
    Help: 1569
    Rate: 3590
    To check such a tool -> FirstChip MpTools . :idea:
    • FirstChip MpTools v1.0.2.9.zip (4.57 MB) You must be logged in to download this attachment.
  • #3 17628092
    wilkunek
    Rate: 15
    The program below!
    I have a GoodRAM 16Gb Twister pendrive ?:
    Description: [F:] USB mass storage device (NAND USB2DISK)
    Device Type: Mass Storage Device
    Protocal Version: USB 2.00
    Current Speed: High Speed
    Max Current: 100mA
    USB Device ID: VID = FFFF PID = 1201
    Device Revision: 0000
    Manufacturer: NAND
    Product Model: USB2DISK
    Product Revision: 0.00
    Controller Vendor: FirstChip
    Controller Part-Number: FC1178BC
    Flash ID code: 453C98B3 - SanDisk - 1CE / Single Channel [TLC] -> Total Capacity = 32GB
    I was looking for a long time MPtools for my pen drive, only version 20180903 or 1.0.3.9 from the website (in Chinese) worked:
    http://www.upantool.com/liangchan/fristchip/13101.html
    No previous version of the program has seen my pen drive. Interestingly, the flash drive changed the PID from 5678 to 1201 after the repair. I'm not penetrating.
    Google translate:
    https://translate.google.pl/translate?sl=auto...tool.com%2Fliangchan%2Ffristchip%2F13101.html
    or attachment. Kaspersky does not see viruses.
    • FirstChip_MpTools_20180903.zip (6.47 MB) You must be logged in to download this attachment.
  • #4 20800155
    mraworx
    Rate: 15
    thanks so much
